Best lighting for a detailing area? | FerrariChat
Discussion in 'Detailing & Showroom' started by Ak Jim, Dec 21, 2016.
  1. Ak Jim
    Ak Jim F1 Veteran
    9,615
    North Pole AK
    Part of my garage addition is an area 15'x28' with 8' ceiling. I installed 20 6" diameter recessed can lights. Basically four rows of five lights and the lights are pretty much evenly spaced. I'm planning on using LED inserts in the cans. I'm thinking 900 lumens per light but am not sure of the best temperature lights to go with. I'm thinking 4000 would be a good choice. Any of you guys have any comments on this set up?
  2. KM1959
    KM1959 Formula Junior
    Nov 12, 2014
    984
    Kevin
    LEDs are bright but I've found that nothing shows finish flaws more than flourescent lighting.
  3. Caeruleus11
    Caeruleus11 F1 World Champ
    11,606
    Great question. I'd love to hear what the experts chime in with. Based on my experience, I agree with Kevin above, fluorescent lighting is the best I've found to highlight flaws, its pretty unforgiving.
  4. Dave rocks
    Dave rocks F1 World Champ
    16,047
    Orchard Park, NY
    Dave Lelonek
    #4 Dave rocks, Dec 21, 2016
  5. Ak Jim
    Ak Jim F1 Veteran
    9,615
    North Pole AK
    #5 Ak Jim, Dec 21, 2016
    I was looking at the four tube T5HO lights at Home Depot, 17900 lumens per fixture!
    I have heard that the fluorescents are good but because the ceiling is only 8' in this area I didn't want lights hanging down.
  6. Dave rocks
    16,047
    Orchard Park, NY
    Dave Lelonek
    The T5's are considered hi bay light but I even use them in our shop at benches and such. In my garage they are mounted to the ceiling - no need to hang them.
  7. Kevin Rev'n
    Kevin Rev'n Two Time F1 World Champ
    Nov 29, 2009
    24,489
    Honolulu
    Kevin
  8. cls
    cls Formula 3
    Jun 12, 2007
    1,663
    Los Angeles/Montreal
    Chris
    I put cool temp LEDs in my garage replacing existing fluorescents. I tried the warm LEDs and found the cools were better for detailing. That said, fluorescents show certain flaws well (especially waviness in panels) and LEDs show certain flaws well (like scratches) Both types of lights seem to require different angles to show the same flaws and neither one shows everything - for that you need the full sun. It's a matter of getting good, full, bright lighting and then getting to know what you're seeing and missing and adjusting your sight angle as well as knowing what might be missed regardless. Move the car outside periodically until you're confident in your setup.
  9. JaguarXJ6
    JaguarXJ6 F1 Veteran
    Feb 12, 2003
    5,533
    Black Hawk, CO
    Sunny
    Sunlight and fluorescent. The former highlights surface scratches and spider webbing, the latter deeper scratches and marring.
    Click on My Garage, click on 1993.5 Supra Turbo, look at the first four photos. If it's flawless in the sun.. then you're done.
    Edit: A sodium outdoor light may actually provide the right type of light but I haven't experimented with one.
  10. INTMD8
    INTMD8 F1 Veteran
    Jun 10, 2007
    6,753
    Lake Villa IL
    I have Lithonia ZL1N led fixtures, 4000 color temperature. They are perfect to me. Nice white light.
    Also have the same fixtures but 3500 color temperature over the tool box and benches, the color is noticeably more yellow. (I prefer the look of the 4000)
  11. JoshVette
    JoshVette Formula Junior
    Aug 12, 2007
    708
    Grand Prairie/Dallas
    Josh
    Tube light will show you some flaws if it's bright enough but not all the flaws very well.
    Lights that spread out light such as tube lights are good for lighting up the area but if you really want to see all the swirls and flaws best you need focused light such as you'd find with an LED flashlight.
    Personally I'd use tube lights to light up the garage and then to find flaws turn all the lights off and use a bright LED flashlight and look up and down side to side on each panel to see it all. This is exactly what I do when I'm working on clients cars to polish out swirls.
    Josh
  12. Ak Jim
    Ak Jim F1 Veteran
    9,615
    North Pole AK
    Thanks for all of the suggestions. I'll post some pictures when it's complete.
  13. Envious Eric
    Envious Eric Karting
    Sep 21, 2009
    238
    Orange County, CA
    Eric
    I'm with Josh on this one.
    Fluorescents are not ideal for paint correction. You cant see the small stuff that you would see outside in the sun.
    And the sun is not the end all checker. LED flashlights are the way to go when doing correction work. We typically turn off all the shop lights and correct the car with LED on a stand, and LED flashlight in hand! Sometimes, I think it makes us overproduce and blow past the desired end result for the client (I guess that's a good thing). Many times its not good enough for me with the LED, but looks 100% perfect outside under the sun.
  14. ClydeM
    ClydeM F1 World Champ
    11,877
    Wayne, NJ
    Clyde E. McMurdy
    I suppose its a matter of their primary purpose.
    Florescent is fine for general lighting & you can buy a hand held halogen or a couple tripod halogen for those few times you will be detailing
  15. FiveLiterEater96
    FiveLiterEater96 Formula 3
    Nov 5, 2005
    1,858
    Illinois
    Andrew
    How many 355's does one need?! :D
  16. ClydeM
    11,877
    Wayne, NJ
    Clyde E. McMurdy
    I can think of 5
    GTS, GTB, Spyder, Fiorano & Challenge. Variety is the spice of life :)
  17. Dave rocks
    16,047
    Orchard Park, NY
    Dave Lelonek
    I had 3 but I'm down to 2 now. One is a full restoration project. I could easily hit 3 again if a deal comes my way :D
  18. FiveLiterEater96
    Nov 5, 2005
    1,858
    Illinois
    Andrew
    Thats awesome. Enjoy!
