Blackening steel parts | FerrariChat
Discussion in 'Technical Q&A' started by paul 308, Feb 25, 2005.
  1. paul 308
    paul 308 Karting
    Jan 13, 2004
    110
    Guildford, Surrey UK
    Paul Deslandes
    Anyone know a good home diy (safe) method of blackening exposed steel parts, bolts, nuts etc? I have found gun blueing products on US websites but these are not available in the UK as far as I know. I've used phosphoric acid to remove the rust but need something to rustproof coat the surface. I've heated items up to cherry red and quenched in old engine oil in the past but I hate to think what this does to the tensile strength of a bolt!
  2. writerguy
    writerguy F1 Veteran
    Sep 30, 2003
    6,786
    NewRotic
    Otto
    the process is called Blueing
    it is not easy but requires a large vat of acid and really hot metal
    not exactly something for the hobby guy but you might check around some of those odd british men who like to do "Historic Reenactments" and find the Musket guys... Bet they would know...
  3. GavC
    GavC Formula Junior
    May 9, 2004
    492
    Lincolnshire, Englan
    Gavin Culshaw
    Try Frosts Restoration Products I seem to think they did a kit to black plate items. I could be wrong it was a couple of yrs ago
  4. PWehmer
    PWehmer Formula 3
    Oct 15, 2002
    1,733
    Surrounded by Water
    #4 PWehmer, Feb 25, 2005
  5. fletch62
    fletch62 Formula Junior
    Mar 8, 2004
    333
    Fairhope, AL
    Larry Fletcher
    I do my own black oxide and zinc plating. I ordered kits from Caswell. They have been very good to deal with over the past year and half. See thier website www.caswellplating.com Tell them Larry Fletcher sent you.
    PS you will want to test some junk parts to get the feel for black oxide or plating.
    Good Luck
  6. Verell
    Verell F1 Veteran
    May 5, 2001
    7,022
    Groton, MA
    Verell Boaen
  7. paul 308
    paul 308 Karting
    Jan 13, 2004
    110
    Paul Deslandes
    Thanks for the tips guys. Frosts Restoration Products in Lancashire do have a product, which is probably the same as the US sourced ones. I'll give it a go and report back for the UK chaps who may have the same problem.
    Paul
  8. Jayson@IGF
    Jayson@IGF Rookie
    Aug 17, 2004
    27
    Mountain Home, AR
    Jayson Cotter
    Bluing or Black Oxide is pretty nasty stuff, the solution is made up of salts that have to be heated to 300 degrees and they make quite a mess.
    Parkerizing is much more corrosion resistant and easier for a DIY'r to use, in fact I cant think of any current military firearms with blued finishes, but almost all current firearms have a parkerized finish. However the parts come out dark gray instead of black. You could do parkerizing on your stove top with a stainless pot, it only has to be heated to 180 degrees and isnt real messy.
    Brownell's sells the solution here
    http://www.brownells.com/aspx/NS/Store/ProductDetail.aspx?p=1110&title=PARKERIZING+SOLUTION+%26+KIT
    There are some DIY parkerizing recipes on the internet with some searching you could probably find the ingredients and make your own.
  9. Jon22
    Jon22 Karting
    Sep 4, 2004
    110
    Uk
    Jon
    Have a chat with a gunsmith.
    Most shotguns have the barels blued, and there are diy kits.
    Worth a try
  10. Smiles
    Smiles F1 World Champ
    Nov 20, 2003
    16,673
    Pittsburgh, PA
    Matt F
    No need to get it that hot.
    Simply coat the steel with motor oil and heat to 350 degrees F for about ten minutes. (It's similar to seasoning a cast iron skillet.) That temperature will have no effect on the previous heat treatment of the part, but it will leave a nice, durable black finish.
    --Matt
