Biggest Engine In The World | FerrariChat
Discussion in 'General Automotive Discussion' started by intouch1, May 1, 2008.
  1. intouch1
    intouch1 Formula Junior
    Sep 10, 2006
    918
    Egypt
    #1 intouch1, May 1, 2008
    The Wartsila-Sulzer RTA96-C turbocharged two-stroke diesel engine is the most powerful and most efficient prime-mover in the world today. The Aioi Works of Japan's Diesel United, Ltd built the first engines and is where some of these pictures were taken.
    It is available in 6 through 14 cylinder versions, all are inline engines. These engines were designed primarily for very large container ships. Ship owners like a single engine/single propeller design and the new generation of larger container ships needed a bigger engine to propel them.
    The cylinder bore is just under 38" and the stroke is just over 98". Each cylinder displaces 111,143 cubic inches (1820 liters) and produces 7780 horsepower. Total displacement comes out to 1,556,002 cubic inches (25,480 liters) for the fourteen cylinder version.
    Some facts on the 14 cylinder version:
    Total engine weight: 2300 tons (The crankshaft alone weighs 300 tons.)
    Length: 89 feet
    Height: 44 feet
    Maximum power: 108,920 hp at 102 rpm
    Maximum torque: 5,608,312 lb/ft at 102rpm
    Fuel consumption at maximum power is 0.278 lbs per hp per hour (Brake Specific Fuel Consumption). Fuel consumption at maximum economy is 0.260 lbs/hp/hour. At maximum economy the engine exceeds 50% thermal efficiency. That is, more than 50% of the energy in the fuel in converted to motion.
    For comparison, most automotive and small aircraft engines have BSFC figures in the 0.40-0.60 lbs/hp/hr range and 25-30% thermal efficiency range.
    Even at its most efficient power setting, the big 14 consumes 1,660 gallons of heavy fuel oil per hour.
  2. TexasF355F1
    72,530
    Cloud-9
    Jason
    They have Umpa-Lumpa's working!
  3. WILLIAM H
    WILLIAM H Three Time F1 World Champ
    Nov 1, 2003
    35,532
    Victory Circle
    HUBBSTER
    I was reading a book about building our first Starship, not Sci Fi, more of a socio political book on how this will be done. The author states that it will probably be private industry bcus Govt is too slow and mostly interested in things that they can tax and how do you tax another star system ?
    Anyways he was saying how this ship would most likely use a Matter/AntiMatter drive
    He wrote that when this engine was turned on in the 1st second it would produce more power than all of humanity has produced in the last 400 years !!!!!!!!!!
  4. 62 250 GTO
    62 250 GTO F1 Veteran
    Jan 9, 2004
    7,765
    Nova Scotia Canada
    Neil
    Did he go into any specifics? Anyone can make claims and put their words on a page. "How will a Matter/Antimatter drive be constructed with any sort of reliability?"
  5. BoulderFCar
    BoulderFCar F1 World Champ
    13,192
    Asheville, NC/Ft Lauderdale
    Tom
    Now that is a friggin’ driveshaft and flywheel.
    I understand the efficiencies of a single drive motor, underwater gear and so on. On the other hand, I’m a little surprised that they have all their eggs in one basket with a single motor. Can you imagine what a pig a container ship would be in the middle of the ocean with no power? Maybe they have some other method of power than can spin that drive shaft in the event of failure.
  6. Lee in Texas
    Lee in Texas Formula Junior
    Oct 21, 2006
    685
    near Austin, TX
    Lee
    Turbocharged? I saw many, many posts about this same engine on another automotive forum, but none ever said it was turbocharged. I'd love to see the turbos for it. I'm not saying it's not true...I'd just really love to see them.
