Birdmans Fuse blocks | FerrariChat
Discussion in '308/328' started by mike308gts, May 27, 2007.
  1. mike308gts
    mike308gts Karting
    Aug 28, 2006
    97
    Washington NJ
    Michael
    I finished installing Birdmans fuse blocks, They were very easy to do. I don't think it took me a half hour. Anyone who has doubts about doing it should not. Follow the instructions and number them and you won't have any problems. I took pictures before I removed the wires just in case I messed something up! Thanks Birdman for a great upgrade.
  2. Pizzaman Chris
    Pizzaman Chris F1 Rookie
    Mar 13, 2005
    3,919
    New Hampshire
    Pizzaman Chris
    Looks good job Mike.
    I had the Birdman install mine while i stood on the sidelines watching.
    Like you said, it is very easy to install.
    BTW What was/or almost fryed?
  3. spiderseeker
    spiderseeker Formula 3
    Jul 22, 2005
    1,718
    Colorado
    Steve
    Birdman must have sold a thousand of those fuse blocks and saved hundreds of cars from serious electrical problems.
    Great invention at a reasonable price.
    (now I just need to get a couple of his mat-grabbers)
  4. mike308gts
    mike308gts Karting
    Aug 28, 2006
    97
    Washington NJ
    Michael
    Someone hooked up an amp for the radio to the headlite motor circuit and fried the block. I removed the amp. I would rather listen to the Webers!!!!
  5. D.Mauro
    D.Mauro Formula 3
    Jun 18, 2006
    1,266
    Cumming/ Hlwd Fl
    Dominick
  6. Bad Dogg
    Bad Dogg Formula Junior
    Sep 29, 2006
    433
    Avon, CT
    Howard
    Do these work on the 3.2?
    Thx
    H
  7. John Harry
    John Harry Formula Junior
    Sep 8, 2005
    328
    Pittsburgh PA
    John Harry
    Birdman’s web site (http://www.birdmanferrari.com/) says “These blocks DO NOT work on the Mondial, 328 or 246 Dino. They used entirely different fuseboxes that are incompatible with these.”
  8. Mike C
    Mike C F1 Veteran Lifetime Rossa Owner
    Aug 3, 2002
    6,081
    Southeast USA
    Mike Charness
    Jonathan didn't invent the fuse block replacement, but he *DID* bring it to the masses for those of us who didn't want to make our own, and for that we're all grateful!
    Got to give credit where credit is due:
    http://70.85.40.84/~ferrari/discus/messages/112/307297.html
  9. spiderseeker
    Jul 22, 2005
    1,718
    Colorado
    Steve
    Sorry, wrong choice of words. (maybe I should have said great product)
    I actually built mine from the link that you posted, about 18mos ago. (I think I assumed it was Birdman's creation)
  10. rolster
    rolster Rookie
    Oct 11, 2007
    39
    Roquebrune c Martin
    Roland
    Just installed the "Birdman fuse blocks" into my 1983 euro GTS QV
    What a difference it has made and very easy to install: disconnected the battery on the ground connecter under the bonnet; Then marked the connectors with a marker pen; Then transfered the upper connectors to the top side of the birdman blocks; unscrewed the old fuse blocks and let them hang on the lower connectors; screwed in the Birdman blocks and then transfered the lower connectors. The correct fuses were a bit hard to find overhere but our 30mm glass fuse versions fit and work well (same diameter just 2mm shorter).
    Now the speedo doesn't wobble around and cut in and out!
    I can see the instruments at night!
    The windows work faster!
    The headlights have gone from a candle yellow glow to something approaching white light! (cibie and relay upgrade soon)
    pic of installation for the record.
  11. jeffQV
    jeffQV F1 Rookie
    Feb 13, 2004
    2,976
    NZ
    jeff
    so when is the fuse block for the mondi's going to be ready....please!
