Best headers | FerrariChat
Best headers
Discussion in '360/430' started by collegeboy, Oct 24, 2022.
  1. collegeboy
    collegeboy Formula 3
    1,325
    Texas and Kaua’i
    Mikey
    The pre cats are bad on a CS I am looking at. I know those are issues on these cars anyways so I would want to replace the stock headers with pre cats. Is there any brand that is considered the "best"? I know of Fabspeed and Super Sprint and have heard that either one of those are the "best" from multiple people. I will be keeping the stock main cats and only replacing the headers, and I will need the air injection rails since it has that. Thanks for the advice.
  2. 360trev
    360trev F1 Rookie
    Project Master
    Oct 29, 2005
    4,319
    Gibraltar
    360trev
    1 vote for supersprint... [emoji106]
    clean512 likes this.
  3. clean512
    clean512 Formula 3
    Feb 4, 2010
    2,081
    Josh @jtcarprojects
  4. collegeboy
    1,325
    Texas and Kaua’i
    Mikey
    Thanks. They don't seem to have the air injection rails that I need.
  5. clean512
    clean512 Formula 3
    Feb 4, 2010
    2,081
    Josh @jtcarprojects
    I'm sure trev can delete that on the tune.
  6. priericky128
    priericky128 Formula Junior
    619
    St. Louis MO
    Rick
    You can get euro headers with air rails. I like mine.
  7. DBomb117
    DBomb117 Formula Junior
    Jun 20, 2019
    326
    Connecticut
    Dimitriy
    How did you get euro headers with air rails? I looking to do headers on my car (USA spec) was considering euros and deleting air-injection through a tune but if I can just keep the air injection it would be easier for emissions.
  8. priericky128
    619
    St. Louis MO
    Rick
  9. priericky128
    619
    St. Louis MO
    Rick
    I found a set on fchat. They can be identified visually if my understanding is correct. The air rail is long with the opening at the back rather than the side. No precats either.
  10. clean512
    clean512 Formula 3
    Feb 4, 2010
    2,081
    Josh @jtcarprojects
  11. 360trev
    360trev F1 Rookie
    Project Master
    Oct 29, 2005
    4,319
    Gibraltar
    360trev
    Supersprint headers are equal length with F1 merge collectors and proper bench flowed mandrel bends and high quality welds. They are the real deal and perfectly complementary to my calibration work.. [emoji91][emoji41][emoji106]
    Sent from my CPH2145 using Tapatalk
    cavlino and clean512 like this.
  12. DBomb117
    Jun 20, 2019
    326
    Connecticut
    Dimitriy
    Trev do you have any experience with US emission programming in the 360 ecus? Is it possible to turn off the reading of secondary (cat) 02 sensors, while leaving "readiness" on? I was able to do something similar in my Mitsubishis in years past where the secondary 02s were just "off" but the monitor for those 02s showed "ready" (in effect it was not looking for readings from those secondary 02s). I live in the state of CT, as long as the car does not throw a check engine light, shows most of the readiness monitors as ready, and passes visual for a main cat it passes "emissions inspection".
  13. DBomb117
    Jun 20, 2019
    326
    Connecticut
    Dimitriy
    I did not realize there were 2 versions of the euro header. I just thought there was the one without the air rail. Was it something they introduced in later years?
  14. 360trev
    360trev F1 Rookie
    Project Master
    Oct 29, 2005
    4,319
    Gibraltar
    360trev
    Pm me
  15. RedNeck
    RedNeck F1 World Champ
    12,013
    The CSA
    Me
    Surprised nobody has brought this up yet, but I'd be a bit leery of buying a car with "bad" precats, as it's common for the pieces to find their way into combustion chambers, causing damage. Have you gotten a compression test on that motor yet?
    RANDY6005 likes this.
  16. 650kid
    650kid Karting
    121
    Barrett F
    Love the Tubi headers on my CS
  17. priericky128
    619
    St. Louis MO
    Rick
    Yeah I think so but i don’t know the date. I think some early A vins also don’t have air rails either but not 100% sure on that.
  18. sierra055
    sierra055 Formula Junior
    359
    Melbourne, AU
    Marshall
    I've got a set of Larini headers and cats here waiting to be installed. With the inconel shielding, they look stunning notwithstanding any performance and heat improvement!
  19. modificator
    modificator Formula Junior
    431
    Florida
    George
    Should the headers be wrapped into a tape or put into a blanket or left alone or have other shields added?
    Blankets are not very pretty, wrap can be made to look nicer. Both block the heat from getting into the engine bay (good), but also result in much higher rates of header shrinking and expansion potentially leading to cracks over time (bad).
    Uncovered headers look best, but emit much more heat.
    What's the best option for average street driving?
  20. sierra055
    359
    Melbourne, AU
    Marshall
    I agree, blankets don't look great and i've seen bad things happen with tape. That was one of the reason I went with the Larini cats and headers as they are inconel shielded, so no extra shielding needed. The 360 (and 430 I believe) is known to melt handbrake cables on headers without heat protection
  21. one4torque
    one4torque F1 Veteran
    5,592
    Houston
    One4torque
    I’ve been running fabspeed blankets for 2 yrs now w no I’ll effects.
    Ive used header wrap for years w no issues. It needs to be installed properly.
  22. GogglesPisano
    GogglesPisano F1 Rookie
    2,991
    East Bay, California
    Joe
    have you heard of Header Shield? They custom cover any header is an OEM style heat shield. I hope the owner of these doesn’t mind, but I snagged this photo on Facebook because they were so beautiful. I think they’re supersprint and sent to header shield for the covering process.
    cavlino and modificator like this.
  23. clean512
    clean512 Formula 3
    Feb 4, 2010
    2,081
    Josh @jtcarprojects
    Those are mine. Not at all. Love sharing the passion and growing the knowledge out there.
  24. ttforcefed
    ttforcefed F1 World Champ
    19,219
    i have larini inconel on my scud...they look like a work of art.
  25. modificator
    431
    Florida
    George
    Header Shield looks beautiful for those who already have (naked) headers to cover, thanks for sharing!
