Best spark plug for the 355? | Page 3 | FerrariChat
Discussion in '348/355' started by 355, Sep 6, 2008.
  1. ShineKen
    ShineKen Two Time F1 World Champ
    20,202
    Southern California
    Nostradamus
  2. ShineKen
    20,202
    Southern California
    Nostradamus
  3. ShineKen
    20,202
    Southern California
    Nostradamus
  4. ShineKen
    20,202
    Southern California
    Nostradamus
    John, we need you to take it above 6k to get any meaningful data ;)
    IvanRico likes this.
  5. johnk...
    johnk... F1 World Champ
    Jun 11, 2004
    11,299
    CT
    John Kreskovsky
    #55 johnk..., Feb 1, 2025
    You know, when I bought the car I had the major done with new guides.
    Look like this when the heads came off at 19k miles
    Looked like this before the heads went back on
    Put a borescope down the plug holes and took a look when I changed plugs and it looked pretty much like the 1st picture.
    As for the plugs, I probably should have changed the sooner. :rolleyes:
  6. Mitch Alsup
    Mitch Alsup F1 Veteran
    Nov 4, 2003
    9,774
    The 360 motor has greater mean effective pressure in the cylinder than the F355 motor in the difficult 2,500-3,000 RPM range.
  7. ShineKen
    20,202
    Southern California
    Nostradamus
    Are you saying plugs should be changed perhaps every 5k miles?
  8. johnk...
    Jun 11, 2004
    11,299
    CT
    John Kreskovsky
    Not necessarily. Just that 13k seems too long in retrospect, at least for my car. Recommendation is 20KM, 12.5k miles.
  9. Targatime
    Targatime Formula 3
    Feb 22, 2014
    1,472
    Los Angeles
    @JohnK ignoring the 12.5k mile service interval for plugs
  10. johnk...
    Jun 11, 2004
    11,299
    CT
    John Kreskovsky
    Ok, I went 13k miles. ;)
    I'm betting most of you guys haven't put 13k miles on your car. :rolleyes:
    IvanRico, jjtjr, MAD828 and 1 other person like this.
  11. MAD828
    MAD828 F1 Rookie
    Oct 8, 2011
    2,643
    Elliott Caras
    I have, and many of them above 6000 rpm :)
  12. johnk...
    Jun 11, 2004
    11,299
    CT
    John Kreskovsky
    LOL, I don't know what kind of roads many of you drive on but driving the country roads of New England, and staying at safe speeds, (notice I said safe, not legal), if I wanted to keep the RPM between 6k and red line I'd never get out of 2nd gear and would spend a lot of time in 1st.
  13. bobzdar
    bobzdar F1 Veteran
    Sep 22, 2008
    6,956
    Richmond
    Pete
    Exactly, 1st-3rd is all you need to have fun.
  14. ShineKen
    20,202
    Southern California
    Nostradamus
  15. ShineKen
    20,202
    Southern California
    Nostradamus
  16. johnk...
    Jun 11, 2004
    11,299
    CT
    John Kreskovsky
    Bother checking the owners manual?
    The '95 plugs were Champion RG4PHP which cross reference to both PMR7a and PMR8a
    The '97 manual says PMR7A
    The '99 manual says PMR7A
    Seems the 7a is obvious choice.
    ShineKen likes this.
  17. ShineKen
    20,202
    Southern California
    Nostradamus
    I’m too lazy to check the manual :). I just assume when others say they’ve checked the manual, they’ve checked it.
    RG4PHP has a heat range of 4. That’s pretty far off.
  18. johnk...
    Jun 11, 2004
    11,299
    CT
    John Kreskovsky
  19. ShineKen
    20,202
    Southern California
    Nostradamus
    Those suggestions are waaay too generalized. Perhaps they “fit” on the car, but the specs are different enough. RG4 has a heat range of 4 (hotter plug). PMR7 has a heat range of 7.
  20. bobzdar
    bobzdar F1 Veteran
    Sep 22, 2008
    6,956
    Richmond
    Pete
    Heat ranges aren't comparable across brands, unfortunately. So have to see what a Champion heat range of 4 lines up with in NGK. See the chart in the below link - Champion goes down for colder, NGK goes up. Champion 4 looks roughly the same as NGK 7, per the chart.
    https://www.imps4ever.info/tech/engine/sparking-plugs-spark-plugs/spark-plugs.html
    Rifledriver and ShineKen like this.
  21. INTMD8
    INTMD8 F1 Veteran
    Jun 10, 2007
    6,855
    Lake Villa IL
    That's what I use.
  22. ShineKen
    20,202
    Southern California
    Nostradamus
    Good point. Was unaware.
    That chart seems all over the place. I can’t tell if a Champion number goes hotter or colder with number going up or down, but Champion 4 does seem to correspond most with 7’s. I did see a 4 equate to a 6, but nothing close to an NGK 8.
  23. ShineKen
    20,202
    Southern California
    Nostradamus
    The 360 is also a Coil-On-Plug ignition system if that matters.
  24. johnk...
    Jun 11, 2004
    11,299
    CT
    John Kreskovsky
  25. ShineKen
    20,202
    Southern California
    Nostradamus
    O Reilly has the specs listed in error. It should be a platinum plug with a .028” gap (.7mm)
    https://www.sparkplugs.co.uk/champion-spark-plug-rg4php-oe122-t10-2?utm_source=chatgpt.com
