Best way to access clutch slave cylinder? | FerrariChat
Discussion in 'Mondial' started by spbogen, Feb 26, 2013.
  1. spbogen
    spbogen Karting
    Aug 23, 2007
    92
    Charlotte, NC
    Bob
    What would be the best way to get to the clutch slave cylinder(84 cab)? Wheel well, sliding underneath while raised on jacks or from the top(after removing distributer cap). Clutch just went soft. I'll try bleeding it first, but have already accepted the probability of replacement.
  2. soucorp
    soucorp F1 Rookie
    Sep 20, 2011
    4,816
    Old Dominion
    Its very hard to get to it from the top.
    Best is jack up the left rear wheel well (LHD), remove tire, panel. If you have a cabrio, remove the rear engine access panel for more viewing access. see this thread: http://www.ferrarichat.com/forum/mondial/357008-qv-clutch-slave-cylinder.html
  3. spbogen
    spbogen Karting
    Aug 23, 2007
    92
    Charlotte, NC
    Bob
    Thanks for the quick response - I had reviewed that thread but still didn't have a good idea of actual placement. I thought the wheel well would be the best option ...Of course, it figures that's the side closest to the garage wall.
  4. mulo rampante
    mulo rampante Formula Junior
    May 31, 2011
    997
    Terra Incognita
    Charles
    I did mine with the car backed-up onto a pair of ramps. (Rage Powersports CR-7214, these have a long, removable slope section for low profile vehicles.)
    Once it was on the ramps, I was able to do everything from underneath without much difficulty. There are some "blind" reaches from underneath, but nothing particularly difficult. Mike's approach is probably better, but I had no problems.
