Best Semi-Auto Shift Systems | FerrariChat
Discussion in 'Ferrari Discussion (not model specific)' started by goalsir, Mar 30, 2009.
  1. goalsir
    goalsir Karting
    Mar 28, 2009
    64
    Hi,
    I was just contemplating the best Semi-Auto Shift Systems.
    I got down to (mechanically) Ferrari's F1 system (of course), and Porsche's new PDK system. I think the new PDK will become a huge competitor for Ferrari. I feel before PDK there really was not anything to compare to the F1 system, BMW's SMG, Porsche's TipTronic-nothing special.
    One thing Ferrari got was the name "F1." IMO that is the ultimate name for this kind of system just because that is it's real origin-the F1 cars.
    Lastly, I do not know much about the Mercedes AMG-SPEEDSHIFT mechanically wise, but I feel they have the ultimate type of paddles and the ultimate placement of them. First, I feel having paddles are way better and more fun to use then say buttons on the steering wheel (PDK), but a con about Ferrari's F1 paddles is they're mounted on the Steering wheel column, hence when you turn the wheel it is harder to downshift or up shift as you hand moves away from the paddles. AMG-SPEEDSHIFT however has paddles mounted on the steering wheel so when you turn the wheel, they turn with you.
    What do you think is the best Semi-Auto Shift System mechanically wise?
    Also, if you have the knowledge, is AMG-SPEEDSHIFT a good system?
    -Ray
  2. AndyE430
    AndyE430 Rookie
    Jan 3, 2005
    12
    Atlanta, GA
    Andrew
    They're completely different systems. The Ferrari system is a single clutch, automated manual and the PDK is a dual-clutch pre-selector style similar to the Audi DSG/S-Tronic gearbox that has been out for years and the BMW DCT that was recently launched on the M3 and will be available on the 335i and Z4 sDrive35i.
    I believe the AMG speedshift is similar to the Aston system (and others) in being an automatic with a paddleshift to select pre-defined ratios. Most reviews suggest this gives a smoother shift, although IMO it's cheating a bit since it's still an automatic with a torque converter. So it's solving a deficit in new technology by using old technology.
    I think the new California has a double clutch gearbox, indicating that this is the way that the paddle-shift transmissions are heading as more and more are adopting this idea in place of normal automatic gearboxes.
    I agree though that paddles mounted to the wheels are better than those on the column or buttons, but I couldn't really say that AMG has the best ones (personally I preferred those in the M3 M-DCT to the C63 AMG, but I'm sure it varies by model). My preference is for two paddles, left = down, right = up attached to the steering wheel. This to me is an F1 style gearshift and ultimately that's the point of paddles, to emulate that driving ergonomics. The way that Porsche and the non-M BMW's have it arranged just seems strange to me.
  3. goalsir
    goalsir Karting
    Mar 28, 2009
    64
    I am totally aware of the differences between Porsche and Ferrari's gearboxes, I was just saying that when it comes to shift times and thrills, the F1 and PDK have proved to be very pleasing.
    Do you know if Ferrari is going to call their new double-clutch in the California something else (other then F1)?
    -Ray
  4. mousecatcher
    mousecatcher Formula 3
    Dec 18, 2007
    2,116
    san mateo, ca
    i don't know if semi-auto is the best terminology.
    there seems to be a consensus that DSG style gearboxes are the best. disadvantage is some added weight.
  5. Bullfighter
    Bullfighter Two Time F1 World Champ
    Jan 26, 2005
    22,607
    Gates Mills, Ohio
    Jon
    I have the DSG in my Audi TT. It works as advertised -- very smooth, much better than the 355 and 360 F1 systems. Haven't driven an F430 F1, so can't compare. In full automatic mode, it's not as smooth as a pure automatic, but very usable in traffic.
    I haven't driven the Porsche PDK yet, but have a Cayman PDK test drive scheduled in a couple of weeks when they have one to demo. I expect I won't like the buttons as much as the paddles Audi uses.
    "Semi-auto" is probably the right terminology -- these newer gearboxes manage the throttle for you during a shift, and they can be set to behave as traditional automatics.
