bill's 308 engine project | Page 3 | FerrariChat
Discussion in '308/328' started by bill308, Jul 13, 2018.
  1. Crowndog
    Crowndog F1 Veteran
    Jul 16, 2011
    7,042
    Fairfield,Pa
    Robert
    I have an increased hp 308 and absolutely love it, you will too. I also installed a knock sensor but haven’t used it. Just isn’t needed.
  2. ferrariowner
    ferrariowner Formula 3
    Feb 21, 2014
    1,109
    Mansfield, TX
    Ron
    Bill, I had a lengthy discussion with Motec when I turbocharged my QV about knock sensors (around 2004) They insisted that it was pointless since the knock sensor needed to be calibrated to the engine. Otherwise the knock sensor would interpret certain engine noise (valve gears etc) as knock and retard the ignition needlessly. On their next version of ECU they included a knock sensor (go figure). So I have no experience with knock sensors, but would recommend you look into how the sensor detects knock and if/how it can detect knock without falsing.
    Also, as you noted, a richer fuel mixture does reduce knock to a point. Octane is your friend. Bob Norwood told me that your engine will knock (detonate) before you can hear it. 2-valve engines like more timing advance than 4-valve engines.
    Keep us posted and good luck.
  3. bill308
    bill308 Formula 3
    1,160
    Windsor, CT
    Bill Sebestyen
    Hi Crowndog and ferrariowner,
    Thanks for your feedback.
    I'd love to see a photo of your knock sensor installation. I like the idea of a knock sensor option and my xdi-2 programmable ignition system can read the knock sensor's voltage spike and with an adjustable trigger level. I wish I had a wide band accelerometer and maybe a digital storage oscilloscope to analyze the knock sensor signals at various sensor locations. Some knock sensors are tuned to a nominal 7 khz, others may be tuned to other frequencies. 7 kHz corresponds to the primary theoretical knock frequency for an 84 mm bore. There are both resonant and non resonant sensors. Some knock sensors are tunable.
    I talked to my engine builder and there have been a couple of hiccups. The attempted build up last weekend was aborted because the liner seals were not correct for 328 liners. We will try again this weekend. We need to do a trial assembly to verify deck heights and bore dimensions before we can order the custom pistons. Final valve pockets will be machined on site if necessary. This capability could also give us good control over chamber and intruder volumes. One would like to be able to go further and look at things like how the shape of the combustion chamber and piston crown surfaces affect the flame front propagation. That would be a fun project probably best explored using CFD techniques, although just assuming ignition at the spark plug, the flame front would propagate outward like the layers of an onion, but restricted to the volume between the chamber, piston, and cylinder surfaces. The higher CR should increase squish, for better combustion.
    I'm having discussions with MWE about having some one go through my gear box, but the in-house expert is not available at this time. So, I'm currently looking for someone. One possibility is Miller Motor Cars of Greenwich, Ct, who have a dealership about a block or two from the old Luigi Chinetti (of NART fame) business location. The other thing I learned from my conversation with the service manager is that they go to MWE for their their vintage engine builds.
    I talked to MWE yesterday and he said he had conversations with Miller Motor Cars where the reliability of the transaxle, with the uprated engine, was discussed. My plan is to replace all the bearings, seals, and synchros if possible. Tear down could reveal additional problems. The other issue is the transfer gear system. Apparently there were changes made to the 328 transmission for increased robustness, although it's not yet clear what these changes were. Has anyone reported a transmission failure with an uprated engine? The 1975 GTB engine put out 255 bhp (SAE net) and more importantly 210 ft lbs at 5000 rpm, according to the owner's manual. I'm expecting a max torque of about 300 lb-ft from the new engine. My plan is to also go with a Modena Engineering transfer gear system. Frank says he can do a quiet system that my grand kids will one day drive. Wouldn't that be great?
