Best locations for putting a Dino up on jack stands | FerrariChat
Discussion in '206/246' started by HMB-Dino, Dec 21, 2010.
  1. HMB-Dino
    HMB-Dino Formula 3
    2,280
    Pebble Beach, CA
    RonG
    I plan to start some weekend inspection and touchup under the car during the winter rainy season, so I want to put the car up on 4 jack stands I've purchased. What is the safest locations on the underbody for jack stand placement? Since I'll be under the car, I'd like to focus on the work rather than constantly worry about being crushed because I guessed wrong on jack stand placement. By the way, the jack stand manufacturer (Hein-Werner...3-ton stands) says never put a car up on 4 jack stands...???
    Suggestions and especially photos of the correct locations would be much appreciated.
  2. UroTrash
    Jan 20, 2004
    40,470
    Purgatory
    Clifford Gunboat
    I'm no expert, but those tubes are soft.
    After my first jack up, i stared using a nice big piece of oak on top of the jack to spread the load.
  3. abstamaria
    abstamaria F1 Rookie
    Feb 11, 2006
    2,668
    Andres
    "By the way, the jack stand manufacturer (Hein-Werner...3-ton stands) says never put a car up on 4 jack stands...???"
    I always do that and see so many others do that, too. It's probably more the instability, rather than stand failure, that is the issue.
    Omgjon's restoration photos showed where the major chassis tubes are and how he lifted his car, so that is where place jack stands under.
    Andres
  4. daviekj
    daviekj Formula Junior
    486
    HMB-Dino,
    There are some photos about half way down this thread.
    http://www.ferrarichat.com/forum/showthread.php?t=226569
    The rear is fairly straight forward, particularly if you have "V" shaped stand cups to snuggly catch the "U" shaped chassis section. If there is any concern it is that the two stands are quite close together and not distributed widely across the width of car. However, I think this is more illusionary rather an actual problem.
    There is no natural anchor point for the stands on the front unless you first remove the fibre glass panel below the steering system. To do that you really need the car on stands, so its a bit of a catch 22. Anchoring the stand cups under the front suspension "A" frame is not ideal as these are not solid to the chassis. (as I did in the photos in the above path). If you can probably best to remove the fibre glass panel and anchor the stands to the "U" chassis as on the rear.
    With the car on all four sturdy stands, I felt reasonably comfortable getting under the back end. However, take great care to get the stands flat on the ground and symmetrically positioned.
    Kevin
  5. HMB-Dino
    HMB-Dino Formula 3
    2,280
    Pebble Beach, CA
    RonG
    #5 HMB-Dino, Dec 22, 2010
    My 71 Euro appears to have a very large single piece fiberglass belly pan (with 2 small rectangular access panels), but at quick glance, the pan seems to be riveted on. So removing it would be problematic, not to mention the difficulty maneuvering it back into place when done (while lying on my back just inches away from it...jack stands will lift a max of 19 inches).
    Also, the jack stands have a relatively flat cradle which I thought would be better for a larger set of positioning options (see pic). I will only be using the stands in the garage, on a very flat smooth concrete floor.
  6. Pantdino
    Pantdino Formula 3
    Jan 13, 2004
    2,069
    Jim
    My car has not had the forward-most fiberglass undertray in the 23 years I've had it and I put jack stands under the chassis tubes front and rear.
    I'm surprised you don't ask about how to lift the car to put it on the stands.
    It's not necessarily easy-- if you lift one end to full stand height all in one go you won't be able to get the jack under the chassis on the other end.
    I prefer to just lift one end of the car at a time unless I REALLY need to have the whole thing in the air-- more stable and easier to do.
  7. HMB-Dino
    HMB-Dino Formula 3
    2,280
    Pebble Beach, CA
    RonG
    #7 HMB-Dino, Dec 23, 2010
    There may be a better way, but I figure I'll raise one corner half way, place a jack stand, then do the other side, place a jack stand, then do same for the other two corners. Then go around again increasing to full height. That way no one corner will be drastically heigher than any other corner. By the way, the 3-ton jack I bought has a min height of 3.5" and a max of 21". That allows me to use it for my Porsche Cayman too (4" ground clearance).
    Do you have a better suggestion to get car up on on 4 jack stands at max height, which for my stands is 19"?
    But I'll likely only raise one end if that serves my needs, and jack up all 4 corners only if necessary.
  8. daviekj
    486
    #8 daviekj, Dec 23, 2010
    Yes. Do each corner in stages, not full height in one go as too unstable and as above, difficult to get trolley jack under the corner not lifted.
    My comment about the fibre glass under tray were for the front panel below the steering area only (about 2ft x 2ft see photo) and not the fully under belly panel which is riveted to the chassis rails.
    Kevin
  9. abstamaria
    Feb 11, 2006
    2,668
    Andres
    What about the diagonal frame members just behind the stands in the picture above? They are farther apart. I think Omgjon was lifting his car on those points, albeit with a 2-post lift.
  10. 2NA
    2NA F1 World Champ
    Dec 29, 2006
    18,221
    Twin Cities
    Tim Keseluk
    #10 2NA, Dec 23, 2010
    The Dino has a pretty robust frame (those diagonals behind the front wheels are part of it). If you are careful there is no problem lifting and supporting the car there.
    I always use wood blocks on jacks and jackstands (and frequently on my lift) to protect the car and distribute the load a little better.
  11. HMB-Dino
    HMB-Dino Formula 3
    2,280
    Pebble Beach, CA
    RonG
    I have a hard rubber pad for my jack and cut pieces of 3/4 inch plywood to put between the jack stand and the frame. I recall seeing someone else using that approach for the very reason you mention.
  12. daviekj
    486
    Good structural and balance place, however, the main belly fibre glass panel is there which prevents the use of "V" or cupped shaped supports. Good place to put the trolley jack arm though.
  13. mikeyr
    mikeyr Formula 3
    Jun 17, 2004
    2,154
    Santa Barbara, CA.
    Mike Rambour
    before I got my lifts (yes 2 plural) I would place my car on all 4 stands and then take the wheels off and place them under the car. Kind of pain having to move them around when working under the car but if a stand does fail the car wheel/tire will save you.
    Good safety practice to get into of putting the wheels under the car.
