355 - Best way to rotate engine | FerrariChat
355 Best way to rotate engine
Discussion in '348/355' started by kryten2001, Sep 20, 2023.
  1. kryten2001
    kryten2001 Formula 3
    Hi Guys
    I want to do my own leakdown test at home, so am just enquiring as to the best way to manually rotate the engine to get TDC? I don't want to use the starter and would prefer to do it by hand so I don't need to mess with disabling the fuel pump/injectors etc...
    What's the best method? Pull all the plugs, put it in a high gear and rotate the rear wheels? Can the crank be turned underneath the car (is there enough clearance?)
    What have you guys done?
    I know I could just take it to the dealer, but where's the fun in that.
  2. yelcab
    yelcab F1 World Champ
    Nov 29, 2001
    13,566
    San Carlos, CA
    Mitchell Le
    6 th gear, push the car without plugs out. There is no room under the car for a wrench/socket.
    kryten2001 and Qavion like this.
  3. kryten2001
    OK to do it when on stands (Can you turn just one wheel?).. Rolling the car around on the ground isn't really the best approach....
  4. kryten2001
    Also what's a good figure for compression and leak down numbers on a 355 engine? My understanding is that leakdown is a lot lower than regular cars due to a very small piston ring gap - is that right?
