Best radar detection system. | FerrariChat
Discussion in 'Ferrari Discussion (not model specific)' started by Jkee, Dec 11, 2003.
  1. Jkee
    Jkee Rookie
    Oct 24, 2003
    16
    Gentlemen I need your input and recommendation on purchasing a radar detection system for my 1990 TR.
  3. Schatten
    Schatten F1 World Champ
    11,237
    Austin, TX
    Randy
  4. BWS550
    BWS550 Wants to be a mod
    Apr 1, 2002
    8,933
    NEW JERSEY
    BRUCE WELLINGTON
  5. Entelechy
    Entelechy Formula Junior
    May 19, 2001
    712
    Los Angeles
    Chris Cummings
    Just bought a fellow F-chatter's Valentine One and couldn't be happier - definitely the way to go.
  6. Doody
    Doody F1 Veteran
    Nov 16, 2001
    6,099
    MA USA
    Mr. Doody
    V1
    you can spend less, but you won't get as much.
    you can spend more, but you won't really get more.
    the only beef i have with the V1 is that they haven't made any effort to make a stealth install version. i've heard of shops that split them open and do it like a K40, but valentine does not. maybe there's some patent issue or whatnot, but i think it's real money on the table they've left - and it annoys me :).
    that said, i have mounts, power leads, and remote displays in my cars, so i just move the little unit from car to car. it's great. the unit is bulletproof. "it just works".
    and once you go arrows, you can never go back.
    doody.
    PS: and don't buy the K40 marketing crapola. unless they're willing to pay the points on your license for seven years (or however long they stick on your record in your state) their guarantee isn't worth SQUAT.
  8. enjoythemusic
    enjoythemusic F1 World Champ
    Apr 20, 2002
    10,676
    Worldwide
    Steven
    Valentine One
  9. ferraridriver
    ferraridriver F1 Rookie
    Aug 8, 2002
    4,125
    Bay Area Calif.
    Dave
  10. VS1
    VS1 Karting
    Oct 16, 2002
    197
    Beavercreek, OH
    Vishal Soin
    Another V1 vote. Althought I really don't think you needed another one.
  11. f355spider
    f355spider F1 World Champ
    17,682
    Check archives...it will overwhelmingly be V-1.
  13. wazza
    wazza Formula Junior
    Oct 9, 2003
    614
    The vote from the UK is
    Valentine One
  14. up2nogd
    up2nogd Karting
    Aug 6, 2002
    178
    I asked the same question about 1 year ago -- overwhelming response
    for the V-1!! I bought one and as Doody put it - when you go with the arrows you just can't go back! My wife now has the passport I bought before the V-1. Don't give it any more thought - Buy the V-1
    JJ
  15. TCM
    TCM Formula Junior
    Nov 10, 2003
    552
    Tyngsborough, MA
    V1 here as well. The first time it saves you it pays for itself. And it will save you a lot!
  16. Mitch Alsup
    Mitch Alsup F1 Veteran
    Nov 4, 2003
    8,543
    The only thing V1 needs is "look down shoot down" capabilities
    <Whoops wrong forum>
  17. mw575
    mw575 F1 Rookie
    May 30, 2001
    2,924
    Lake Oswego,Or
    Martin J Weiner,M.D.
    V1 hands down.
  18. jordan747_400
    jordan747_400 F1 Veteran
    Dec 9, 2002
    6,928
    Houston, TX
    Jordan
    LOL!
  19. spyderman
    spyderman Formula 3
    Nov 4, 2003
    1,556
    Toronto - Canada
    Spyderman
    From what I have read the Valentine 1 is the best on the market for detecting radars but in a lot of areas in North America the police are now using laser :( I understand that Valentine is also good in detecting laser, but, when it does it is generally to late for the driver because the laser gun is instanly picking up your speed as the detector is picking up the laser gun. What Valentine needs is a laser deflector of some sort, as the lastest Escort has, to give the driver those presious few seconds to slow down. I wonder if Valentine is working on something like this?
