Best fuel additives....around | FerrariChat
Discussion in 'Ferrari Discussion (not model specific)' started by patpong, Oct 20, 2005.
  1. patpong
    patpong Formula 3
    Jul 6, 2004
    2,274
    Bangkok, Thailand
    Patpong Thanavisuth
    What brand is the best fuel additives of your choice for your Ferrari? for injectors or carb. which make you feel the different? which really clean the system?....
  2. 911Fan
    911Fan Formula 3
    Apr 15, 2004
    1,294
    Southern California
    Just use good, fresh, fuel and drive it regularly. Let it gently get to operating temp then drive it like it's meant to be driven, through the entire RPM range, reaching redline at least once every outing. No token drives around the block.
    You won't need any additives.
  3. BigAl
    BigAl F1 Veteran
    Mar 17, 2002
    6,146
    TX
    GSgt Hartman
    I use Techron when I need to clean things out and always use Chevron gas (with Techron).
  4. bobafett
    bobafett F1 Veteran
    Sep 28, 2002
    9,193
    Add a bottle of Swepco 503 to every tank. Your car will love you for it. Proven success with hard-driven, race-winning production ferraris.
    Alternatively the redline brand of fuel system cleaner / fuel additives are very good. I believe SI-3 is the one you can add to every 3rd tank or so.
    --Dan
  5. paulie_b
    paulie_b F1 Veteran
    Jan 13, 2003
    6,842
    Jupiter, FL
    Paul Bianco
    Techron for me also. the super concentrate. I seem to remember that they have 3 types.
  6. Ken
    Ken F1 World Champ
    Oct 19, 2001
    16,078
    Arlington Heights IL
    Kenneth
    None in the US if you buy 'name brand' gas.
    Unless you're running over about 10.5:1 compression ratio and need an octane booster because you can't get premium gas, premium pump fuel is fine. It has cleaners and anti-knock stuff already in it. The only caveat is to always buy gas from a busy station; it will have high turnover and less water will accumulate in their underground tanks.
    You can add carb/injector cleaner every now and then but frankly I think it's a waste of money.
    Ken
  7. parkerfe
    parkerfe F1 World Champ
    Sep 4, 2001
    12,887
    Cumming, Georgia
    Franklin E. Parker
    I put a little Marvel's Mystery Oil in my Boxer ever two or three tanks. It helps keep the top end lubed.
  8. mark328
    mark328 Guest
    Jul 30, 2005
    664
    Mi
    Mark
    Would not recommend using anytype of additive to every tank or even every 3rd tank. If you store your car over winter months i may add a bottle of stabilizer, but i read an article that said using to much of an additive can cause damage to the seals.
  9. bobafett
    bobafett F1 Veteran
    Sep 28, 2002
    9,193
    plenty of extremely well respected ferrari techs would disagree.
    --Dan
  10. parkerfe
    Sep 4, 2001
    12,887
    Cumming, Georgia
    Franklin E. Parker
    Wouldn't that give those techs more business?
  11. mgtr1990
    mgtr1990 Formula 3
    Mar 30, 2005
    1,580
    Naples Florida
    Martin Graham
    Same here the products been around a long time and seems to work.
  12. BigAl
    BigAl F1 Veteran
    Mar 17, 2002
    6,146
    TX
    GSgt Hartman
    ok...Oliver... :)
  13. Dave
    Dave F1 Rookie
    Apr 15, 2001
    2,722
    Little Rock
    David Jones
    I use snake oil!
  14. mark328
    mark328 Guest
    Jul 30, 2005
    664
    Mi
    Mark
    To each his own, but it is not something that i would do on a daily bases.....i have seen certain addititives dry out and crack rubber parts so a Ferrari tech who makes his living off repairing these cars may disagree
  15. sparky p-51
    sparky p-51 Formula 3
    Aug 8, 2004
    1,375
    klamath falls, Or.
    steve
    With every fill up I add 1 gal of aviation 100 lo lead and Marvel Mystery oil. The av gas makes the exhaust smell great. See what happends next year when Brian does yearly.
  16. BigAl
    BigAl F1 Veteran
    Mar 17, 2002
    6,146
    TX
    GSgt Hartman
    Heard the same thing....was gonna do that until the place that carried it here folded. Not sure (must be though) where else in town that carries it.
  17. Rachane
    Rachane Formula 3
    Sep 5, 2005
    1,086
    San Francisco, CA
    Rachane
  18. DN35
    DN35 Formula Junior
    611
    Illinois
    D. Norton
    Seafoam.
  19. don_xvi
    don_xvi F1 Rookie
    Nov 1, 2003
    2,934
    Outside Detroit
    Don the 16th
    I knew this discussion might get to one of my pet peeves and sure enough it did!
    Top Tier gas, while it sounds great from the guy from one of the companies behind it, also contains 10% Ethanol, which decreases your fuel economy by ~2.5% on a fuel injected car and will cost you power by leaning out your combustion on a carbuerated car (assuming it was optimally tuned before). In this case, C&D bought the line of the company hyping Top Tier hook line & sinker, as there was no mention of walnut shell blasting to clean up intake valves. I've seen intake valve deposits in late model production engines, but not stuck valves.
    Skip the Top Tier. Use Amoco/BP or Mobil if you can't stand the thought of putting generic gas into your fancy car. Dump in some Techron or Redline once a year if you insist. But... that's just my opinion.
  20. alert1
    alert1 Karting
    Mar 17, 2005
    104
  21. Gary48
    Gary48 Guest
    Dec 30, 2003
    940
    Years ago Hot Rod Magazine published data from a test of STP gas treatment done on a Taxi fleet with and without treatment and then torn down to see. The results made a believer out of me. Untreated, full carbon build-up on the backs of valves and combustion chambers and tops of pistons. Treated motors were very clean. Whats not to understand? Running your motor all out most of the time will not clean out the carbon. I prefer an additive that contains upper cyl. lube with every tank and experiance motors that run very clean and seldom if ever need a tune-up.
  22. BigAl
    BigAl F1 Veteran
    Mar 17, 2002
    6,146
    TX
    GSgt Hartman
    heard of it, never tried it. people who use it swear by it.
    yeah. decided to try in my truck, not impressed. Saw better results with Militec, at least for oil additives.
  23. bpu699
    bpu699 F1 World Champ
    Dec 9, 2003
    17,704
    wisconsin/chicago
    bo
    Someone explain this to me. Lubes what??? Aren't the cams, bearings, etc. already doused with oil?
    Wouldn't adding oil to the gas effect the o2 sensor, catalytic converter, glaze the cylinder walls, foul plugs, etc?
  24. Gary48
    Gary48 Guest
    Dec 30, 2003
    940
    bpu699, the area of combustion, that is the top piston rings and the valve guides on a normally running engine in good condition will have its upper end or the parts that I've mentioned actually dried out from gasoline and heat of combustion, remember gasoline has few lubricating properties and hense needs a bit of some help. I have seen motors torn down that had very good and functioning oil rings and valve seals, the cylinders were so dry visually to the point that you could take your finger and wipe the area and not detect any lube at all on your fingers.
    Yes all other parts are lubricated internally by pure oil ,and valve seals and oil rings do their job by keeping the oil out of the combustion area until they wear significantly. This is normal. To postpone this wear, upper cylinder lube will garantee a longer more deposit free life.
