Biscottino per barra done broke | FerrariChat
Discussion in '308/328' started by Irishman, Jan 6, 2008.
  1. Irishman
    Irishman F1 Rookie
    Oct 13, 2005
    3,533
    Raleigh
    Kevin
    #1 Irishman, Jan 6, 2008
    Just going by the name in my parts catalog. This part is at the right rear wheel connected to the stabilizer link. Is it something I will be able to find?
    Thanks,
    Seamus
  2. jimshadow
    jimshadow F1 Veteran
    Feb 19, 2006
    6,268
    Indiana/North Carolina
    JIM
    They pop up on Ebay from time to time...Last ones I saw were $150/pr...
    Typically referred to as "drop links"...
    How did you break it?
    JIM
  3. davebdave
    davebdave Formula 3
    Mar 18, 2007
    2,381
    Northern VA
    Dave W
    ooooooh, that hurts just looking at it.
    Good luck, dave
  4. alberto
    alberto Formula 3
    Aug 25, 2001
    2,404
    San Diego
    Alberto
    Wow, how the heck did you do that?
  5. greg328
    greg328 F1 Rookie
    Nov 17, 2003
    4,209
    Austin, TX USA
    Greg
    I may have a set in the garage, I'll check..
    Greg
  6. Jdubbya
    Jdubbya The $10 Trillion Man
    43,942
    Hell's waiting room
    I had a complete spare set but I sold them all to Jim. They are available from the dealer parts department but be prepared to pay for it. I'd check with Daniel and usual sources first.
    My car showed up with one broken when I bought it. I think I paid about $400 for the drop link, bushing and grommets (IIRC and that was 4 years ago).
  7. jimshadow
    Feb 19, 2006
    6,268
    JIM
    I have the rears on my car, but the fronts are available with the sway bar. They are for a 308GTS...
    I havent seen any rears on Ebay lately.
    JIM
  8. Hans
    Hans F1 Veteran
    Feb 17, 2006
    7,734
    Hilversum, Netherlands
    Hans Teijgeler
    #8 Hans, Jan 7, 2008
    Have a look at the aftermarket anti rollbars. These typically use two bearings on a piece of rod end, at a 90 degree angle.
    MUCH cheaper, readily available and adjustable
    For want of a better picture:
  9. Irishman
    Irishman F1 Rookie
    Oct 13, 2005
    3,533
    Raleigh
    Kevin
    I did it in my driveway of all places. There is a little culvert on one end. The wheel didn't drop off much, but it was enough. Pretty dumb :(. Should have read the "backing in" post.
  10. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,824
    The twilight zone
    I have a pair I can't use because my extra wide wheels run into them. $200 and they're yours.
  11. barcheta
    barcheta F1 Rookie
    Nov 15, 2003
    3,738
    Maryland
    Jim
    dang! some crazy glue will fix that right up! :) Sorry.... but at least it happened at your house and not 2 or 300 miles away. Give Nick at Forza Ferrari a call he may be able to help.
  12. Verell
    Verell F1 Veteran
    May 5, 2001
    7,027
    Groton, MA
    Verell Boaen
    Go to the parts sources stickie & look up the places that part out F*s.
    Hans,
    That type of end is commonly called a 'Heim joint' or sometimes called a 'spherical bearing'.
  13. Irishman
    Irishman F1 Rookie
    Oct 13, 2005
    3,533
    Raleigh
    Kevin
    Any idea what is press fit here? Am I going to have to order a bushing kit, too?
  14. Spitfire
    Spitfire Formula 3
    Nov 16, 2006
    1,602
    Not that I can help with a replacement, but I do have a question!
    As part of my suspension rebuild I just started looking at my drop links yesterday. I've got new "Silent Block" bushings for them and would like to know what the trick is for removing the old ones (and inserting the new ones). These silent blocks are different from the other suspension bushings in that they slide in in their own steel collar -- they appear to be a more difficult replacement than the others that I've tackled.
    Thanks as ever for sharing your collective wisdom with me.
  15. Jdubbya
    43,942
    Hell's waiting room
    Yes they are a press fit. Any standard shop press should be able to do it. I just happened to have access to a skilled worker and about a 200 ton press at work when I did mine but a much smaller press will do it I'm sure.
