Best tires | FerrariChat
Best tires
Discussion in 'FF/Lusso' started by babwine, Oct 11, 2021.
  1. babwine
    babwine Karting
    Nov 6, 2016
    159
    Boca Raton/Cape Cod
    Burt
    What tires are recommended for a GTC4 Lusso
  2. Georgemaser
    Georgemaser Karting
    Aug 7, 2014
    246
    Michigan
    Caeruleus11 and forstephan like this.
  3. 3POINT8
    3POINT8 F1 Veteran
    Jan 23, 2014
    5,291
    + michelin
  4. SeattleStew
    SeattleStew Formula 3
    1,019
    In the rain
    Stew
    Michelin pilot sport 4s
  5. Caeruleus11
    Caeruleus11 F1 World Champ
    11,629
    Agree 100% MPS4S
    Il Co-Pilota likes this.
  6. ANOpax
    ANOpax Formula 3
    Jul 1, 2015
    1,358
    The Netherlands
    I run MPS4S abs would echo all the recommendations above.
    However, I note that you’re in Boca Raton and that the average temperatures you get will be much higher than for me in Northern Europe or Georgemaser in Michigan or Seattlestew in Seattle.
    So on that basis, I’m going to go out on a limb and suggest that maybe tyre optimised for warmer weather like the Pirelli P Zero would be a better choice.
    Hopefully, our resident tyre expert IlCoPilota will be along to advise.
  7. gilly6993
    gilly6993 F1 Rookie
    Aug 20, 2009
    2,561
    Longmeadow, MA
    Eric
    I went with the OEM Pirellis. Mostly for the fact my dealer had them in stock and the car was there for service. No complaints
  8. Il Co-Pilota
    Il Co-Pilota F1 Veteran
    May 29, 2019
    6,023
    Hopefully some place nice.
    A.B
    The MPS4S will be fine in those temps. It will only be an issue on track, and who tracks a Lusso?
    There's no reason to choose the Pirelli, unless tramlining is something you like.
    Personally I think the 255/35R20 and 295/35R20 is the way to go. The Lusso likes the bigger front and they offer better rim protection too
  9. Bamsefar
    Bamsefar Formula Junior
    Nov 26, 2012
    524
    Hmm yes let me be clear here: Yes one do seem to need better protection... I had to avoid a cab the other day and well I did try to avoid the sidewalk, but touched it so light - and now I need to get the front right painted.... Damn cab driver...!
  10. 350MH83
    350MH83 Formula 3
    Jul 11, 2014
    1,181
    Denmark
    Max
    The first time I drove the 812 Superfast, it was on a cold February morning with the Pirellis. I almost s*** myself at how twitchy it was, I thought it was just so dangerous in anything more than Sport. I drove the 812 again on a cold morning (but in May, so not as cold) but with the Michelin. The car was totally different, much more progressive, and I thought it was very easy to judge when you are on the limit.
    Caeruleus11 and Vegas CS like this.
  11. Bamsefar
    Nov 26, 2012
    524
    Hmm might need new front tires, just removed my wheels for the winter ones (yes a bit sad in a way, but hey it got 4wd - it can not be better than this during winter)...
  12. colonels
    colonels Formula Junior
    Aug 5, 2011
    877
    I'm researching Michelin pilot sport 4 all season instead of summer. They come standard on the C8 corvette.
    Lateral grip 1g whereas a summer tire would get 1.3g but only on a track setting.
    Usable performance under 50 degrees.
    Better wet handling which is where my F12 really struggles.
  13. ttforcefed
    ttforcefed F1 World Champ
    19,257
    im done with michelins on ff - im on contis and they have been great so far, with more meat
    otakki and Caeruleus11 like this.
  14. Il Co-Pilota
    May 29, 2019
    6,023
    A.B
    I don't think the oroblem you had was due to them being Michelins. What is working for now is the significantly taller sidewall in conjunction with more volume to absorb impacts.
  15. watt
    watt Formula 3
    Jun 17, 2004
    2,262
    Northern Rocky Mountains
    Giuseppe T Hemingway
    how cold will the all seasons grip on dryu roads? i can't find this info, thanks
  16. ttforcefed
    19,257
    I have no issues with ps4s in the northeast winter when it’s dry on my 430, scud etc
  17. SeattleStew
    1,019
    In the rain
    Stew
    My conti’s did fine in like 30° F weather. Don’t know what ground temp was, and they also were more than 60° when I pulled out of the garage.
