Best way to slow down. | Page 10 | FerrariChat
Discussion in 'Tracking & Driver Education' started by Dr.Gee, Aug 1, 2015.
Is engine braking useful when racing sports cars?
  1. No, its effect is only incidental
  2. Yes, it is a useful technique
  3. Maybe useful in some situations (describe)
Multiple votes are allowed.
Results are only viewable after voting.
  1. singletrack
    singletrack F1 Veteran
    Mar 16, 2011
    5,971
    Pittsburgh, PA
    Can you define what you mean by "engine braking" in this scenario and how this would be used in the wet vs not in the dry? Just not following you.
  2. tervuren
    tervuren Formula 3
    Apr 30, 2006
    2,469
    The OP was somewhat ambiguous about street/track driving despite being in the tracking section. That applies more to street driving than track, as its a lot safer to run 3rd or 4th gear on the interstate, than top gear.
    In the case of the engine of my 944, the engine wasn't tuned for maximum horsepower, it is not concentrating the power band at the upper end of what the engine can turn over speed wise. The primary purpose of downshifting is to keep the car in the powerband, so with a pure racing engine, there is nothing that could change. The 944, under normal circumstances, I'd be downshifting to a point that the next gear arrived about 5800RPM, within the powerband. I *could* increase engine braking by downshifting to a point 500RPM over red line(7K RPM, a speed the engine can safely spin, but makes poo for power unmodified)
    Theres a certain flat section of interstate near me without as much camber for water run off, pretty much a guarantee when the rain dumps to see fwd's scattered around there. They reconnect with pavement with the front wheels turning a completely different speed, spook the driver, driver goes drastically bad, and take a trip into the fence/grass.
  3. singletrack
    Mar 16, 2011
    5,971
    Pittsburgh, PA
    I don't follow on the interstate. Why?
    ...and why would you do that (downshift to raise engine speed to 7k) vs just using the brakes?
    So you are saying they are hitting their brakes through the water or losing it back out of the hydroplane and onto pavement with traction? That is the first correction I would make - adjust speed leading into the water. So they could brake, drive through on the best line, then get back on the throttle once you are through it. I'm missing what putting the engine to max revs buys you in that scenario. It will slow you slightly, but so would the brakes - and they are both dependent on the grip of the tires. This is actually what you will see taught in driver's education in the US - OMG big puddle, slow down before it, drive straight through off power and off brakes, then make decisions once you have traction back.
    Just not following : )
  4. ProCoach
    ProCoach F1 Veteran
    Sep 15, 2004
    5,468
    VIR Raceway
    Peter Krause
    +1. I agree that the purpose of downshifting is to select the gear that results in the optimal rev range through and out of the corner.
    I guess it is semantics. Braking to me (and most others) is when there is a slowing force inputted by the driver on the rotating, unsprung mass of the car (wheels, tires, hubs, rotors).
    In nearly all cases, properly executed and with commitment to achieve highest levels of deceleration performance, the brakes are the most effective tool at the driver's disposal.
    If there is excessive (read: almost ANY) period of "engine braking/coasting/slight thrust negative" state, the car becomes unstable and there is no consistent way to administer that state.
    At least, that's what 11 TB of data and video from the worlds finest formula, sports racing and GT drivers tell me... :D
  5. GuyIncognito
    GuyIncognito Ten Time F1 World Champ
    100,795
    pffft what do you know :p
  6. Fast_ian
    Sep 25, 2006
    23,397
    Campbell, CA
    Ian Anderson
    Perfectly stated, thanks!
    [/thread!]
    I think that's what pretty much *all* of us have been trying to say all thru this entire train wreck! ;)
    Cheers,
    Ian
  7. singletrack
    Mar 16, 2011
    5,971
    Pittsburgh, PA
    This! Thanks Coach and Ian....and many others : )
  8. JWeiss
    JWeiss F1 World Champ
    Nov 18, 2010
    12,890
    NYC and Long Island, NY
    JWeiss
    To me, this is the key, and probably a large point of the disagreement here.
    If by "use engine braking", 4th Gear means "experience engine braking", then I agree. We all experience it.
    But, to me, "using" it means it's something that I can control, modulate, etc. (administer!) in order for it to be a tool. For me, it's not.
  9. jcurry
    24,153
    In the past
    Jim
    Time to bring this back to life..... lol
    In the 3rd Qtr issue of Prancing Horse (FCA rag) there is a lengthy article about the '65 24 Hrs of LeMans. Apparently Ferrari had a few issues with brakes during that race, to the point where the crews were jacking up cars in the parking lot and taking the rotors. The article mentioned how the drivers ended up using compression braking.:eek:
  10. rdefabri
    rdefabri Three Time F1 World Champ
    Jun 4, 2008
    33,571
    NJ
    Rich
    I rev my engine exactly 500 rpms past redline as I'm slowing down. While that happens, I pump the clutch 10-15 times, on, off, on, off...and so on. At the same time, I do a "star" pattern with the shift rod - 1st, 4th, 3rd, 2nd, 5th, reverse - and repeat that.
