Best way to remove wheel weights? | FerrariChat
Discussion in 'Technical Q&A' started by Boxer12, Apr 28, 2007.
  1. Boxer12
    Boxer12 Formula 3
    Jun 1, 2003
    1,672
    What is the best method, specifically to get the sticky adhesive pad from alloy wheels? I know the guys at the tire store have some good juice they splash on there, but the sticky stuff remains behind. There has got to be a better way than what I am doing (using WD40 and a rag).
  2. Steve Magnusson
    Steve Magnusson Two Time F1 World Champ Lifetime Rossa
    26,930
    I like the citric acid based "goo" removers -- like "GOO GONE" (sometimes they've got "orange" or one of the other citrus fruits in the name/description/labeling).
    PS The TR wheel is deep enough on the backside that the tire shop should still be able to do a 2-plane balance with all the weights on the inside.
  3. phillg
    phillg Karting
    Feb 4, 2007
    54
    Dorset UK
    I removed the glue by letting a little car polish (mer) soak in for 20 mins,and then cleaned off.Came off completely.
  4. Pizzaman Chris
    Pizzaman Chris F1 Rookie
    Mar 13, 2005
    3,919
    New Hampshire
    Pizzaman Chris
    I agree. "Goo Gone" is the way to go.
  5. Boxer12
    Boxer12 Formula 3
    Jun 1, 2003
    1,672
    I would try both to see which works best, but I don't know what "mer" is! Must be one of those good old British products. Goo Gone I can find! Thx for the advice guys! Jim
  6. Boxer12
    Boxer12 Formula 3
    Jun 1, 2003
    1,672
    I use a shop with a road force balancer, and they usu end up with a weight on the inside and one on the outside. I run Pirelli's and they say that they are the toughest to get balanced. In fact, I usu return two out of four tires bc they won't meet tolerences. They are half worn now, so should be easier to balance I would think.
  7. miketuason
    miketuason F1 World Champ Owner Silver Subscribed
    Feb 24, 2006
    15,823
    Cerritos, CA.
    Whatever you do, don't use chisel and hammer
  8. hank sound
    hank sound F1 Veteran
    Jan 31, 2004
    5,953
    Burbank, CA
    Hank Garfield
    Just apply it to the surface, leave it be and let it work for a few minutes and then wipe off. The other popular similar product is called "Goof Off"