    Bill
  4. derekw
    derekw Formula 3
    1,520
    London, UK
    Derek W
    I looked into the chamber design a little as in classic Jaguar racing they sometimes machine the chambers a bit bigger to get rid of the small horizontal squish landing and instead have pistons with full diameter domes, squish against the full hemispherical chamber, and a "dished" area around the plugs to have a nice shaped initial combustion space and get away from the orange peel effect on flame propagation. I had some custom forged JE pistons that I picked up from an abandoned turbo project so I just radiused the chamber corners a bit and hand blended the piston landings (for tdc squish clearance) to match the chamber given the valves' movement, head gasket thickness and piston rock. I say "just" but it was very time consuming and I would never do it again (timing system off, heads off, and pistons out about 8-10 times with playdoh cutting and measuring every time!) One thing that is definitely worth the time is blending away sharp corners and thin sections (outside edge of the inlet valve pocket) to reduce hot spots that can cause detonation.
  5. Brian A
    Brian A F1 Rookie
    Dec 21, 2012
    3,086
    SanFrancisco BayArea
    1983 US 308 GTS QV
    I have no experience in this stuff, so please forgive the naïve question:
    Since you are getting custom drop gears machined and also doing a total rebuild of the transaxle, is it possible to change the ratio of a single gear in the transaxle? I am thinking that it would be nice to have a taller 5th gear. Stock 5th is awfully low for highway cruising and is not useful on the track.
  6. bill308
    bill308 Formula 3
    1,160
    Windsor, CT
    Bill Sebestyen
    Hi Brian,
    The primary reason for the custom drop gears is to arrive at a taller 5th gear. The increased spacing between all gears is also a plus assuming greater available torque.
    Bill
  7. bill308
    bill308 Formula 3
    1,160
    Windsor, CT
    Bill Sebestyen
    Hi derekw.
    One of the interesting things I learned from my friend John Stowe is that OEM jaguar engine bore spacing changed over time. The combustion chambers are no longer centered over all bores. John has contracted with the Jaguar Club of the UK to produce a replacement head that, among other things, will correct this geometry problem, improve the metallurgy and perhaps make some other improvements
    I talked with MWE yesterday.
    1. The sleeves are in the block and their bottoms are sealed with special O-rings, because of the machining and geometry.
    2. The crank is in the block and all (std/std) clearances, including rod clearances, are acceptable.
    3. The pistons were defined and ordered last week from JE Pistons I believe. Lead time is 3-4 weeks.
    4. Valves were ordered
    MWE told me their gearbox guy is having health issues and his part time work hours are uncertain. I asked John Henkel at Miller Motocars (Greenwich Ferrari) to go through my transaxle with the intent of replacing all bearings, seals, and synchros. John expressed concern that the drop gear train was not up to the torque of an uprated engine. Ferrari 328’s feature extra outboard bearings for drive the shafts, which earlier 308’s lacked. If I can work a deal for a 3-ratio, quick change, drop gear conversion, the cover is already fitted with the necessary extra bearings. John sent me an email yesterday saying he would be picking up the transaxle from MWE for transport to the Greenwich workshop for an instructional tear down, which I will observe. MWE is doing a Ferrari 250, 12-cylinder for Miller Motor Cars, so transaxle pickup will be a byproduct. Thanks to John and the team at Miller Motor Cars.
    I haven’t heard much about drop gear or transaxle failure or unusual wear. Yet Ferrari clearly saw a need to change the 308 design for the increased torque of the 328. How can it be that all the uprated 308’s running around are not having drivetrain issues? Am I just being paranoid?
    Bill
  8. finnerty
    finnerty F1 World Champ
    May 18, 2004
    10,406
    #58 finnerty, Nov 27, 2018
    Bill,
    FWIW, I studied the transfer gear (308 vs. 328) situation years ago, and discovered a few things.