  7. WILLIAM H
    Nov 1, 2003
    35,532
    Victory Circle
    HUBBSTER
    Not really, he was interpolating from the speed you would need to cover enormous distances and moving several 1000 tons of spacecraft and from what nuclear scientists told him
    Matter/antimatter explosions are amongst the most powerful in the universe so if you can harness this in an engine you have a serious hot rod :)
    http://science.howstuffworks.com/antimatter1.htm
    "When antimatter comes into contact with normal matter, these equal but opposite particles collide to produce an explosion emitting pure radiation, which travels out of the point of the explosion at the speed of light. Both particles that created the explosion are completely annihilated, leaving behind other subatomic particles. The explosion that occurs when antimatter and matter interact transfers the entire mass of both objects into energy. Scientists believe that this energy is more powerful than any that can be generated by other propulsion methods.
    So, why haven't we built a matter-antimatter reaction engine? The problem with developing antimatter propulsion is that there is a lack of antimatter existing in the universe."
  8. scottyd
    scottyd Karting
    Jun 22, 2005
    103
    Lucan
    Scott Dietrich
    Does anyone make a propane or NOS injection kit for it yet lmao.
  9. WILLIAM H
    Nov 1, 2003
    35,532
    Victory Circle
    HUBBSTER
    The Borg might have one :)
  10. 62 250 GTO
    Jan 9, 2004
    7,765
    Nova Scotia Canada
    Neil
    The explosion part is where my concern is focused. If they are that powerful, what happens if GM gets the nod to build it? Will I be given enough time to buy a new "Hitchhikers Guide To The Galaxy" book and wait for a passing ship to give me a lift?
  11. WILLIAM H
    Nov 1, 2003
    35,532
    Victory Circle
    HUBBSTER
    I guess we should have Honda or Toyota build it bcus we'd have to mortgage the whole planet if Ferrari builds it :)
  12. AnotherDunneDeal
    AnotherDunneDeal F1 Veteran
    Jun 2, 2003
    6,109
    N.Richland Hills, Tx
    James Dunne
    I would love to see the intercoolers.......
  13. WILLIAM H
    Nov 1, 2003
    35,532
    Victory Circle
    HUBBSTER
    Those are probably the size of a small town :)
  14. AnotherDunneDeal
    Jun 2, 2003
    6,109
    James Dunne
    Controlled by the water outlets at Hoover Dam.....and all the oil refineries on the Texas Gulf coast.
  15. mls
    mls Karting
    May 1, 2005
    225
  16. Mbutner
    Mbutner Formula 3
    Aug 11, 2005
    1,689
    Bay Area / Washington DC
    Quick Draw
    1.5 mil lb/ft of torque!?! That is just AWESOME. lol
  17. Maranello Guy
    Maranello Guy F1 Rookie
    Jun 5, 2005
    3,290
    MG
    Almost eight Veyrons :D
  18. FerrariF50lover
    FerrariF50lover Formula 3
    Aug 12, 2005
    2,383
    Ohio
    Nate
    This thing wouldnt stand a chance on the ring against the gtr
  19. RussianM3_dude
    RussianM3_dude F1 Rookie
    4,097
    Switzerland/Montreal
    Nikolai Petroff
    Put it on a Civic and add NNNNAAAAWWWWSSSS!!!!
  20. Mbutner
    Mbutner Formula 3
    Aug 11, 2005
    1,689
    Quick Draw
    Ummm, that 7780 hp figure is PER CYLINDER.
  21. 62 250 GTO
    Jan 9, 2004
    7,765
    Nova Scotia Canada
    Neil
    Wasn't it 5.6 million?
  22. Mbutner
    Mbutner Formula 3
    Aug 11, 2005
    1,689
    Quick Draw
    I stand corrected! No worry if you run the ship into a sand bar, just crank the engine up and spin the earth the other way.
  23. 62 250 GTO
    Jan 9, 2004
    7,765
    Nova Scotia Canada
    Neil
    Seriously what would you do with only 1.5 million? My coffee maker has more torque than that.
  24. Mbutner
    Mbutner Formula 3
    Aug 11, 2005
    1,689
    Quick Draw
    LOL, well, you are from Canada. You guys brew some pretty strong coffee!
  25. BBL
    BBL Formula Junior
    Nov 1, 2006
    658
    Northern California
    Sean
    Actually, it was 5,608,312 lb/ft at 102rpm. Do you realize that by simply rounding it off to "5.6 million", you are dismissing 8,312 lb/ft of torque as insignificant? :)
