Big red battery warning (and the small one on the left) | FerrariChat
Discussion in '456/550/575' started by niftyfivefifty, Apr 1, 2021.
  1. niftyfivefifty
    niftyfivefifty Formula Junior
    Mar 5, 2007
    366
    PacNW
    I was out collecting exhaust sounds on Sunday in heavy rain, and at one point my dash lit up like crazy. ABS, suspension, and battery errors. I was able to get the car home, but it felt like it was losing power steering on some corners. I made it home and put it on the charger, thinking I must have left the car unlocked the night before and maybe that drained it more than usual. It started and ran with no issues last night, but it is still showing the big red battery error in the center info area and the smaller red battery on the left side of the instrument panel. I did some reading and I'm going to get the car on a lift this weekend to check all grounds, alternator wiring, etc. Has this happened to anyone else before?
  2. flash32
    flash32 F1 Veteran
    Aug 22, 2008
    7,206
    Central NJ
    Dominick
    Check your voltage while running
    niftyfivefifty, Qavion and rhern213 like this.
  3. rhern213
    rhern213 Formula Junior
    Jan 8, 2021
    578
    Miami, FL
    Richel
    #3 rhern213, Apr 1, 2021
    +1
    First check your battery voltage with the car off to make sure it's at 12+ volts.
    Then turn the car on and monitor the voltage, if the alternator is working properly the voltage should increase to about 13.5-14.5.
    If it's any lower than 13 then the alternator's probably the problem.
    If it has proper charging voltage then I would start looking around for potential loose wiring.
    niftyfivefifty and Qavion like this.
  4. niftyfivefifty
    Mar 5, 2007
    366
    PacNW
    Thanks guys! I'll test it tonight and report back.
  5. tazandjan
    39,392
    Unless the battery is new, consider getting a new AGM. Cures a lot of weird problems.
    niftyfivefifty likes this.
  6. niftyfivefifty
    Mar 5, 2007
    366
    PacNW
    Yeah it's strange, the battery is a new Odyssey Extreme AGM, the alternator was rebuilt last year with a new regulator installed, and my mechanic confirmed all connections are good in November. So either something prematurely failed, or we missed something somewhere.
  7. niftyfivefifty
    Mar 5, 2007
    366
    PacNW
    I'm only getting 12.18v when running (same when off). So it appears my alternator needs to be looked at.
    Il Tifoso and Qavion like this.
  8. 308 GTB
    308 GTB F1 World Champ
    11,758
    New Jersey
    Barry Wolinsky
    One gets an array of warning lights and a loss of power, most noticeable in turns, when the alternator isn't functioning properly. Here's my F355 Challenge at Daytona when my alternator failed in 2015...
    It's possible that the alternator cable connectors are dirty and just need to be cleaned.
  9. Qavion
    Qavion F1 World Champ
    14,645
    Ian Riddell
    Also make sure the small red wire between the battery and the alternator hasn't detached itself.
  10. niftyfivefifty
    Mar 5, 2007
    366
    PacNW
    Thanks and yes, it was very strange in the turns. That looks like it was a fun day! I have been driving in a lot of wet and “dirty” conditions so it could very well be the connectors.
    Thanks, I will be taking a closer look on Saturday and hopefully it is a simple fix.
  11. 308 GTB
    11,758
    New Jersey
    Barry Wolinsky
    I had the same thing happen to me at Watkins Glen a couple of years ago. It wasn't the alternator or dirty connections but rather a broken wire in the cable....
    My support techs spliced the broken wire and I was good to go. :)
  12. niftyfivefifty
    Mar 5, 2007
    366
    PacNW
    I have actually suspected this because it has always been a little off. So your broken wire was in the cable between the alternator and battery?
  13. 308 GTB
    11,758
    New Jersey
    Barry Wolinsky
    Yes, it was about 3 cm from the connector to the alternator. It gets hot over there and the wires in the cable get brittle. In my case, I experienced intermittent symptoms as the broken wire would make intermittent contact. My techs used a wire continuity detector to diagnose the problem.
    I replaced the cable when the car got back to the shop. The cable is difficult to shield in the F355.
  14. niftyfivefifty
    Mar 5, 2007
    366
    PacNW
    My mechanic confirmed that the alternator is toast. But he found a voltage drop at the ignition switch, so that may have contributed to the premature failure. More details to come...
  15. niftyfivefifty
    Mar 5, 2007
    366
    PacNW
  16. tres55
    tres55 F1 Rookie
    3,573
    Canada
  17. niftyfivefifty
    Mar 5, 2007
    366
    PacNW
    He said the contacts will loosen or oxidize over time, and the reduced conductivity surface area can create a dangerous amount of heat, leading to this type of damage, or worse. I can definitely see why people do the gold contacts fuse box upgrade.
  18. rhern213
    Jan 8, 2021
    578
    Miami, FL
    Richel
    Ouch, yeah I guess in the grand scheme of things it was fortunate to just be the alternator. Perhaps also in the PacNW with the extra rain and condensation it could lead to higher risk of something like this happening.
  19. AVIMAX
    AVIMAX Formula Junior
    Aug 5, 2014
    714
    Toronto
    Ryan
    I don't know about the black connector in your first photo, but the 2 wires in the blue connector that overheated are for one of the radiator fans. Check the wires for the other radiator fan (they are in a different connector), I bet they have also overheated. I believe this is common as the radiator fans age.
    Mine before I repaired.
  20. niftyfivefifty
    Mar 5, 2007
    366
    PacNW
  21. rhern213
    Jan 8, 2021
    578
    Miami, FL
    Richel
    Was it difficult to get access to the back of the board to check on it?
  22. niftyfivefifty
    Mar 5, 2007
    366
    PacNW
    My mechanic is is the one who pulled it, but I believe it comes out with a few screws after detaching all of the harnesses.
    rhern213 likes this.
  23. niftyfivefifty
    Mar 5, 2007
    366
    PacNW
    Ferrari55whoa, Qavion and rhern213 like this.
  24. A348W
    A348W Formula 3
    Jun 28, 2017
    1,865
    North Wiltshire, UK
    Where did you get the new fuse board done?
  25. niftyfivefifty
    Mar 5, 2007
    366
    PacNW
    Mark Glenwood at 7 Lakes Auto Repair in Arlington, WA is the creator of these, and he can help source one for you. It does require a core and a 2 week turnaround. Here is his business FB page: https://www.facebook.com/7Lakesautorepair/
