best high temperature exhaust bypass valve sealer? | FerrariChat
Discussion in '348/355' started by hjp, Oct 20, 2015.
  1. hjp
    hjp Formula Junior
    Feb 23, 2013
    591
    Kansas City, Mo.
    Jerry Peterson
    I am replacing the two SS O rings on each side of my 355's bypass valve. A Ferrari tech suggested a thin film of sealer be applied around the rings to help ensure they don't leak. I'm guessing some sort of high temperature silicone would be appropriate. What have you guys used? What temperature limit do you think this stuff needs to be?
  2. Eric C
    Eric C F1 World Champ
    11,136
    St. Louis, MO
    Eric
    I've never added any sealant around those rings.
  3. Rifledriver
    37,288
    A Ferrari mechanic suggested that?
    I really don't think so but if true you now know one to not take your car to.
  4. Rifledriver
    37,288
    No one with half a brain has.
  5. hjp
    hjp Formula Junior
    Feb 23, 2013
    591
    Kansas City, Mo.
    Jerry Peterson
    Why? What is wrong with a small amount of a high quality sealer. I'm not arguing, just asking to understand the downside.
  6. phrogs
    phrogs F1 Veteran
    7,357
    Kzoo Michigan
    Becuase you shouldn't need to use a band aid to make it seal.
    It should seal without sealant if it doesn't you have other problems, Douching it with some silicone won't fix it.
    I mean what does he use to weld parts with?? JB weld?
  7. lotusk
    lotusk Formula 3
    Nov 3, 2003
    1,840
    London UK
    He is no "tech"
    Do it right.
    The parts fit if fitted right.
    No bodge job
  8. gothspeed
    gothspeed F1 World Champ
    May 26, 2006
    10,244
    U.S.A.
    goth
    If exhaust components are not sealing or seating flush on their interfaces, then they need to be loosened and realigned. If they still do not seal up, then the suspect part(s) need to be corrected on a bench.
    Many exhaust parts including factory are not very straight or square. Maybe they were ok when new .... but after many heat cycles and deformation prone tubing .... this leak does not surprise ... :eek:
