Best way to remove smoke smell | FerrariChat
Discussion in 'Other Off Topic Forum' started by WJHMH, Feb 20, 2007.
  1. WJHMH
    WJHMH Two Time F1 World Champ
    26,444
    Panther City, Texas
    WJHMH
    Yesterday my mother left her home for a while with the stove on, she was boiling something & completely forgot about it. I was with her during this time but didn't know she did this, when we got home I smelled smoke & opened the kitchen door only to find the house was filled with smoke. There were flames but only burned the pot & the contents inside. I tried airing out the house but the smell is now all over the home. I think she was very fortunate it didn't spread any further than it did. Now I've to get the smell out the furniture, drapes, carpet, etc...
    Any ideas?
  2. rollsorferrari?
    rollsorferrari? F1 Veteran
    Jun 5, 2006
    9,984
    St. Louis
    Scott
    i would recommend fabreeze (sp) always seems to get odors out. if it works in a fraternity house, it should work at a normal house. :)
  3. PhilNotHill
    PhilNotHill Two Time F1 World Champ
    Jul 3, 2006
    27,855
    Aspen CO 81611
    FelipeNotMassa
    Send the drapes to the cleaners.
    Have the rugs professionally cleaned.
    You will prebably have to repaint the interior.
    Smokers Candles at www.maximumscented.com
    Good Luck
    ciao
  4. WJHMH
    26,444
    Panther City, Texas
    WJHMH
    I thought as much, being taken to the cleaners bring on a whole new meaning. Thanks for the information.
  5. darth550
    Jul 14, 2003
    61,110
    In front of you
    BCHC
    #5 darth550, Feb 20, 2007
  6. PhilNotHill
    Jul 3, 2006
    27,855
    Aspen CO 81611
    FelipeNotMassa
    But nicer car! :eek:
  7. RacerX_GTO
    RacerX_GTO F1 World Champ
    14,745
    Oregon
    Gabe V.
    There's two ways to effectively remove smoke.
    Ever wonder how a restoration crew removes smoke from a home that has been partially burned?
    Method 1
    Ozone machine. Not to be confused with the Ionic air cleaner(Ionic Breeze by Sharper Image) This method must be used with care, for pure ozone is poisonous to humans. A restoration crew will typically seal a room as airtight as they can get it, run fans to move the air around and switch on an ozone machine and let it run overnight. The next morning, before entering the room, put on a gas-type respirator. Even a surplus gas mask will work. Switch the ozone machine off first, then the fans and open up all the windows to get the ozone out of the house. The result? no smoke odor.
    The only caution is this, if any damp cloth or carpet is in the area of during the ozone process, it will bleach the damp area out. Ozone will turn water into hydrogen peroxide.
    Method 2
    Smoke fogger teatment. A special restoration solution and a fogger put an ultra fine mist of the solution into the room. The person fogging the room will need a gas mask as well. The fogged product will attach itself to odor and neutralize it. Sealing the room airtight is also required. The fog must take for several hours until the room is clear.
    The only warning about fogging is that if the room is fogged too much, cloth items will saturate.
  8. luvnhp
    luvnhp Rookie
    Dec 25, 2006
    42
    Charlotte, NC
    Brian Syphard
    Ozone machine or Unsmoke 9-D-9
