Best sparkplug for 250 outside plug motor? | FerrariChat
Discussion in 'Vintage (thru 365 GTC4)' started by AndruetBiche, Mar 16, 2015.
  1. AndruetBiche
    AndruetBiche Formula Junior
    Oct 7, 2006
    427
    Putting my car back on the road after a prolonged restoration. It's an outside plug 1961 128F with 9.4 comp, later bigger valves, split header, street SWB exhaust/SNAPS, hood scoop. Stock points (not electronic conversion)
    I drive in a large city and frequently sit in stop and go traffic. I read earlier about issues with projected NGK BP5ES or BP6ES with piston interference for 250s. I have a set of B5ES but would switch to a 6 if I plan on country/track use - what do you think?
  2. Smiles
    Smiles F1 World Champ
    Nov 20, 2003
    16,674
    Pittsburgh, PA
    Matt F
    I think you're on the right track.
    I used NGK BPR6ES plugs for my 4 litre 209 engined 330 2+2. But I think the heat range was right, and the plug never let me down.
    Start there and experiment.
    Good luck!
    Matt
  3. Bob Zambelli
    Bob Zambelli F1 Rookie
    3,661
    Manning, SC
    Robert G. Zambelli
    I have put many BP5ES in 250s and they're the absolute best plug I've ever used.
    The B5ES also work very well. The main difference is that the BP has a projected tip.
    Bob Z.
    The BP6 are fine for track use.
  4. AndruetBiche
    Oct 7, 2006
    427
    Bob should I try the projected tip version ?
  5. DWR46
    DWR46 Formula 3
    Honorary
    Jun 19, 2012
    2,047
    For a outside plug 250, use B6ES. The plugs do not hit the pistons, projected tip plugs can hit the outside wall of the spark plug well as they are screwed into the head, thus closing down the gap. This is most common on cars with chassis numbers in the 3000-6000 range. 330's are not affected by this issue, and not all 250 outside plug engines are either, just a series of cylinder heads that had some "core shift" when they were cast.
  6. John Vardanian
    John Vardanian F1 Rookie
    Jul 1, 2004
    3,080
    San Francisco Area
    John Vardanian
    My car was in the range that Dyke mentioned and sure enough, one of the plugs ended up with a collapsed electrode upon installation. After driving it a few miles like that intermittent backfire made me wise up to it.
    john
  7. Ed Niles
    Ed Niles Formula 3
    Honorary
    Sep 7, 2004
    2,493
    West Hills, CA
    Edwin K. Niles
    Just remember to "double-washer" them.
  8. AndruetBiche
    Oct 7, 2006
    427
    Double washer the non projected as well?
  9. DWR46
    DWR46 Formula 3
    Honorary
    Jun 19, 2012
    2,047
    No, no need to double washer the B6ES plugs. They clear the walls of the plug well. Ed is correct, in that in the past, people could sometimes make projected tip plugs work in these engines by adding a second washer to not let the plug go as deep into the well and sometimes not hitting the wall.
  10. AndruetBiche
    Oct 7, 2006
    427
    Thanks for the tips!