    1) At one point, early on in the development process, Ferrari had plans to have the 328 engine produce closer to the 300-310 HP range before they dialed it back to the production unit value of approx. 270 HP. The reasons for this are varied, rumored, and unimportant. But, the upshot is that they had already revised the transfer gear / cover configuration to accommodate the increased deflection of the transmission input shaft anticipated for the 300+ HP motor....... so, they just kept it as it was also a nice improvement over the 308 setup in other regards ---- less noisy, more robust, and less stressful on bearings.
    2) No one, to my knowledge --- including Ferrari --- has ever run a proper level of fidelity deflection / load analysis on the input shaft without the extra outboard bearing (308 configuration) to determine at what engine output HP deflection becomes a problem.
    3) That said there are quite a few modified 308s running around with engines producing in the ranges of 300-380 HP (maybe even 400 ?) ---- all with the stock 308 transfer case and gears, and input shaft arrangement.
    I have not heard of any failures (input / transfer), but that does NOT mean they have not occurred. It also could mean that the cars simply have not accumulated enough driving time (wear, stress, and fatigue) for the problem to manifest itself ---- or, perhaps that the owners are not driving the cars hard enough in the critical gears (most likely 3rd and 4th ?) to cause a problem.
    That said, if I were taking one of these engines to 320 or beyond level HP, I would certainly try to accommodate the 328 transfer configuration (additional outboard) into my overall approach ----- particularly if, as in your case, a new cover is already being done. Of course, adding the bearing is easy, the hard part is modifying the stock 308 input shaft to utilize it. And, AFAIK, the input shaft from the stock 328 gearbox does not interchange into the 308 box at all.
    I guess what I am trying to say is that just because no one has identified it to be an issue --- or had an actual failure --- doe NOT necessarily mean that it is not a potential problem needing to be addressed. :)
    I mean, after all, how many modded cars are out there and with how much use ?
    Not many, and not a lot....... so, we don't really have reliable data and evidence to support a strong conclusion either way.
  9. Patrick Dixon
    Patrick Dixon Formula 3
    Mar 27, 2012
    1,084
    I broke two teeth off a transfer gear on my gt4 shortly after I bought it in 1985. No one suggested that it was other than an unusual failure at the time. Standard UK spec engine with (supposedly) 255hp.
    everettmse likes this.
  10. bill308
    bill308 Formula 3
    1,160
    Windsor, CT
    Bill Sebestyen
    Hi finnerty and Patrick,
    Thanks for sharing your experiences and insight.
    I prefer to upgrade to the quick change system rather than convert to the the 328 transaxle. A lot depends on what we find upon tear down. Going in it shifted with effort and one could be at least one of the synchros. The other big concern is the limited slim differential. Individual repair parts generally are not shown in the Parts Catalog. I do see aftermarket friction plates plates here:
    https://www.ebay.com/itm/Ferrari-Limited-Slip-Differential-Autobloccante-Clutch-Plate-kit-Rebuild-set/263501134304?fits=Make%3AFerrari&hash=item3d59e439e0:g:H0kAAOSwl29ahxQw:rk:1:pf:1&frcectupt=true
    I hadn't heard from Frank Capo at Modena Engineering in weeks and was getting concerned, so I called and found out that Frank has been on a European trip for a couple of weeks and would contact me next week. So the quick change option is still viable at this time.
    Bill
  11. Ferraridoc
    Ferraridoc F1 World Champ
    Jun 20, 2012
    16,198
    Gold Coast, Aust.
    Patrick
    Frank is... slow. So long as you're not in a hurry, you'll be fine
  12. derekw
    derekw Formula 3
    1,520
    London, UK
    Derek W
    You can switch the order of the LSD clutch plates if they are worn. I didn’t do it as my diff was still tight and I ran out of time. I’ve heard the spider gears wear if high mileage or hard driven. The silver bullet for drop gear and transaxle preservation are thinner and less sticky tyres :)
  13. ferrariowner
    Feb 21, 2014
    1,109
    Mansfield, TX
    Ron
    I have a 308QV turbo. The dyno registered 509 hp at the wheels back in 2004. So far, I haven't had any transmission or other failures. However, I don't do smoking burnouts or otherwise abuse the car. I suspect repeatedly dumping the clutch a 4000 rpm from a standing start or other shenanigans may produce different results. Bob Norwood told me the week point was the differential. His quote to me was,' you will break that pumpkin off the transmission'. He would know.
