Best Gear Oil for a F1 575? | FerrariChat
Discussion in 'Technical Q&A' started by Auraraptor, Jan 3, 2022.
  1. Auraraptor
    Auraraptor F1 World Champ
    Sep 25, 2002
    13,218
    MO
    What is the current consensus on the best oil for the gearbox on the 575? I have seen recommendations from redline to Motul to Ravenol.
    It looks like Shell now makes a "Spirax S6" 75w90 GL-5 gear oil; I can't find their (I guess out of production?) S5 oil anywhere.
    I like Ravenol J1C1109 (75w90 full synthetic) in my TR...was going to lean the same unless consensus leans in another direction. Was planning on 11 bottles aka 11L.
  2. flash32
    flash32 F1 Veteran
    Aug 22, 2008
    5,674
    Central NJ
    Dominick
    Since the 575 doesn't have soft metals I would use Mobil 75w90 like I used in the 512 tr
    My indie uses shell s6 axrme
    Hope that helps
  3. Auraraptor
    Sep 25, 2002
    13,218
    MO
    Thanks! I have heard that oil that has too many low friction additives can result in the F1 system ‘pop’ out of gear when warm, hence the thread.
  4. tazandjan
    38,072
    575M synchros are brass.
  5. flash32
    flash32 F1 Veteran
    Aug 22, 2008
    5,674
    Central NJ
    Dominick
    If you were going ravenol ..i would use vsg which works great in f360 and f430 s
  6. flash32
    flash32 F1 Veteran
    Aug 22, 2008
    5,674
    Central NJ
    Dominick
    Ok then ravenol vsg it is
    Did they change from 550 ?
    I thought the 360 was the first with brass
  7. tazandjan
    38,072
    As far as I know, the last Ferrari with iron synchros was the F355. I believe all the 65 degree V12s use brass, but would have to ask Brian or one of the other experts.
  8. Auraraptor
    Sep 25, 2002
    13,218
    MO
    #8 Auraraptor, Jan 4, 2022
    Thanks Flash. I realized I typed the wrong fluid in the original post. The J1C1109 I was referencing is VSG.
    Have others used it without issue (smooth shifts, no chatter, no gear popout)?
    I posted in technical as I assume there is overlap between the 575, 612, and 599 in best fluid.
  9. flash32
    flash32 F1 Veteran
    Aug 22, 2008
    5,674
    Central NJ
    Dominick
    I know of at least two f430s that use it ..they have no issues
  10. Auraraptor
    Sep 25, 2002
    13,218
    MO
  11. flash32
    flash32 F1 Veteran
    Aug 22, 2008
    5,674
    Central NJ
    Dominick
    That is the capacity but you probably will get out 3.5 l ...after opening plugs ..let drain for an hour or more especially if cold ...
  12. windsock
    windsock Formula 3
    1,069
    I would also run the car with the wheels in the air for 1-2 minutes after filling. The oil pump operates off the output shaft on that box and we see a huge number of boxes damaged due to low oil levels causing gear pitting in the 4,5,6 gears. If it is full to proper level now our technicians drain into a container and ensure the same amount goes back in as another level of protection.
    of2worlds, f355spider and flash32 like this.
  13. AEHaas
    AEHaas Formula 3
    May 9, 2003
    1,461
    Osprey, Florida
    Ali E. Haas
    I bought a 575 manual new when they first came out. Second gear was very hard to acquire when the engine was not warmed up. After 200 miles I changed it to Red Line gear oil and the whole thing was much smoother. FNA offered to put in a brand new transmission. I refused as the situation was so much better (and the break-in period was early). 'Have used the RL gear oils in every exotic. I think others may chime in that Red Line makes great motor oils but perhaps the best gear oils. I feel the others are fine but if you want the best...
    Ali
    Island Guy and of2worlds like this.
