Best GoPro positions for track day | FerrariChat
Discussion in '458 Italia/488/F8' started by hanz, Jan 4, 2016.
  1. hanz
    hanz Karting Rossa Subscribed
    Dec 24, 2014
    112
    Going to be tracking my Speciale for the first time at the Yas Marina circuit in a couple of days and wanted some advice regarding the best positions to place 2 GoPro's?
  2. clar
    clar Formula Junior
    Mar 17, 2013
    297
    Singapore
    Clarence
    I placed 1 on the middle front part of the roof. Gives a very balanced view of the racing line.
  3. Entropy
    Entropy Formula 3 Owner
    Jul 10, 2008
    2,149
    One thing to consider, more and more tracks and/or organizing bodies are requiring external cameras to be hard-mounted (i.e. screwed on, bolted in, clamped on) or, if you're using a suction cup or adhesive-based mount, then it needs to be "wired" to the car (i.e. a tether, so if it comes loose, it somewhat stays connected to the car).
    As someone who has been hit by flying GoPros, and has a daughter who races karts that has been hit by a flying GoPro, I tend to agree with the rule.
    In any case, if that rule is in place, it does limit your creativity with placement, or at least makes it more complex...
    how I've seen them mounted, am sure there are more...
    1) interior, between seats facing forward
    2) interior, below rear view mirror
    3) inside engine bay, mounted to bulkhead window (i.e. rear/engine shot)
    4) rear bumper near plate (exhaust view, or low rear) - wire inside engine bay
    5) on rear quarter window, facing forward or aft (shoulder view) -wire to air intake or interior
    6) driver door facing forward/aft (low side view) - wire inside door or around mirror
    7) low center front hood (wire under bonnet)
    8) low front radiator opening (wire into radiator grille)
    9) center top of roof (forward or aft facing), run wire to interior both ways
    if you are not required to tether the camera, I'd still consider it (so you don't lose one), and consider how you'd feel if your 458 took a rock-solid GoPro case into the bumper/bonnet at 100mph because someone didn't tether theirs.
    Am sure Carlo (458Trofeo) has suggestions on recording the best exhaust sound
  4. pride355
    pride355 Formula Junior
    Apr 16, 2006
    388
    Istanbul/Turkey
    MOT
  5. Voda
    Voda Formula 3
    Oct 10, 2013
    1,808
    Seattle
    Go to minute 2:18 in the video and you can see what happens to external mounting.... incredible video:
    [ame]http://www.youtube.com/watch?v=tK9LAdUpLtk[/ame]
    here's a pic from the video with the gopro torn away and in flight:
  6. hanz
    Dec 24, 2014
    112
    Thanks a lot for your help guys. I can imagine how mounting it on the outside could be dangerous if it falls off.
    Think ill def put one in the same position as Voda did and maybe one just below the rear view mirror looking out (getting the nose of the car included) or on the outside depending on the circuit regulations.
  7. DavidJames1
    DavidJames1 Formula 3
    Mar 6, 2010
    1,779
    Bangkok, Thailand
    What about using the front and rear tow hook mounts - a few companies do GoPro mounts for those.