  6. rcallahan
    rcallahan F1 Rookie
    Jul 15, 2002
    3,307
    Santa Barbara
    Bob Callahan
    I don't think you want to be up/down shifting while in a turn.
  7. goalsir
    goalsir Karting
    Mar 28, 2009
    64
    Really? I really would of thought that while you're turning you might want to downshift as you have to slow down.
    -Ray
  8. J. Salmon
    J. Salmon F1 Rookie
    4,367
    VA
    You don't want to have to slow down as you turn either.
  9. Irishman
    Irishman F1 Rookie
    Oct 13, 2005
    3,526
    Raleigh
    Kevin
    #9 Irishman, Mar 30, 2009
    These systems were designed for people with severe handicaps, which in most likelihood would be Americans.
  10. Bullfighter
    Jan 26, 2005
    22,607
    Gates Mills, Ohio
    Jon
    Yeah, like that Schumacher guy from wherever.
  11. The Ape
    The Ape Formula 3
    Feb 28, 2007
    1,793
    Los Angeles
    Ape
    +1
  12. WCH
    WCH F1 Veteran
    5,186
    IMO the F1 Superfast in the 612 OTO and especially the Scuderia is superb, seamless.
  13. Kds
    Kds F1 World Champ
    It also depends which AMG Speedshift transmisison you are talking about. They all use conventional torque converters except for the special MCT version in the SL63. It is a multi-clutch system with a wet clutch and 4 shifting modes with launch control. I've driven this car with this gearbox.......shift from 7th to 4th under full power and be prepared to use a neck brace for 2 weeks, as well as get your stomach unravelled from around your spine.
    The AMG SPEEDSHIFT MCT 7-speed sports transmission is an all-new, unique concept, available exclusively in the new Mercedes-Benz SL 63 AMG. It combines the best of two worlds: the sporty, direct and agile feedback of a manual transmission and the maximum convenience of an automatic transmission. Fitted with seven speeds, four drive modes, a double-declutching and Race Start function, the AMG SPEEDSHIFT MCT 7?speed sports transmission offers unprecedented versatility. MCT stands for Multi-Clutch Technology and only employs clutch elements to perform gearshifts.
    The high-tech transmission is designed for high torque and maximum revs up to 7200 rpm. It also comes with sufficient reserves even under the highest loads thanks to its high-performance oil cooling system. An all-new, sophisticated electronic transmission control unit fully controls and monitors all processes. A new two-stage torsion damper effectively eliminates vibrations. The AMG SPEEDSHIFT MCT 7-speed sports transmission has been developed jointly by Mercedes-AMG GmbH and Daimler AG, although it will be used exclusively in AMG high-performance vehicles. It is produced at the Mercedes-Benz Esslingen-Hedelfingen production facility, Europe’s largest manufacturer of planetary gear sets.
    Four drive modes for tailor-made driving pleasure.
    At the heart of the new AMG SPEEDSHIFT MCT 7-speed sports transmission lies the wet start-up clutch, which runs in an oil bath and replaces the previous torque converter. Thanks to its low rotational inertia, the transmission responds instantaneously and dynamically with no slip. Accelerator pedal movements trigger an instant traction response. Fitted with four drive modes: “C” (Comfort), “S” (Sport), “S+” (Sport plus) and “M” (Manual), the transmission provides gearshifting with no loss of tractive force and supports customised control strategies for maximum driving pleasure. In “C” mode the gearshifts are comfortable, coupled with a “soft” accelerator response set-up for outstandingly smooth power transfer. In “S” mode the engine and transmission interact with more "bite": the engine speed is allowed to reach a higher level in each gear; the downshifts also feel more spontaneous. The gearshifts are around 20 per cent faster than in “C” mode. Switching to “S+” mode cuts another 20 per cent off shift times, while “M” is the sportiest mode: here the AMG 6.3-litre V8 engine has even more bite, added to which the transmission shifts gear another 10 per cent faster – a reduction of 50 per cent compared with “C” mode. In “M” mode the gearshifts take just 100 milliseconds.
