Bianco Fuji CS Spider Project | Page 5 | FerrariChat
Discussion in '360/430' started by voicey, Apr 16, 2011.
  1. voicey
    voicey Formula 3
    Jul 29, 2009
    1,193
    London, UK
    Aldous Voice
    My first major balls-up :(
    The paint on the disaerator was non existant at the top and while the coolant tank was off I decided to tidy it up a little.
    It's aluminium so needs special primer to make the paint stick.
    After a coat of hammerite - the picture was taken when the paint was wet but there's still a big difference between the new and old paint. It looks gash and I have already taken steps to rectify it with the correct wrinkle finish. Watch this space.
  2. CarreraCaballo
    CarreraCaballo Karting
    Apr 5, 2011
    246
    Y.F.A
    Hahaha . . . I like it in Hammerite . . . Fits pretty well with the rest ;) :D
    Greetz,
    Joseph
  3. voicey
    voicey Formula 3
    Jul 29, 2009
    1,193
    London, UK
    Aldous Voice
    Trust me - it looks awful and will be changed.
  4. CarreraCaballo
    Apr 5, 2011
    246
    Y.F.A
    Wise decision :)
    How is the condition of your interior, any restorations planned in there?
    Greetz,
    Joseph
  5. voicey
    voicey Formula 3
    Jul 29, 2009
    1,193
    London, UK
    Aldous Voice
    Interior is OK - not quite up to my standards but I have plans for it. However, there are more pressing things to deal with...
  6. voicey
    voicey Formula 3
    Jul 29, 2009
    1,193
    London, UK
    Aldous Voice
    #106 voicey, May 5, 2011
    With the car back together for the first time since I started it was time to take it out and show it off. I recently went to a breakfast club at Goodwood circuit and was lucky enough to be invited to show the car on the pit straight.
    Photo courtesy of globalsupercars
  7. no8080
    no8080 Karting
    May 5, 2011
    83
    Uk
    Very nice work indeed.
    I am about to start my own mini project of fixing up a 360 modena I have bought. I am in the UK as well.
    I am interested in your repair on the rear bumper, as I have a similar issue on mine, it has a small hole/crack in it.
    So I would like to know what products you used and what methods you used to restore it. Mine has a gloss black paint finish at the moment and I want to go for the satin black you have used.
    Neil
  8. F430addict
    F430addict F1 Rookie
    Sep 17, 2010
    4,460
    Amazing...lovely looking spider. Doesn't look her age at all. Great job!
  9. F430addict
    Sep 17, 2010
    4,460
    And oh yes, are you adding the cs mirrors too?
  10. anxpert
    anxpert Formula Junior
    Mar 4, 2008
    970
    Oceanside, CA
    Enrique Mar
    Looking like all the hard work is paying off !
  11. voicey
    voicey Formula 3
    Jul 29, 2009
    1,193
    London, UK
    Aldous Voice
    Thanks.
    It was a very easy repair for me. I ground back the damage with a grinding tip on the dremel. This revealed the damaged to be on the surface only. I didn't have any cracks but if you do you'll need to drill the ends to stop them spreading. As my damage was on the surface I didn't need to glassfibre but if you have a hole then you'll need to lay a mat over the back and cover with resin.
    Once my damage was cleaned up I put a skim of filler over and let it set. This was rubbed back to get it flat. I then used filler primer and let that set. This and the rest of the diffuser were rubbed down with 600 wet and dry. I then sprayed it with two coats of satin black.
    I'll PM you so you can get in touch if you have any questions.
  12. voicey
    voicey Formula 3
    Jul 29, 2009
    1,193
    London, UK
    Aldous Voice
    Thank you.
    I have a package en-route. I will post up details ASAP.
    Thanks, although I'll never get anywhere close to what you're doing.
  13. voicey
    voicey Formula 3
    Jul 29, 2009
    1,193
    London, UK
    Aldous Voice
    #113 voicey, May 8, 2011
    The other weekend was an opportunity to take the car out and give it a bit of a shakedown. I joined Petrolhead Nirvana on one of their Welsh weekend tours - the weather was great and the car performed very well. All in I covered about 500 miles at full tilt on some of the finest roads in Wales.