  14. Patrick Dixon
    Mar 27, 2012
    1,084
    When I broke my drop gear, they also discovered that the LSD didn't limit slip any more ... it turned out that it had been re-assembled with the plates around the wrong way at some point prior to my ownership.
    The solution was a new diff, I think they were around 300 quid then. I probably should have bought a couple.
  15. bill308
    bill308 Formula 3
    1,160
    Windsor, CT
    Bill Sebestyen
    #65 bill308, Dec 8, 2018
    Hi guys,
    derekw,
    Thanks for the heads up on the potential fit issue with early 308 engines and the round tooth drive pulleys. I asked MWE to check this. Good point on the sticky tires, still there will be more torque available at the flywheel. I hope the spider gears are in good shape. Are these parts even available new, other than as complete assembly? The PC shows 1067869 for the differential assembly. What was your conclusion regarding Swiss Army Vehicle's 7102225611 offering for $275.50 USD? Is this really a suitable ZF1249304278 part (1-3 synchro)?
    Ferrariowner,
    You have lots of bhp with the trubo. Any idea what your max torque is and how often you use it?
    Patrick,
    Are you saying you replaced the entire differential assembly for 300 GBP’s? When did you make the purchase?
    This past week has been about trying to get the transaxle refresh going. I ordered synchros from Algar Ferrari in PA, who have a small quantity on clearance. They are NOS, ribbed type, 150628’s (4-5 gears), were still coated in Cosmoline, and were delivered in about 24-hours. Great job
    I ordered three, 106040 (1-3 gear) synchros from another supplier, who gave a terrific price, but were sadly unavailable at this price. The supplier did offer to supply these parts at a much higher price, but I declined and cancelled this order. So I’m back to looking for 106040 synchros at the best available price. A review of postings has not shown a clear alternative to the Factory part. Smg2 sugggested equivalent pieces made by RBT may be made of a different material, as the GT40 ran in different oil? What gearbox did the GT40 run?
    derekw suggest s ZF part numbers 1249304278 or 1249304570 may be suitable for the 1-3 synchros. IndyGuy posted ZF part number 1031.304.153 and 1031.302.177 were internal ZF numbers for the Ferrari 1-3 and 4-5 synchros, respectively. I want to replace all synchros with new, so I need three 106040 (1-3) synchros.
    Anybody have 106040's on the shelf?
    Bill
  16. Patrick Dixon
    Mar 27, 2012
    1,084
    1985! We need a time machine.
  17. derekw
    derekw Formula 3
    1,520
    London, UK
    Derek W
    Hi Bill,
    I have some stainless spacers for the lower round-tooth pulleys in case you have the older outside seal on the cam drives. Let me know if you need them and I'll pop them in the post. Yes the Swiss army synchros fit perfectly. Easiest way to solve the torque through the drivetrain issue is don't use such fat and sticky tyres. I broke about 3 diffs in my souped-up Triumph GT6 before I switched to harder rubber :)
  18. Ferraridoc
    Jun 20, 2012
    16,198
    Gold Coast, Aust.
    Patrick
    Yep. On my tarmac rally Elan, put a race engine in: broke a drive shaft. New drive shafts machined out of tool steel: stripped second gear. New Quaife SCCR dog box: broke the tail shaft. This happened over several years, with the tyres getting stickier and stickier. I now ease off the line for a rally stage, but last month used a drag start at a hillclimb (very slippery off the start pad). Current rear tyres Yoko A 048 R softs in 205/60 13
  19. bill308
    bill308 Formula 3
    1,160
    Windsor, CT
    Bill Sebestyen
    Hi derekw and Ferraridoc,
    Thanks for the heads up on the spacers. I've asked my engine builder to check the drive pulleys but it may be premature, as we are early in the assembly stage, waiting for pistons to be delivered. Did you put the Swiss Army synchros in your tranny and are they indeed made by ZF? One supplier can offer both ZF and a less expensive Chinese sourced version. They recommended the real ZF part. I was looking for a GT6 back in the 1979 when I came across a 1966 Lotus Elan, S2, SE, RHD, and bought it instead. Your point about the high loads resulting from sticky tires is taken. My 26R uses an all aluminum T9 transmission with a custom gear set and special, shock absorbing drive shaft, CV joints and high strength output shafts and axles.