  16. chrismorse
    chrismorse Formula 3
    Feb 16, 2004
    2,150
    way north california
    chris morse
    Hi Seamus,
    The easy way is to look for a good set of used drop links.
    I bought some bigger sway bars from a very helpfull chatter, without links. If you look at the aftermarket bars, they use "Heim joints", as Verell mentioned. These are almost bullet proof. The upside is that they are likely cheaper than buying used, (certainly cheaper than new), They will likely never wear out and they will make the sway bar more effective because there is no rubber damping. The downside is that they are not orriginal and may contribute an itsy bitsy bit of harshness to the ride because they are not isolated by rubber.
    So, here is what i did, i measured the lower controll arm stud and the sway bar end that mounts the link, ordered a pair of male and female end links that fit together, ( same diameter and thread pitch) and put them on. You may need to play around a bit with washers to obtain the same fitted length across the ball end.
    If this sounds interesting, take a look at the Saner Bars that a lot of members have fitted, or pm me and i will go out and take a few photos and measurements.
    Bona fortuna,
    chris
  17. Hans
    Hans F1 Veteran
    Feb 17, 2006
    7,734
    Hans Teijgeler
  18. Irishman
    Irishman F1 Rookie
    Oct 13, 2005
    3,533
    Raleigh
    Kevin
    #18 Irishman, Jan 9, 2008
    Really appreciate all the help. There has been some progress. First picture shows the removal of the lower half. The goop in the picture is Aerokroil. I could find no evidence of the drop link inner sleeve, but instead only a rusty mess. The washer shown attached in the picture did indeed come off so I take that as a positive sign? The top half, shown still attached, came right off and is shiny smooth underneath.
    Other bummer is the second picture. Used replacement arrived courtesy of one of our usual suppliers, but is not a match :(. Will attempt to rectify that tomorrow.
    Seamus
  19. gerritv
    gerritv Formula 3
    Jun 18, 2001
    1,400
    St Catharines
    Gerrit
    Hi
    The front and rear links are different lengths. Parts manual will show the numbers.
    It looks as if the anti roll bar hit something, thus the link broke (Marks on the lower A arm). One of my links was welded, these are just aluminum (aluminium in some places :)).
    Gerrit
    http://dino308gt4.com
  20. Verell
    Verell F1 Veteran
    May 5, 2001
    7,027
    Groton, MA
    Verell Boaen
    It can be done (barely) with a 3 ton lever type arbor press & a couple of carefully selected sockets. Birdman & I used off the shelf ES poly bushings to replace the silentblocs. See this thread in the old Fchat for the procedure & ES part numbers:
    Replacing rear sway bar bushings (with pics)
    http://www.ferrarichat.com/discus/messages/112/320732.html
    Unfortunately the pics didn't survive the fchat hard drive crash.
  21. Birdman
    Birdman F1 Veteran
    Jun 20, 2003
    6,689
    North shore, MA
    THE Birdman
    Wow, that's an oldie but goodie (The "sway bar adventure...not gay bar!") Too bad the pics were lost.
    Birdman
  22. jimshadow
    Feb 19, 2006
    6,268
    JIM
  23. Irishman
    Irishman F1 Rookie
    Oct 13, 2005
    3,533
    Raleigh
    Kevin
    Well dang. First, I get a "long" one when I need a "short" one. And now the short one doesn't match exactly. So they changed year-to-year? Starting to look like they must be bought, even used, as a matching set.
  24. Irishman
    Irishman F1 Rookie
    Oct 13, 2005
    3,533
    Raleigh
    Kevin
    Okay, if someone 26 can post about going to F1 I can make a reach :).
    It took three tries but I now have my used drop link that matches the one I broke. But what I got is "empty" on the lower end.
    If someone with a '78 happens to read this post and did work with the sway bar, what I am trying to determine is if the two rubber-like cushions that make up the connection with the sway bar are supposed to have a metal sleeve or bushing inserted? There was nothing but rusty dust when I removed the original.
    And, yes, I should be going through all these suspension parts and refreshing them all but had not planned to do that this winter.
    Thanks,
    Seamus
  25. Steve Magnusson
    26,960
