Bleeding Brakes-ABS equipped 328 | FerrariChat
Discussion in '308/328' started by Aircon, Nov 1, 2008.
  1. Aircon
    Aircon Ten Time F1 World Champ
    100,524
    Melbourne, Australia
    Peter
    Is there any special procedure needed to bleed the brakes on ABS equipped 328s? I remember hearing things about cycling the ABS pump etc etc...but not sure if this only applied to later cars. (360 etc)
    Many thanks.
  2. Iain
    Iain F1 Rookie
    Jan 21, 2005
    3,302
    Yep, I was told to use the ABS pump to do the rear brakes only. So you attach your bleed hose, switch the ignition on and get someone to depress & hold the brake pedal between a third and half way to the floor. Fluid doesn't exactly come flying out, its a fairly slow process.
    The front brakes are done the old fashioned way although I prefer to use a pressure bleeder rather than pump the pedal. If you do pump the pedal then put a block of wood under it to stop it going all the way to the floor otherwise you risk damaging the seals in the master cylinder.
    Don't ask me why the difference between the front & rear brakes -its just what I was told to do by my local indy & is what I have done ever since & it seems to have worked OK.
    I.
  3. mike996
    mike996 F1 Veteran
    Jun 14, 2008
    6,828
    Mike 996
    Maybe Ferrari ABS brakes are different but I have been draining/replacing brake fluid in ABS cars since they came out and bleed them just like non-ABS brakes (using a pressure bleeder). Be interested to hear what's different about the Ferrari set up that requires something else.
  4. Mule
    Mule F1 Rookie
    3,758
    Alaska
    Mule
    This is what I got from my dealer for my 89 328:
    Remove wheels
    Fill brake fluid reservoir
    Turn key on (level should drop)
    Top off reservoir again, almost to the top and leave the key on
    Have a helper sit in the car
    Open the bleed screw on the right rear caliper
    Have helper slowly press the brake pedal, after the pedal drops a couple of inches the pump will start to run and fluid will come out. Helper should hold the pedal at that level so pump will continue to run.
    After approximately ¾ of pint has come out, close the bleed screw.
    Now repeat the procedure at the left rear caliper
    After both rear calipers have been bled turn the key off and fill the reservoir to the full mark (seam on tank)
    Now bleed the front brakes manually
    Starting at the right front caliper
    Helper should pump the pedal three times then hold it down
    Open the bleed screw until the pedal reaches the bottom, then close the bleed screw (repeat this process 10 times on each front caliper)
    **While bleeding the front calipers watch level of fluid it may overflow before it starts to go down (because accumulator may release stored fluid) also don’t let level get too low there are three chambers in the reservoir and its hard to watch them all. If the front chamber gets too low you will get air in the system.
    After all four calipers are bled turn the key on when the pump motor stops running turn key off
    Pump the brake pedal 50 times to depressurize the accumulator, watch the fluid level so it doesn’t overflow (use a turkey baster or syringe to suck some out if its going to overflow)
    After the accumulator is depressurized the fluid level should be at the top of the reservoir (bottom of the filler neck)
    Turn key on again after pump stops running the fluid level should now be at the max mark (the seam in the reservoir)
  5. mike996
    mike996 F1 Veteran
    Jun 14, 2008
    6,828
    Mike 996
    Ah...that procedure sounds like one that was used for very early integral ABS brakes so I guess the early Ferraris must have used that type of system. I thought they were gone pretty quickly. BUt I guess 89 was still pretty early for ABS my wife's 87 MB had ABS which was the first car I saw with it - not that others weren't around earlier. You had to do all that to ensure the check valves were in the proper position.
    K L Lim likes this.
  6. jonesdds
    jonesdds Formula 3
    Aug 31, 2006
    2,160
    SB,CA & Park City UT
    Jeff
    Nice write up, thanks for sharing.
    Jeff
  7. mustardfj40
    mustardfj40 Formula 3
    Jun 17, 2004
    1,142
    Northen California
    Ken
    Has anyone actually bled their '89 ABS brake? Any tips to share? The above procedure is simple enough but anything else should I pay extra attention to?
    Thanks in advance.