    Bill
  20. derekw
    derekw Formula 3
    1,520
    London, UK
    Derek W
    The Swiss army synchro I used for 2nd was indeed ZF and some iron alloy. I also found some bronze Escort rally synchro copies from China which looked well made but probably wear faster and given the work to change them I went with the OEM synchro.
  21. bill308
    bill308 Formula 3
    1,160
    Windsor, CT
    Bill Sebestyen
    Hi derekw,
    I just got back from a 2 week holiday in Orlando.
    Did you write down the ZF number from the Swiss Army synchros?
    The folks at Miller Motor Cars tore down my transaxle while I was away. Basically, it's a piece of junk. Extensive internal corrosion, abnormal wear, and broken (synchro spring) pieces. The diff pieces were even worse. Lee at Miller Motor Cars made a multiple videos of his evaluation of all the major pieces.
    I'm on a search for a replacement transaxle core, where I will replace all the usual stuff to bring it up to snuff. I talked to Bill Young of GTCP today and he recommended a late 328 transaxle for my application. I'm not sure about clutch actuation, is it cable or hydraulic on the 328? The speedo sender is the later type so incompatible with my speedometer. Compatibility is gained by replacing my Speedometer with a later type. The benefits one gains with a 328 transaxle are a stronger drop gear system, the taller euro, 1st and 5th gears, and a pump driven lubrication system, . A quick change transfer gear system is now easier to do, but maybe not so necessary for strength.
    Bill
  22. hyenahf
    hyenahf F1 Rookie
    May 25, 2004
    2,603
    Hi bill
    Cool project of yours
    328 clutch cable... mondial 3.2 hydraulic
    328 red speedo graphics. You can have Pali Alto Speedometer change the faceplate graphics to white with redline of your choosing
    I’m not sure of the quality anymore since they have been under new ownership for awhile now. There previous work was stunning but it took a LONG time for them to complete your order depending on the type work or restoration needed.
    Cheers
  23. bill308
    bill308 Formula 3
    1,160
    Windsor, CT
    Bill Sebestyen
    Hi hyenahf,
    Have you done a 308 on a 328 trans?
    It looks like all the 328's cable operated clutches. I need a 328 clutch cable?
    I had Palo Alto Speedometer do a 180 mph face on my current speedometer. It works and looks great. I'm thinking a replacement speedometer from an i or QV might work as I believe these models use a magnetic speedo sender. How about Nisongers in NY?
    Bill
  24. hyenahf
    hyenahf F1 Rookie
    May 25, 2004
    2,603
    no have havent done a 328 trans to 308 swap but was considering it because formula GT in germany has hydraulic conversion for clutch on the 308s. why not just swap out the trans for a 328 and just do the pedal MC portion i was thinking. to be honest, i dont think there is anything wrong with the cable clutches. old 308s pedal pressures arent bad at all. the 355 and 360 clutches feel like honda accords to me.
    I also havent any experience with Nisongers speedometers. they are kind specialist in the English gauges right? there is also North Hollywood Speedo that might be able to help you.
  25. Fabspeed Motorsport
    Sponsor
    Feb 5, 2009
    3,059
    Fort Washington, PA
    John S
    Let us know if you have any questions on the exhaust side of things! May be a good time to upgrade the cats or do a recore if that’s something you would be interested in for added power and sound without affecting the oem look.
