Birdman Fusebox cover | FerrariChat
Discussion in '308/328' started by cls, Oct 10, 2016.
  1. cls
    cls Formula 3
    Jun 12, 2007
    1,663
    Los Angeles/Montreal
    Chris
    #1 cls, Oct 10, 2016
  2. Todd308TR
    Todd308TR F1 World Champ
    Nov 25, 2010
    11,074
    LA
    Todd
  3. Birdman
    Birdman F1 Veteran
    Jun 20, 2003
    6,689
    North shore, MA
    THE Birdman
  4. chas-3
    chas-3 Formula 3
    1,281
    Colorado
    Chuck
    Wow! Nicely done. And willing to donate the 3D model! You are an amazing member of this community. :)
  5. PDB
    PDB Formula Junior
    Feb 1, 2011
    602
    Leicestershire, UK
    Paul
    I've just taken delivery of my new fuse boxes from forum member Samsaprunoff. They're really nicely made, one in black and the other in white as per original but take modern blade fuses.
    They also accept the original covers and are keyed so that you can't put the wrong cover on the wrong panel.
    I currently have the Birdman fuseboxes fitted, but the previous owner didn't do a very good job and I don't like the glass fuses.
    Paul
  6. SteveG75
    SteveG75 Formula Junior
    Nov 23, 2010
    380
    FL
    Stephen
    OK, we need more information about these blade fuse boxes.
  7. cls
    cls Formula 3
    Jun 12, 2007
    1,663
    Chris
    #7 cls, Oct 11, 2016
    The model has been updated slightly for an acrylic version (it has small cutouts that match the original.) I was worried that the 3d printed version would be too brittle for the cutouts.
    dmayoort likes this.
  8. robo330
    robo330 Formula Junior
    Apr 15, 2014
    608
    Michigan USA
    Karl Robertson
    After I bought Birdman's Fuse Blocks and installed them, I made up the graphics for the circuits, made up a set of decals and fixed them to the Trim Cover. This is because Jonathan's Fuse Blocks do not have covers. With the glass fuses they did not need covers. I think they could be used for these covers. They may need to be adjusted in size, but I am sure that could be done very easily. If interested, let me know and I will attach / send a file here. Let me know, as I sent a copy to Jonathan already.
  9. robo330
    Apr 15, 2014
    608
    Michigan USA
    Karl Robertson
    #9 robo330, Oct 11, 2016
  10. fastradio
    fastradio F1 Rookie
    Apr 26, 2006
    3,664
    New England
    David Feinberg
    A nice addition to a great product...
  11. robo330
    Apr 15, 2014
    608
    Michigan USA
    Karl Robertson
    #11 robo330, Oct 12, 2016
  12. samsaprunoff
    samsaprunoff F1 Rookie
    4,465
    Edmonton, AB Canada
    Sam Saprunoff
  13. samsaprunoff
    4,465
    Edmonton, AB Canada
    Sam Saprunoff
    Good day
    Indeed, nicely done!
    Cheers,
    Sam
  14. Birdman
    Birdman F1 Veteran
    Jun 20, 2003
    6,689
    North shore, MA
    THE Birdman
    Hey Chris, awesome cover! Can they do it in a clear material like the original?
  15. cls
    cls Formula 3
    Jun 12, 2007
    1,663
    Chris
    3d printed, no, there's no clear. There is a frosted acrylic that would be closest. I have white ones on my car with the original aluminum labels attached. If I did it again, I would print in black.
  16. PDB
    PDB Formula Junior
    Feb 1, 2011
    602
    Leicestershire, UK
    Paul
    #16 PDB, Nov 23, 2016
    Having clear covers is of no real value over opaque covers because the labels prevent you from seeing the fuses in any case.
    I've installed Sam's fuse boxes and fitted them with LED blade fuses, so that if one blows, it will be readily visible.
    Paul
  17. Patrick Dixon
    Patrick Dixon Formula 3
    Mar 27, 2012
    1,131
    The white & black thing - what's that all about? I think my gt4 has both the same colour but I can't remember which.
  18. Mike C
    Mike C F1 Veteran
    Aug 3, 2002
    6,081
    Southeast USA
    Mike Charness
  19. PDB
    PDB Formula Junior
    Feb 1, 2011
    602
    Leicestershire, UK
    Paul
  20. Mike C
    Mike C F1 Veteran
    Aug 3, 2002
    6,081
    Southeast USA
    Mike Charness
    Oh -- I hadn't noticed that. My originals are in a box in the garage :)
  21. Birdman
    Birdman F1 Veteran
    Jun 20, 2003
    6,689
    North shore, MA
    THE Birdman
    You are absolutely right. But by that same logic, having covers at all is of no real value. The covers were originally designed to prevent the OEM fuses (with exposed fusible links) from throwing molten lead around the interior. With glass fuses, the covers really have no purpose at all. The only reason people want them is for an OEM look. To get that look, the covers need to be clear.
  22. tinterow
    tinterow Formula 3
    Nov 1, 2014
    1,339
    Houston, Tx
    Chaya Tinterow
    Also, you have to take the interior trim panel off to see the clear covers...and I can't believe the hassle involved in taking the clear cover with labels off to check the fuses :)
  23. cls
    cls Formula 3
    Jun 12, 2007
    1,663
    Chris
    I like the covers because it's nice to have the labels for reference.
    And yes, it would be nice to see an OEM look, but oh well.
  24. PDB
    PDB Formula Junior
    Feb 1, 2011
    602
    Leicestershire, UK
    Paul
    I have a Series I GT4 and it doesn't have a trim panel over the fuse boxes so the covers do provide valuable protection for the fuses and connections.
    If it should have a trim panel covering the fuses, could someone post a picture please.
    Paul
  25. BigTex
    79,386
    Houston, Texas
    Bubba
    The white and black bases, I would assume, is because the buss work on the back of the units is not the same?