    One thing I can note is the Pagid Blue pads are so much better than OEM. They do squeel a touch at low speeds but they make up for it when throwing the anchor out.
  14. voicey
    voicey Formula 3
    Jul 29, 2009
    1,193
    London, UK
    Aldous Voice
    #114 voicey, May 11, 2011
  15. voicey
    voicey Formula 3
    Jul 29, 2009
    1,193
    London, UK
    Aldous Voice
    #115 voicey, May 11, 2011
    It was pointed out to me that I had put the exhaust bracket on upside down. As I had the rear bumper off I quickly switched it round. It seems the hammerite has gone a golden colour with the heat - it looks OK at the moment as it matches part of the exhaust but if it gets any worse I'll have to think of another solution.
  16. voicey
    voicey Formula 3
    Jul 29, 2009
    1,193
    London, UK
    Aldous Voice
    #116 voicey, May 12, 2011
  17. voicey
    voicey Formula 3
    Jul 29, 2009
    1,193
    London, UK
    Aldous Voice
    #117 voicey, May 12, 2011
    I noticed that the vaccum pipes that control the stock exhaust flaps were missing - I guess whoever took the stock exhaust off removed these instead of plugging them. I have seen reports of open pipes causing problems, including the dreaded CEL. This was easily fixed with a small length of pipe, a bolt and two hose clips.
  18. voicey
    voicey Formula 3
    Jul 29, 2009
    1,193
    London, UK
    Aldous Voice
    Following my botch to touch in the disaerator I decided to do the job properly.
    First off was to drain the oil out but I only managed to get a bit out as I didn't have the correct hex for the front drain plug. No matter as enough came out to drain the disaerator.
    As the car will be sitting for a while without oil I decided to tape up the ignition to stop any unfortunate accidents.
    This is what I wanted off the car. It was very easy to remove - three breather pipes, one big braided hose that goes to the heat exchanger and three 13mm bolts. It was removed with everything else in place.
    I taped everything up to prevent any debris getting in the oil system.
    Paint stripper in action:
    And this is how I left it for the day as I ran out of paint stripper.
  19. PAP 348
    Dec 10, 2005
    100,232
    Mount Isa, Australia
    Pap
    Nice work mate. :):)
  20. bulletproofwallet
    Mar 2, 2011
    198
    San Francisco
    I LOVE process threads......am I the only one thats only seeing about 1/2 of all the photos posted?
    Its killing me!
    Inspiring project by the way.
  21. voicey
    voicey Formula 3
    Jul 29, 2009
    1,193
    London, UK
    Aldous Voice
    Thanks.
    Thanks. What url are you viewing the thread from? I think to see all the pics you need to be logged into www.ferrarichat.com
  22. bulletproofwallet
    Mar 2, 2011
    198
    San Francisco
    thanks, i logged out and then back in again and all the images showed up.
    again, great project!
  23. voicey
    voicey Formula 3
    Jul 29, 2009
    1,193
    London, UK
    Aldous Voice
    I spent a day in the garden as the weather was glorious.
    First step was to strip the rest of the paint off the disaerator.
    Masked up and ready for paint. I was careful to key the surface with wire wool and then thoroughly degreased it.
    The can reckoned on three coats so that's what it got.
    After an hour in the heat of the sun the wrinkles were already starting to form. I'm really pleased with the way it's turned out.
  24. F430addict
    Sep 17, 2010
    4,460
    Wow!
  25. voicey
    voicey Formula 3
    Jul 29, 2009
    1,193
    London, UK
    Aldous Voice
    The undertray had a piece snapped off - fortunately the broken off piece was inside the tray. I wasn't even going to entain buying a new one at over £750.
    The other side was also beginning to crack:
    A few pieces of fibreglass matting to strengthen things up...
    And impregnated with resin. I'll tidy it all up once it hardens with the dremel.
