Birdman's Fuse Blocks | Page 2 | FerrariChat
Discussion in '308/328' started by Jbryant, Feb 25, 2007.
  1. Birdman
    Birdman F1 Veteran
    Jun 20, 2003
    6,689
    North shore, MA
    THE Birdman
    That is definitely the weak link in the injected cars. (The fuel pump in the carb cars doesn't draw as much current and isn't as bad.) More people in injected 308s are stranded because of the fuel pump fuse than anything else. Even our great leader Verell once had to get out and push (with his wife!) when his fuel pump circuit stopped working.
    The carb cars seem to melt on the right side of the right fuseblock on the circuit that drives the radiator fans (and the injected cars often melt this circuit as well).
    Birdman
  2. Pizzaman Chris
    Pizzaman Chris F1 Rookie
    Mar 13, 2005
    3,919
    New Hampshire
    Pizzaman Chris
    #27 Pizzaman Chris, Feb 28, 2007
  3. sam231
    sam231 Formula Junior
    Aug 5, 2004
    569
    RI
    Hey Birdman, I guess we are all going to have to bow down to you at the next Route 1A "Coffee Clatch." Well done. Wish my car's electrics could use your straight forward solution. The whole Community thanks you for your service.
    Sam
  4. Hans
    Hans F1 Veteran
    Feb 17, 2006
    7,734
    Hilversum, Netherlands
    Hans Teijgeler
    One question on these: How are GT4 guys like myself supposed to actually get to the fuses?? The ones in mine are buried somewhere deep behind the glove compartment. Top wires sticking out inside the glove compartment, bottom ones nearly impossible to reach...
    All I see is those neat photos with everything neatly exposed (guess that's on the GTB/GTS).
    Any GT4 jockeys out there who can comment on this?
    Hans
    (1974 308GT4)
  5. M.James
    M.James F1 Rookie
    Jun 6, 2003
    2,721
    Worcester, MA
    Michael.C.James
    Someone mentioned replacing relays as well as fuses - I second that, but two points:
    1. There are relays on the Jetronic Computer board (right rear trunk well) - one of them, on the newer cars, is a special Lambda relay. It can be sourced from a Porsche 928, but it ain't cheap: $120. This area can be subject to moisture/corrosion, so you might want to look back there.....
    2. Be VERY careful re-inserting relays to the relay board on the dash - pushing relays IN can also push the connector leads on the rear of the relay board OUT, resulting in poor contact with the relay pins themselves.
  6. BwanaJoe
    BwanaJoe Formula 3
    Oct 23, 2006
    1,764
    Former Space Coast
    Joe Burlein
    Thanks. Hadn't thought about that and I am about to change out my dash relays.
    Joe
  7. roccopof
    roccopof Karting
    Jul 10, 2006
    113
    Oakland
    Rocco
    I installed Birdman's fuseblock in my '75 GT4. It took a lot of patience to work in the cramped glove compartement, but it's possible. Have'nt had any electrical issues since.
    Rocco
  8. Birdman
    Birdman F1 Veteran
    Jun 20, 2003
    6,689
    North shore, MA
    THE Birdman
    I have never installed them myself in a GT4 so I have no idea how tricky it is. I can say that I'm told there is a lot less space to work in there!!
    Birdman
  9. roccopof
    roccopof Karting
    Jul 10, 2006
    113
    Oakland
    Rocco
    #34 roccopof, Feb 28, 2007
  10. 78-308gt4
    78-308gt4 Formula Junior
    May 22, 2005
    735
    Memphis, TN
    The later series gt4s have the fusebox relocated to underneath the glove box rather than in/behind it. Very easy access and plenty of room to work.
  11. Paul308
    Paul308 Formula Junior
    Apr 24, 2006
    289
    Paul
    I'm ordering my Birdman fuseblocks for my '85 GTS QV. The fuel pump fuse blew on me last summer so clearly I want to do what I can to improve the electrical system in my car. Besides, it's a fun hour long project and this is one that I don't have to climb under the car to do! :)
    Paul
  12. enjoythemusic
    enjoythemusic F1 World Champ
    Apr 20, 2002
    10,676
    Worldwide
    Steven
    Just do it!!! Amazing how just cahnging to Birdman's will upgrade things in many ways.
  13. miketuason
    miketuason F1 World Champ
    Feb 24, 2006
    15,849
    Cerritos, CA.
    How would you know what amp to use for each slot, Is this info in the OM? Sorry for the dumb question.
  14. Hans
    Hans F1 Veteran
    Feb 17, 2006
    7,734
    Hans Teijgeler
    Mine is a 1974 series 1, so indeed in/behind it.
    Just wondering if it would be possible to relocate the boxes myself... I guess I'd have to see about that.
    Hans
  15. spiderseeker
    spiderseeker Formula 3
    Jul 22, 2005
    1,718
    Colorado
    Steve
    I think the fuse sizes are listed on the inside of the fuse cover.
  16. John Harry
    John Harry Formula Junior
    Sep 8, 2005
    328
    Pittsburgh PA
    John Harry
    For my ’83 QV the amps for each fuse are on the fuse box covers and also in the Owner’s Manual.
  17. miketuason
    Feb 24, 2006
    15,849
    Cerritos, CA.
    Thanks John
  18. fishing
    fishing Karting
    Sep 3, 2006
    137
    Norway
    Harald
    Does the fuse box covers fit to Birdmans fuse block?
  19. Perfusion
    Perfusion F1 Rookie
    Oct 16, 2004
    4,151
    Marietta, GA
    Aaron
    You mean the clear plastic ones? No...unfortunately not. If you mean the actual portion of the *dash* that the fuseblocks hide behind, it still fits without issue.
  20. Birdman
    Birdman F1 Veteran
    Jun 20, 2003
    6,689
    North shore, MA
    THE Birdman
    Rocco, thanks for the cool pic.
    Birdman