    Ultra-fast, spontaneous multiple downshifts are another forte of the new MCT sports transmission. For instance, kickdown lets you move straight from seventh down to fourth gear or from fifth to second. In the “S” (Sport), “S+” (Sport plus) and “M” (Manual) modes the automatic double-declutching function is active. Every manual or automatic downshift is accompanied by precisely metered double-declutching – from “S” through “S+” to “M” incrementally. And this not only adds to the driver's emotional experience: the virtually load-free downshift minimises load-change reactions, which pays dividends particularly when braking into a bend on the
    New AMG DRIVE UNIT with innovative Race Start function.
    The new AMG DRIVE UNIT is the central control unit for the AMG SPEEDSHIFT MCT 7-speed sports transmission and all driving dynamics functions. The driver can change gears either using the new AMG selector lever with its leather/carbon-fibre finish, or by nudging the AMG steering-wheel shift paddles. On the left next to the selector lever is the electronic rotary switch to select the four drive modes including activation of the new Race Start function. Underneath are three buttons for additional functions: the first controls the ESP function, the second the ABC suspension system. The third adorned with AMG lettering is used to store the selected transmission drive mode and the suspension set-up. Briefly pressing the AMG button brings up the configuration options, while holding down the button allows you to program the required set-ups.
    The Race Start function takes driving dynamics to an entirely new level: it enables the SL 63 AMG driver to call on maximum acceleration, while ensuring optimum traction of the driven wheels. While the vehicle is at a standstill, the driver needs to activate the ESPÒ sports function and press the brake pedal with their left foot. Having preselected the Race Start program using the rotary switch, a confirmation message comes up on the AMG central display. The driver then simply needs to confirm the Race Start function by pulling the “Up” shift paddle once, fully depressing the accelerator and taking their foot off the brakes. The optimum start-up engine speed is set fully automatically and the SL 63 AMG accelerates away in an instant – as an option even up to the top speed. The driver does not need to shift gear manually; the AMG transmission changes gear with lightning-fast shift times.
  14. goalsir
    goalsir Karting
    Mar 28, 2009
    64
    Sounds great!
    I feel they will eventually tie that into to all of their AMG cars. It sounds like a hell of a system and once it's released on all of the AMG models I feel it will be up there with F1 and PDK. I am surprised they did not make it exclusive to the SL65 considering it is the Flagship of SL range.
    I must admit on this Ferrari website Mercedes is my favorite manufacturer. I personally think they are the best mainly because they have every type of genre in top quality ranging from Maybachs to SLRs to SL65 Black series to the legendary S-Class, and on and on.
    For me:
    You'll notice Porsche and Ferrari are both second on my list because I have the same amount of love for them.
    1. Mercedes
    2. Ferrari
    2. Porsche
    -Ray
  15. ddemuro
    ddemuro Formula 3
    Nov 16, 2006
    2,129
    San Diego
    Doug
    I haven't driven a 612 OTO or a Scuderia, but I was surprised at how not seamless the shifting in the two 599s I drove was. I was expecting it to have no noticeable lag and not jerk at all, but there is lag and the car does jerk. Granted, it happens incredibly quickly, but still not perfectly. I imagine a dual-clutch setup would eliminate any such lag and jerking.
  16. mousecatcher
    Dec 18, 2007
    2,116
    san mateo, ca
    please note that the gearboxes in F1 cars are not at all like the F1 shifter/gearbox in a street car.
    and driving a race car is nothing like driving a street car. it's not just driving faster.
  17. mousecatcher
    Dec 18, 2007
    2,116
    san mateo, ca
    no way, you can get yourself into big trouble. you downshift in the straight part of the braking zone.
    upshift in a turn is ok ... depending on the turn.
  18. otaku
    otaku Formula 3
    Aug 12, 2005
    1,391
    Boise,Idaho
    Josh
    Not that I've used any that weren't in normal everday inexpensive cars but my favorite so far is definetly audi/vw's DSG (tried about 3-4 others) sadly do not own a car with one but test drives gave me a good idea as to what they were like to live with. Only had one owner complain of reliability
