Best resources for learning how to tune Webers? | FerrariChat
Discussion in 'Technical Q&A' started by nathandarby67, Jan 31, 2016.
  1. nathandarby67
    nathandarby67 F1 Veteran
    Feb 1, 2005
    8,349
    Mississippi
    Nathan
    #1 nathandarby67, Jan 31, 2016
    I just bought this little beauty, a 1974 Alfa Spider. The previous owner did a complete restoration including engine rebuild about 2000 miles ago, and the original SPICA injection was swapped to Weber DCOE's. The car runs good, but to my ear sounds and feels like it's perhaps a tad rich. Also just on general principal I go through and fully service and tune up any car when I first buy it, I want to make sure it's honed razor sharp!
    As a car guy, I am somewhat embarrassed to admit these are my first Webers. I can tune SU's with my eyes closed, but obviously that isn't going to help me much here. What are some good references for learning about Webers? I ordered the Braden book on Webers, but are there any other good resources you'd suggest for a Weber virgin like me?
  2. nathandarby67
    Feb 1, 2005
    8,349
    Mississippi
    Nathan
  3. Steve Magnusson
    26,932
    #3 Steve Magnusson, Jan 31, 2016
  4. miketuason
    miketuason F1 World Champ
    Feb 24, 2006
    15,832
    Cerritos, CA.
  5. Streetsurfer
    Streetsurfer Formula Junior
    Dec 16, 2015
    934
    near Chicago
    Ron
    Probably nothing new to you guys, but the Ducati Paso, Cagiva Elephant, and 750 Sport (I think all three, and maybe others) used the 44DCNF on it. Ducatipaso.org also has good resources listed for parts and tuning, if any will carry over.
    I checked this Braden book out a couple times from local library while my bike was in service. Never had to do much beside clean my carb after a few years of sitting. It came dialed in pretty good on the LTD Edition.
  6. Kevin Rev'n
    Kevin Rev'n Two Time F1 World Champ
    Nov 29, 2009
    24,675
    Honolulu
    Kevin
    Look at all those screws!!!!!! Sweet car.
  7. jmaienza
    jmaienza Formula Junior
    Jan 8, 2009
    629
    Massachusetts
    Joe
    Good explanation about how Webers work. Many additional tuning tips on subsequent pages from this site.
    Performance Oriented
  8. BJJ
    BJJ Formula 3
    1,301
    #9 BJJ, Feb 1, 2016
    This is my "bible" and very valuable, since it also lists any and all jet sizes etc. for essentially all 60s and 70s cars, which had Webers fitted by the factory or aftermarket.
    Aside this, tuning really is simple. In almost all cases, where I had the carbs off and in parts (for cleaning and checking), the base settings (idle and mixture) were near perfect with just a minor need of adjustment (the main work being getting the levers for 6 cars well synchronized and free from backlash). Base settings as indicated in the Haynes book.
    Nice Alfa! Since they never were provided with Webers by the factory (as to my knowledge), the only things going wrong might be wrong jets, emulsion pipe, etc., or wrong lift of the accelerator pump. And do not forget to check the needle valve size, but it is presumably 1.50 (standard in the 151, I believe) and this should be sufficient for your car.
    By the way, in yours the choke cable seems to be missing ;).
    Cheers, Bernhard
  9. 2NA
    2NA F1 World Champ
    Dec 29, 2006
    18,221
    Twin Cities
    Tim Keseluk
  10. North bay tech
    Apr 18, 2015
    22
    Fountain Hills, AZ
    Josh Bare
  11. Keith360
    Keith360 Formula Junior
    Feb 6, 2015
    570
    Santa Barbara County
    Keith Williams
  12. Keith360
    Feb 6, 2015
    570
    Keith Williams
  13. staatsof
    96,239
    Fuggetaboutitland
    Bob
    Count your blessings that there's only two of them and a relatively simple linkage.
    I'm convinced that Beelzebub himself designed the Lamborghini V12 linkage. :D
  14. BJJ
    BJJ Formula 3
    1,301
    #15 BJJ, Feb 3, 2016
    Nope, it was Diavolo Satana himself :D.
    You just need to check that all joints are without backlash, very simple .... :p :D.
    If you have disassembled the carbs and reassembled them with new leather covers on the bearings, then you might be tricked, because the return spring of the carb alone might not be sufficient to close the throttle completely, due to the (initially) stiff fit of the leather on the throttle shaft . If you adjust the linkages without taking close care of that, then you for sure will have fun ... :D
    P.S.: I definitely prefer the 6 DCOEs over the IDL40s (Miura, 4 x triple choke), because in case of the latter it may be very advisable to have a fire extinguisher nearby, if the car suffers misfires for whatever reason .... :D
  15. Martin308GTB
    Martin308GTB F1 Rookie
    Jan 22, 2003
    4,286
    Black Forest Germany
    Martin N.
  16. nathandarby67
    Feb 1, 2005
    8,349
    Mississippi
    Nathan
  17. BJJ
    BJJ Formula 3
    1,301
    Have fun! :D
    For checking that all the jets have the proper sizes for your car, according to the list in the left book, you must, however, dissassemble the carbs quite completely ...... :D
    Cheers, Bernhard
  18. Wade
    Mar 31, 2006
    32,793
    East Central, FL
    Wade O.
    #20 Wade, Feb 11, 2016
