Birdman Fuse blocks - what fuses? | FerrariChat
Discussion in '308/328' started by KershIrl, Nov 30, 2009.
  1. KershIrl
    KershIrl Karting
    Aug 10, 2004
    92
    Dublin, Ireland
    Stephen
    Hope to have my Birdman fuse blocks soon. But since my car is in storage far away from my house, I want to buy the correct quantity of fuses of the correct rating. So I will have everything here. How many of each rating fuse do I need?
    Im in Ireland so where is the best place to get them? Has anyone sourced them in the UK?
  2. DavidB_SD
    DavidB_SD Karting
    Sep 7, 2008
    63
    San Diego, CA
    David B
    I looked at this just last week on a '75 308 gt/4 (don't know if there are any differences from your car). I got this information from the top of the factory fuse block covers.
    6 fuses @ 25 Amps
    4 fuses @ 16 Amps
    8 fuses @ 8 Amps
    -David
  3. Paul_308
    Paul_308 Formula 3
    Mar 12, 2004
    2,345
    I concur with the quantities for the 308 2V thru 1980. You will want spare fuses! And not just 1 each.
    The AGC type fuse is often sold in boxes of 5. Common manufacturer is Bussman.
    These AGC fuses were used in the US for 50-60 years of electronic and automotive use, so you should find UK sources without trouble. RadioShack had franchise stores in UK...try auto supply houses also.
    More fuse info: http://www.happcontrols.com/electrical_supplies/49034900.htm
    Note they are 250V FastBlow. If you find them w/ceramic bodies, good also.
    _________________________
    http://www.ferraridiagrams.com
  4. Crazyhorse
    Crazyhorse Formula Junior
    Jul 23, 2007
    450
    Mooresville,Nc (Race
    Bill Long
    FWIW, you'll probably find 15a AGC fuses like i did instead of 16a euro type,works fine.Like Paul mentioned,get spares.
    B.
  5. KershIrl
    KershIrl Karting
    Aug 10, 2004
    92
    Dublin, Ireland
    Stephen
    Super, many thanks for the replies guys, much appreciated,
  6. Formula Uno
    Formula Uno F1 Veteran
    Oct 8, 2008
    6,659
    New York City
    I just ordered Birdman's fusebox as well and expect it this week. For my 1980 GTSI, which fuses do I need? Same as posted above by David?
    Thanks!
  7. Paul_308
    Paul_308 Formula 3
    Mar 12, 2004
    2,345
    Woke up in the middle of last night realizing I didn't recommend amperages. You can't get an 8A or 16A AGC fuse. Although 7.5A and 25 were made they won't be found so use 10A and 20A for those. For the 8A use a 10A AGC.
    Revised fuse usage + spares (3 each min)
    6 - 20A
    4 - 15A
    10- 10A
    Actually I used self-resetting circuit breakers in the spot for my window 25A fuses.
  8. Birdman
    Birdman F1 Veteran
    Jun 20, 2003
    6,689
    North shore, MA
    THE Birdman
    I don't know about Europe but in the USA, AGC fuses are cheap as dirt and available in any NAPA, Wal-mart automotive section, or Pep Boys. Just get a couple packs of the 8, 15 and 25 AMP fuses. You can check your owners manual for the numbers of each, or just look at the covers on the OEM blocks. PLEASE just read the directions on my site carefully. No rocket science, but it eliminates a lot of questions that are already answered if you read the instructions!
    http://www.birdmanferrari.com/fuseblock_install.htm
    Of course, if you get stuck, e-mail me!
    Birdman
  9. Dino246gt
    Dino246gt Formula 3
    Mar 26, 2007
    1,038
    Winnipeg, Manitoba,
    Dennis Ezmerlian
    #9 Dino246gt, Dec 4, 2009
    Here's 3 pics showing how I replaced mine, it was very easy and I've never had to replace a fuse since, that's 4 years now, thanks Birdman!!! First pic shows crappy original, I numbered the connections T for top, and some arrows for bottoms, some have 2 connections so I made my own code. The new fuse blocks are nice, simple, neat and use the better, more easily available fuses. You'll notice an immediate improvement of just about everything, well I sure did! It took me less than a leisurely hour, so do it and enjoy!
    Ciao, Dino
  10. Paul_308
    Paul_308 Formula 3
    Mar 12, 2004
    2,345
    Dino - photo hint...to eliminate the nasty flash hot spots. When you are up close there is plenty of light. Try putting a sheet of white paper over the flash to spread the beam. And many times simply using ambient light or trouble light will produce a superior picture than the flash.
    Glad you posted those pics...they sure show how much the area is cleaned up with the new fuseblocks.
    Birdman, if you're there, ever stop to consider if you or anyone else hadn't provided replacement fuseblocks, how the market for 308s would be affected. Don't know how many you've made against the 15K 308 cars out there but knowing sellers would be wise to advertise 'my car has new this and that and Birdman blocks'.
  11. RVIDRCI
    RVIDRCI Formula 3
    Dec 1, 2005
    1,576
    Long Beach / Phoenix
    Luigi
    Good point !! Hands down THE most bang for the buck 308 resto-mod. Thanks again Birdman!
  12. Birdman
    Birdman F1 Veteran
    Jun 20, 2003
    6,689
    North shore, MA
    THE Birdman
    Thanks guys! There are a lot of 308s out there with my fuseblocks in them. But a long way to go until I have them in all the 308s. ;)
    It's funny because every now and then I see a car on eBay and it mentions the "Birdman's Fuseblocks." I have to laugh because I can't imagine what a potential buyer is thinking. "Birdman fuseblocks? WTF is that?"
    It can be a pain building them when I get behind after a long business trip and I have hours and hours of sitting in the basement assembling them. But I get great satisfaction when someone e-mails me back and say they fixed something on the car. I know they made a huge difference on my car which was absolutely plagued with issues in the fusebox. Pretty cheap peace of mind I think. Anyone driving around with the OEM blocks in their car is nuts. They suck so bad!! It's not if but when will you be stranded.
    Birdman
  13. Dino246gt
    Dino246gt Formula 3
    Mar 26, 2007
    1,038
    Winnipeg, Manitoba,
    Dennis Ezmerlian
    Thanks for the photo hint, it must be my renovation background, I always try to make the "before" pic look as bad as possible, then the "after" one all nice and clear, heh heh heh.Cheers, Dino
  14. KershIrl
    KershIrl Karting
    Aug 10, 2004
    92
    Dublin, Ireland
    Stephen
    wa-haey . . all fitted, very easy to do, all worked perfect, brighter dash lights now,
    Thanks Birdman, and thank you all for your replies and help, much appreciated :)
  15. Birdman
    Birdman F1 Veteran
    Jun 20, 2003
    6,689
    North shore, MA
    THE Birdman
    You're welcome!
  16. spiderseeker
    spiderseeker Formula 3
    Jul 22, 2005
    1,718
    Colorado
    Steve
    #16 spiderseeker, Dec 15, 2009