    I'm still at speed, then forcibly grab the emergency brake with both hands OFF the wheel to induce maximum spinnage.
    By then, hopefully I've scrubbed off about 100 mph, at which point I look for the the nearest berm or road sign and make a bee-line to it. Once I slam into it (around 80 mph or so), I then stop with the most efficient and clean way possible.
    I didn't see that as one of the choices above, but that's the best way...you heard it from me.
  11. Bas
    Bas Four Time F1 World Champ
    Mar 24, 2008
    43,217
    ESP
    Bas
    Slamming it into 1st, pop clutch out works a treat. Won't damage car since you slowing down anyways.
  12. ProCoach
    ProCoach F1 Veteran
    Sep 15, 2004
    5,468
    VIR Raceway
    Peter Krause
    Hmmm, maybe I can work these approaches into the curriculum? :D
  13. Fast_ian
    Sep 25, 2006
    23,397
    Campbell, CA
    Ian Anderson
    :D
    Post of the thread, right there!
    Cheers,
    Ian
  14. rdefabri
    Jun 4, 2008
    33,571
    NJ
    Rich
    LOL!! :D:D:D
  15. Rob in Potomac
    Rob in Potomac Formula Junior
    Mar 3, 2006
    454
    Potomac, MD
    Robert
    On a more serious note - one of the corrections I often observe required is the too early downshifting at the end of a long straight. I am not certain less experienced drivers do this to utilize the braking power of the engine - lower gear - or just because they want to get the car into the appropriate gear to enter the corner as quickly as possible. In fact, you sometimes observe coasting into the corner. In any event, again for most drivers, the early application of brakes and later downshifting results in a smoother and controlled entry into the corner and ultimately results in earlier application of the throttle in or at exit of the corner. Somewhat of an oversimplification - but this whole discussion has often veered away from basics.
    Rob in Potomac
  16. rob lay
    rob lay Administrator
    Staff Member Admin Miami 2018 Owner Social Subscribed
    Dec 1, 2000
    64,632
    Southlake, TX
    Rob Lay
    how did I not see this thread yet! ok, anyone quote Giuseppe Risi yet?
    "brakes are cheap, engines expensive!"
    that said I love engine braking! I love the sounds, heal toeing, and it is effective in coordination with the brakes.
    do it wrong and unsettle the car, blow your motor, blow the trans, blow the clutch, and blow your race!
  17. DesertDawg
    DesertDawg Nine Time F1 World Champ
    95,516
    The Desert
    DesertDawg
    Oh, come on Rob - everyone knows that middle pedal is something akin to your appendix... nobody knows what it's really there for. It's just an extraneous addition with no quantifiable value whatsoever.
  18. DesertDawg
    95,516
    The Desert
    DesertDawg
    Glad to see I'm not the only one!
  19. John B
    John B Formula 3
    May 27, 2003
    1,564
    NJ
    In racing you should either be on the gas or the brakes. NO COASTING!!!
  20. rob lay
    Dec 1, 2000
    64,632
    Southlake, TX
    Rob Lay
    yes, but engine braking you are still on the brakes.
  21. Entropy
    Entropy Formula 3
    Jul 10, 2008
    2,149
    that's why you should shift into neutral, and why F1 wheels have the neutral button so close to the driver's thumb
    (sarcasm)
    I was hoping this thread had worn itself out. Guess not.
  22. NeuroBeaker
    NeuroBeaker Advising Moderator
    Moderator
    Oct 1, 2008
    40,260
    Huntsville, AL., USA
    Andrew
    The appendix is a vestigial structure that used to have a greater role in digestion and immunology, but we've evolved away from needing it and by now it has become superfluous.
    Perhaps racecar drivers are evolving away from needing the middle pedal and would only go back to it in the event of a sudden digestive issue... such as the brown overalls that can arise from a rapidly approaching barrier? Maybe we'll get a clearer picture heading into the next millennia.
    All the best,
    Andrew.
  23. rob lay
    Dec 1, 2000
    64,632
    Southlake, TX
    Rob Lay
    ha, yes, would like to hear honestly what % shift F1 to neutral when braking. :D
  24. brian.s
    brian.s F1 Rookie
    Nov 3, 2003
    3,809
    Midwest
    Brian
    I think too many people watch Top Gear...........
  25. singletrack
    Mar 16, 2011
    5,971
    Pittsburgh, PA
    KILL IT WITH FIRE!!
