Bianco Fuji CS Spider Project | Page 13 | FerrariChat
Discussion in '360/430' started by voicey, Apr 16, 2011.
  1. Exotic Lambo
    Exotic Lambo Formula Junior
    Aug 15, 2011
    491
    South Florida
    Gianca
    Hey,
    Do you happen to know the color code on this silver? I have to re-paint the air box on my Stradale.
  2. MoeMonney
    MoeMonney Karting
    Jan 25, 2004
    67
    Mexico
    Charles
    I have to say this is inspiring. Great Work!
  3. dlopez001
    dlopez001 Formula Junior
    Sep 25, 2007
    908
    CA
    DL
    I'm resurrecting an old thread I know, but I saw this and tohught it was rather unique.
    http://www.dupontregistry.com/autos/Search/DRauSearchDetails.aspx?itemid=1130802
    DL
  4. voicey
    voicey Formula 3
    Jul 29, 2009
    1,193
    London, UK
    Aldous Voice
  5. 430 scuderia
    430 scuderia Guest
    Jun 10, 2008
    813
    Very special project... It's very beautiful ;-)
    Congrats..!
  6. voicey
    voicey Formula 3
    Jul 29, 2009
    1,193
    London, UK
    Aldous Voice
    One of my winter projects is to refresh the tired suspension parts. Top of the list were the ball joints - I was informed by a previous owner that the lower joints were changed under warrenty when he bought the car in 2005 with 9k on the clock (replaced with the crappy OEM joints). The upper joints were replaced by Shiltech with Hill's stainless ones in 2010.
    Here's the state of the lower ones - they don't look too bad with a small amount of pitting and corrosion and I've certainly seen a lot worse. However, there was play that could be felt by hand so they had to go.
    The first problem I encountered was that I didn't have a suitable socket to press them out with - so I decided to make my own from an offcut of alu.
    A little turning on the lathe...
    And here's the finished item next to a brand new Hill joint:
    I also turned down the rest of that offcut to help with the shock bush (more later).
    And I made a tool to press out the upper joints just in case I need one in the future...
  7. voicey
    voicey Formula 3
    Jul 29, 2009
    1,193
    London, UK
    Aldous Voice
    To press it out I used the tool I made, a big socket and my 60 year old vice.. plus a little heat to break the glue bond.
    The old circlips needed to be removed from the boots...
    ... and installed in the arm to prevent the glue from getting in the slots.
    I used the correct Hysol glue (bought from Hill).
    I didn't want to use up a nozzle as I was only doing one joint at this moment in time so mixed the glue on a bit of clean cardboard.
    And applied to both the joint and arm. I put far too much on - in the future I will use less and warm it up so it spreads more easily. The glue dissolves in isopropyl alcohol so the excess was easily mopped up.
  8. voicey
    voicey Formula 3
    Jul 29, 2009
    1,193
    London, UK
    Aldous Voice
    Joint in...
    ...and boots on. I left the arm in my low bake oven* overnight to set.
    [size=-2]*I haven't really got a low bake oven (yet) but simply put the arm in my airing cupboard which contains both the hot water cylinder and boiler so it's very useful for drying/setting stuff - much to the dismay of my other half.[/size]
  9. voicey
    voicey Formula 3
    Jul 29, 2009
    1,193
    London, UK
    Aldous Voice
    My lower shock bushes were totally shot. These were able to be pressed out with a 22mm impact socket but I used the machined alu ring I made to sit against the shock itself as there is hardly any material at the bottom.
    I bought the Superformance pattern bushes - guess which one is going back in!
    The inside of the shock was amazingly clean..
    And here's the new bush installed in the shock.
  10. FerrariDublin
    FerrariDublin F1 Rookie
    Jun 14, 2009
    3,457
    Dublin, Ireland
    Greg
    Excellent work Voicey. Well done and thanks for sharing.
    Are you going to re-bush the suspension ams also or are they ok?
  11. Kouki Monster
    Kouki Monster Formula Junior
    Feb 26, 2007
    422
    Washington
    AJ
    awesome write up! going to archive this in my folder of DIY
  12. voicey
    voicey Formula 3
    Jul 29, 2009
    1,193
    London, UK
    Aldous Voice
    Thanks mate. Yes I am most likely to change the arm bushes. Powerflex didn't come through but I saw some kevlar GT2 bushes the other day (the guy needs to find the lower ones). I'm also waiting to see the Superformance bushes before making a decision.
    Thank you!
  13. wang
    wang Formula 3
    Feb 23, 2004
    1,998
    Brunei
    H. Wang
    Great stuff Voicey, I'm learning alot.
    Thanks for sharing :)
    Cheers
  14. voicey
    voicey Formula 3
    Jul 29, 2009
    1,193
    London, UK
    Aldous Voice
    I managed to grab a few mins in the garage today - I wanted to take a look at the anti-roll bar on the corner I've got stripped down.