  20. M.James
    M.James F1 Rookie
    Jun 6, 2003
    2,721
    Worcester, MA
    Michael.C.James
    Don't take anyone's word for it...get the facts from independent testers. The following website should help out: http://www.speedzones.com/
  21. Ferrari
    Ferrari Karting
    Nov 2, 2003
    205
    Found this on the V-1 site . . . See the site for the full report.
    http://www.valentineone.com/laserhowto/
    If one's objective is never to miss a laser encounter, I recommend mounting the detector as close to the typical laser aiming points as possible. Here in the US, most laser operators aim at the front license plate since it is usually made with a special reflective treatment to aid night-time visibility (works great for laser visibility too, day or night). If there's no front plate (some states don't require one), then a headlamp cluster or piece of bright grillwork is the next most promising aiming point.
    Advanced warnings (a warning in time to do some good) are more likely if one can avoid some problems caused by the low mounting position. Advance warnings require the greatest possibility of receiving a weak fragment of the beam while it is being used on traffic a good distance ahead. To maximize reception of weak signals, one must reduce blockage and interference.
    Mounting high on the windshield will position the detector to "see" through the windows of most vehicles ahead. Glass in vehicles ahead is a good thing for your detector to see; it can scatter reflections in your direction. Sometimes it develops a glow, or a bloom, when the beam strikes, giving yet another chance for advanced warning.
    Mounting high on the windshield reduces the effect of sunlight reflected from the hood, which increases the detector's ability to find weak beam fragments. Daytime warning sensitivity is completely dominated by how one manages the sunlight issues.
    Mounting high behind the tint band may reduce the laser signal somewhat, but it reduces the sunlight contamination by the same amount. The result is an unchanged laser-to-sunlight ratio from the scene beyond your vehicle, but with reduced hood reflections owing to a higher vantage point—a net gain. Only in the dead of night would a just-below-the-tint-band mounting position be beneficial.
    The downside of high mounting is the move away from the most common aiming points. This means that in bright sunlight, you may miss the occasional direct hit from very close range—no detection at all! But that's possible with a low mounting as well, just not as often.
    Now you know the variables, so you can make your own choice. To me, a warning too late is the same as no warning.
  22. Hubert888
    Hubert888 F1 Veteran
    5,376
    Manhattan &amp; LA
    Hubert
    Has anyone ever received a speeding ticket while using the V1?
  23. notoboy
    notoboy F1 Rookie
    Jul 8, 2003
    2,531
    NYC
    David
    V1 hands down. It has saved my butt more times than I can tell you, and it's probably the only reason I still have a license.
    David
  24. Doody
    Doody F1 Veteran
    Nov 16, 2001
    6,099
    MA USA
    Mr. Doody
    of course. they aren't MAGIC :).
    instant-on radar of any sort will nab you. laser will nab you.
    there's no mystical energy involved in a V1.
    doody.
  25. GaryReed
    GaryReed F1 Rookie
    Feb 9, 2002
    3,102
    Seattle
    Gary
    Three Ferraris later... and my same V1 is still working great and has saved my butt on countless occassions.
    Thank you Mike Valentine!!
  26. Brianjonesphoto
    Brianjonesphoto Formula Junior
    Dec 2, 2003
    266
    Seattle Wa
    Brian Jones
    Well I'm going out on a limb here with my theory. I bought a Corbra 9870 off of ebay for $50 ($250 cheaper than top end models). I have never seen this detector in the top ranking of any test, but it is usually top 3-5. The way I look at it I saved $250 and am still pretty likely to not get a ticket. And if I do I have $250 in my pocket to pay for it. :)
  27. shelbee
    shelbee Guest
    With one thing why don't they make V1 wireless or baterry operated??
  28. Tyler
    Tyler F1 Rookie
    Dec 19, 2001
    4,274
    dusty old farm town
    Tyler
    V1, no question!
