News
Black Arman Wiper Blades For '72 E-Series Dino
Discussion in '206/246' started by 4CamGT, Nov 21, 2011.
  1. 4CamGT
    4CamGT Formula 3
    2,099
    Southern California
    All,
    Could you all give me what is the correct length for the Arman wiper blades? Does anyone have a lead where I can find a new or used black set?
    Freeman
  2. 2GT
    2GT Formula 3
    Aug 25, 2008
    1,755
    Western NY
    Fred
    I believe that there are two lengths, Freeman. My later Dino (04808) has 18" blades. My earlier one (03964) has, if I'm not mistaken, 16" blades. Fred
  3. BigTex
    Rossa Subscribed Owner
    Dec 6, 2002
    70,569
    Houston, Texas
    Bubba
    Did you check with ReOriginals Freeman?
    IIRC they have the right open style arms....
  4. 4CamGT
    4CamGT Formula 3
    2,099
    Southern California
    My collegue's early E-Series has 14" Arman blades that look to be original. I would appreciate more feedback from other Dinos please!
    Freeman
  5. Pooh-Baugh
    Pooh-Baugh Formula Junior
    Sep 3, 2011
    488
    Greencastle Indiana
    Bob
    I have ones that seem to measure 15 inches. Center park blades. *04022*
  6. 2GT
    2GT Formula 3
    Aug 25, 2008
    1,755
    Western NY
    Fred
    Curiously, when I recently called a well-known independent Ferrari parts supplier, they told me that they had non-original blades for a Dino, specified by Ferrari. When I asked if they were 18" in length, they said no. It turned out that they are longer. I have seen pictures of Dinos with parallel wipers, where the right-side wiper is hanging off the edge of the windshield. Presumably these are the "Ferrari-approved" oversized blades. For under $10.00 each, I found replacement blades at my local service station that slipped right into the Arman wiper arms. Fred
  7. simonc
    simonc Formula Junior
    Nov 1, 2003
    847
    Herfordshire, UK
    Simon Campbell
    #7 simonc, Nov 22, 2011
    I found the attached Tech Sheet from the Factory that gives the wiper blade lengths for various Dinos in various country specifications. Hope it is useful.
  8. 500tr
    500tr Formula Junior
    Feb 28, 2004
    781
    Germany
    Volkmar Spielmann
    Perfect, thank you.
  9. 4CamGT
    4CamGT Formula 3
    2,099
    Southern California
    Looks like this is for parallel wipers only from chassis No. 05102? Clapper arm blades I would think would be shorter?
    Freeman
  10. Pooh-Baugh
    Sep 3, 2011
    488
    Greencastle Indiana
    Bob
    If memory is correct you have center/clapper wipers, euro. I still think 14/15s are correct... No way on 18s. I can go measure mine again but they are a shade under 15 inches end to end. *04022*/919body euro
  11. 4CamGT
    4CamGT Formula 3
    2,099
    Southern California
    That sounds similar to my collegue's.
    Freeman
  12. rynoshark
    rynoshark Formula Junior
    921
    Pacific Northwest
    Ryan
    #12 rynoshark, Sep 3, 2013
    Is there a good source for the 16" (or 390mm) Arman black blades these days? The existing Arman blades on my Euro GT #06618 measures approximately 15 1/2 inches (390mm). I suspect the blade was just replaced at some point and was probably 16 inch (per the guide posted above). My passenger side blade is a bit loose/wobbly and has scratched the glass, so I'd like to replace both of them.
    Re-Originals doesn't have the Arman in 16" size (and people have complained about the fit of their wiper blades in other FerrariChat threads).
    Thanks for any leads.
  13. Edward 96GTS
    Edward 96GTS F1 Rookie
    Nov 1, 2003
    3,236
    where to get 18" black arman wiper arms?
    thanks
  14. rynoshark
    921
    Pacific Northwest
    Ryan
    I guess nobody has a source for the correct 16" black blades for a Dino?
  15. rynoshark
    921
    Pacific Northwest
    Ryan
    So...sounds like there isn't a good source for replacement black blades (not just insert)? My passenger side has come loose with age and wobbles about a bit and I'd like to replace it since it has a habit of twisting and scratching the windshield if I'm not careful.
  16. synchro
    synchro F1 Veteran
    Feb 14, 2005
    8,899
    CHNDLR
    Scott
    #16 synchro, Feb 17, 2014
    Thank you, this is incredibly helpful.
    I have 2 Dinos, a Euro with clapping then ~300 VINs later a US with parallel and wondered why the arm lengths and wiper blades are different sizes.
  17. synchro
    synchro F1 Veteran
    Feb 14, 2005
    8,899
    CHNDLR
    Scott
    Arman is marked on both the wiper arm and the wiper blade holder.
    I can grind the glass scratch out for you, LMK
  18. npwmd2
    npwmd2 Karting
    Mar 31, 2015
    137
    Hudson Valley
    Neal
    Definitively, I have never changed my wiper blades, 04124, it measures 380mm, center park.
  19. abstamaria
    abstamaria F1 Rookie
    2,596
    Andres
    Image Unavailable, Please Login My 1972 US spec Dino, S/N 4866, has 18” wipers. The passenger side wiper always bothered me, as it overlaps the windscreen, but I suppose, from Simon‘s spec sheet (many thanks, Simon), that that is the correct length. 16 inches would be much better.
  20. 4redude
    4redude Formula Junior
    Jan 13, 2005
    659
    Someplace new
    Brian Keegan
    A Service Bulletin from FNA dated November 1979.
  21. abstamaria
    2,596
    Andres
