Big Brake Kit options in 2024 for 83 Mondial QV | FerrariChat
Discussion in 'Mondial' started by gunn, Mar 4, 2024.
  1. gunn
    gunn Formula Junior
    Aug 30, 2021
    319
    Gunn S
    Hi:
    I'm explore BBK options and wanted to see what folks have used in the past. It looks like my front rotors need replacing and since I want to replace the rear ebrake setup with an electronic parking brake, I wanted to see what options are out there.
    - My application doubles the HP over stock so instead of throwing money on replacing my stock components, I might as well buy upgraded stuff. I DGAF about purity.
    - Target is 5x108 bolt (stock) and I have 18x8.5 wheels to clear any larger rotors
    - Stock rotors seem to be 282 mm diameter x 22mm thick (11.1" x 0.78" thick) for front and 280mm diameter x 22mm thick (11" x 0.78" thick) rear
    - No larger than 4-pot (not sure how the brake master cyl will deal with the changes in clamping force and/or the front/rear bias but I can deal with both later)
    Here's what I found so far here in the US
    Girodisc sells a front kit with relocation brackets for the 308 which should fit the fronts
    - I'm waiting to hear back as to what they offer for the rears
    https://************/ferrari-308-bbk/
    FPE/Ferrparts sells a kit with unknown rotors and HiSpec 4pot calipers
    - looks like it also includes SS lines, pads, and the relocation brackets
    - I think this looks just like the Superperformance.co.uk kit
    https://www.ferraripartsexchange.com/products/brake-kit-p002
    https://www.ferraripartsexchange.com/products/rear-brake-kit-with-black-calipers
    What is NOT clear to me is how any kits deal with the rear e-brake
    - It's within my/friends capabilities to fabricate a bracket to hold the e-brake but does anyone know one that is available off-the-shelf AND mates to one of the above kits?
    - Wilwood sells kits with 0.75"-.81" thick rotors, 1.04-1.1" rotors, and 1.19-1.25" thick rotors.
    - About $1200-ish, in black or red
    https://www.summitracing.com/search/part-type/parking-brakes-electric
    Q; Anything else I should consider?
    ellum likes this.
