Best way to get post-track melted rubber off | FerrariChat
Discussion in 'Ferrari Discussion (not model specific)' started by Aradune, Jul 26, 2004.
  1. Aradune
    Aradune Karting
    Jul 11, 2004
    76
    San Diego
    Not sure if this is the right forum, so apologies in advance.
    Ok, so most of the rubber that got my 360CS after Willow comes off with water and a towell and a lot of rubbing. It's all over. Is there something I could safely use in addition to water to break of the tire rubber but not harm the paint? Someone suggested WD40, but I'm hestitant to try without hearing from others.
    thanks,
  2. rscholl
    rscholl Formula Junior
    Dec 4, 2003
    296
    Houston,TX
    Try 3M Adhesive Remover. You should be able to buy it at any decent auto parts store like Pep Boys. Sometimes Home Depot or Lowe's will have it. It's great and is totally safe on cured auto paint. It will strip off the wax (in fact that's what my clearbra/xpel installer uses to prep the paint), so give it a little waxing afterwards.
  3. maranelloman
    maranelloman Guest
    I hear a product called Goof Off also works very well.
  4. GoFerrari28
    GoFerrari28 Formula 3
    Jun 16, 2004
    2,313
    Ridgemont, CA
    Jeff Spicoli
    This is an old drag racer's trick: spread a light layer of petroleum jelly on the areas behind the wheel wells before you start driving. It washes off easily and absorbs the clag that would normally stick to the paint.
  5. jakermc
    jakermc Formula 3
    Jan 17, 2004
    1,804
    Palm Beach, FL
    Rob
    I use WD40. It works and its safe.
  6. Spasso
    Spasso F1 World Champ
    Feb 16, 2003
    14,656
    The fabulous PNW
    Han Solo
    I was told by the local body shop that lighter fluid is good for removing tar deposits so I would imagine it would work for the rubber too.
  7. Smiles
    Smiles F1 World Champ
    Nov 20, 2003
    16,674
    Pittsburgh, PA
    Matt F
    Or automotive "Bug & Tar" remover.
  8. Aradune
    Aradune Karting
    Jul 11, 2004
    76
    San Diego
    Thanks all.
  9. watt
    watt Formula 3
    Jun 17, 2004
    2,258
    Northern Rocky Mountains
    Giuseppe T Hemingway
    #9 watt, Jul 26, 2004
  10. h22gordo
    h22gordo Formula Junior
    May 24, 2004
    374
    So. Cal.
    Gordan
    That latex is a great idea....
