Best F355 check engine reset tool for a 1999 model? | FerrariChat
Discussion in '348/355' started by Turblow, May 30, 2024.
  1. Turblow
    Turblow Karting
    99
    Who knows the best tool to reset after the catalyst ECU and slow down light triggered my check engine light?
  2. Challenge
    Challenge Formula 3
    Sep 27, 2002
    2,013
    PA
    Kevin
    If that's all you need to do, the cheapest of OBDII code readers will work.
  3. Turblow
    Turblow Karting
    99
    I would like something to use for maintaining the car since I do my own work on my lift minus engine drops every 7+ years.
  4. ssnowball
    ssnowball Formula Junior
    295
    Scot
    I currently utilize BlueDriver, you can pick one up on Amazon. I found the information provided was helpful when I experienced SDL issues earlier this past month, monitoring the system through the app. Bluetooth connection was easily managed and works well with my Apple products, iPhone and iPad.
    Mike Morrissey likes this.
  5. JoeCab
    JoeCab Formula Junior
    425
    Colorado
    Joe C
    I used BlueDriver too for a basic ODII code reader, and it does work well considering the low cost and simplicity.
    It will read and clear codes related to the engine/emissions only, as those are what is federally mandated to be available through the OBDII system. It can also livestream and record various data if you're using it for troubleshooting.
    On the F355, it won't be able to interface with the ABS, Suspension, Airbag, and F1 system ECUs, so it can't clear any of those warning lights. You will need other devices to deal with those systems.
  6. Turblow
    Turblow Karting
    99
    Surprises me there still really isn’t anything besides an SD1 to deal with these cars and lower cost options like Leonardo at $5k is dumb. Figured by now some China copy of SD1 would exist.
    JSBMD likes this.