    The drop link came off very easily. There wasn't much play to be felt but the boots were split so it will be renewed.
    The main bush is inside a cast alu mount attached to the subframe by two 13mm bolts. I coated the bar with some PTFE spray to help with the removal.
    Despite being able to get it past the first turn it was impossible to manoeuvre past the second turn. I eventually prised out the rubber bush slightly which gave me enough play to get it off.
    He's the mount and bush as it came off the car and shows how much I had to prise the bush out.
    The bush came out with a small tap of the hammer on a suitable socket. It doesn't look too bad but for the price of the replacement it will be changed.
    The end of the bar itself was corroded. Ideally I'd remove the whole bar and get it shot blasted and powder coated. I don't have the space to get it out at the moment so the job will have to wait until I get my proper workshop.
    In the meantime I ground the area down with a sanding drum on the dremel.
    And then gave it a good coat of rust remedy. I will give it a coat of case paint once the new bush has been installed.
  15. FerrariDublin
    Jun 14, 2009
    3,457
    Dublin, Ireland
    Greg
    More excellent work.
    I'll be interested to see how you get the new bushing on to the a-roll bar given the difficulty getting the old one off! Do please detail that procedure as you go!
    I suspect you're really going to like the end result of all this work. When I purchased my car nearly all of the rubbers and bushes had been renewed and it was lovely and tight. I never experienced it prior but I suspect the diff between worn and perished mounts / balls and a complete refresh is significant.
    Keep it up - and well done again. I may PM you for a loan of your two ball pushers in due course!
  16. voicey
    voicey Formula 3
    Jul 29, 2009
    1,193
    London, UK
    Aldous Voice
    The rubber bush is split so I plan to install it on the bar first and then push the mount over the top of it.
    I'm really looking forward to seeing how different it drives after this refresh.
  17. spiderscott
    spiderscott Formula 3
    1,662
    Ratarossa HQ UK
    Ratarossa
    Superb work Aldous .... love your low bake oven !!
    Looks like you are having such fun doing it, I will bring mine over for you when you are done :O}
  18. anxpert
    anxpert Formula Junior
    Mar 4, 2008
    970
    Oceanside, CA
    Enrique Mar
    Agreed Scott, Aldous is having all of the fun !
  19. voicey
    voicey Formula 3
    Jul 29, 2009
    1,193
    London, UK
    Aldous Voice
    Have you got the CS flamblocs in your car? I'm more than happy to help you with your car if you need a hand mate.
    Sometimes it's fun - sometimes it isn't... but I bet you all about that Enrique!
  20. voicey
    voicey Formula 3
    Jul 29, 2009
    1,193
    London, UK
    Aldous Voice
    #320 voicey, Jan 6, 2012
    I received new ARB bushes and drop links today for front and rear. Big thanks to Steve @ Joe Macari - I ordered these at 3:30pm on Tuesday and they hit my desk at 10am today (Fri).
  21. Kouki Monster
    Feb 26, 2007
    422
    Washington
    AJ
    nice! but is the e45 cream for the "lets see beautiful ladies with ferrari's" thread? hopefully not the beautiful children one HAHAHA
  22. voicey
    voicey Formula 3
    Jul 29, 2009
    1,193
    London, UK
    Aldous Voice
    Sadly, I get mild eczema on my hands in the winter so it's there for me!
  23. voicey
    voicey Formula 3
    Jul 29, 2009
    1,193
    London, UK
    Aldous Voice
    #323 voicey, Jan 8, 2012
    I got some more garage time today. First up was to put the two flamblocs back together that I dismantled to see how they were made.
    The dogbones are held in place with an external circlip. As you can see, the circlips I removed were bent and distorted - they shouldn't be reused. Ferrari don't list the circlips seperately so I headed down to a local engineering supplier, Fiveways Belts and Bearings, in Eltham and bought some 18mm and 20mm external circlips - they were a perfect fit.
  24. voicey
    voicey Formula 3
    Jul 29, 2009
    1,193
    London, UK
    Aldous Voice
    #324 voicey, Jan 8, 2012
    Next up was to fit a new track rod end to the offside. I had replaced the nearside one back in May when play was detected at the HR Owen open day. The offside TRE didn't have any play but the bot was torn and the joint very loose. Seeing all the effort I'm going to it seemed churlish not the switch it out.
    I always lube the threads with copperslip to make future adjustments easier - as long as the locknut is done up properly it shouldn't have any adverse affects. Once I'm done with the suspension refresh I will get it to Wheels in Motion and have Tony check the settings.
  25. voicey
    voicey Formula 3
    Jul 29, 2009
    1,193
    London, UK
    Aldous Voice
    #325 voicey, Jan 8, 2012
    I then turned my attention to the nearside. First out was the drop link - I was disspointed to see it had been fitted without one of the washers and since they are a seperate part number I will have to order one!
