Bleeding 365 gtc/4 brakes | FerrariChat
Discussion in 'Technical Q&A' started by geffen365gtc/4, May 30, 2007.
  1. geffen365gtc/4
    geffen365gtc/4 Karting
    Mar 12, 2005
    191
    Morning All.....Are there any secrets concerning bleeding the brakes on a c/4??? I've had the rear calipers rebuilt on mine and when I went to bleed the system it seemed like the fluid was not flowing from the master cylinder. I tried both a vacuum pump and the old fashioned pump the pedal method.
    Any ideas????
    Geffen
  2. brian.s
    brian.s F1 Rookie
    Nov 3, 2003
    3,809
    Midwest
    Brian
    You have not mentioned if the hoses were replaced. This was a weak spot on older models and should always be replaced as they close up and severely restrict flow. For bleeding, I use a pressure system, Eastwood sells a reasonable DIY one.
    Brian
  3. 2NA
    2NA F1 World Champ
    Dec 29, 2006
    18,221
    Twin Cities
    Tim Keseluk
    Your hoses may have deteriorated internally. It is not uncommon for brake hoses to become constricted.
  4. tbakowsky
    Sep 18, 2002
    20,012
    The Cold North
    Tom
    As above..but if they are ok..let the system gravity bleed until fluid starts dripping from the open bleeder screws. Then bleed the entire system starting from the cailper furthest away from the master cylinder..RR,LR,RF,LF
