Bleeding Brakes! | FerrariChat
Bleeding Brakes!
Discussion in '206/246' started by nerodino, Aug 8, 2009.
  1. nerodino
    nerodino Formula 3
    1,161
    Suffolk UK
    Graham
    I have been trying to bleed my braking system today, Old fashioned way with Son in drivers seat and me with the tube and jar. The complete system is renewed, rebuilt calipers with new pistons new pipework and rebuilt master cylinder. System is split front and rear with two reservoirs. We started bleeding at furthest pipe (UK car so nearside rear) But to no avail,tried offside rear and no fluid there either so did fronts and fluid appeared and we got (so we thought ) all the air out.
    Moved back to rear and hey presto, fluid appeared, So we bled rears and obtained reasonable pedal resistance,
    I drove the car round the drive and the pedal went to the floor!!!
    Bled all again......and again , more air but minimal....but i still have a spongy pedal. Given up for the evening as wife fed up with me in the garage all day (She shouldnt moan as i have to do a round trip Tomorrow with van and trailer of some 200 miles to pick up her new toy......37 year old Fiat 500)
    Any ideas on my brakes.....am i missing something or should i just keep on bleeding away, so to speak.
    Regards, Graham.
  2. jselevan
    jselevan Formula 3
    Nov 2, 2003
    1,873
    Keep on bleeding. After system rebuild, it takes a long time to bleed air out. Make sure reservoir does not go empty, and realize that "firm pedal pressure" with engine off means nothing, as you are feeling the vacuum assist.
    Just keep on bleeding.
    Jim S.
  3. nerodino
    nerodino Formula 3
    1,161
    Suffolk UK
    Graham
    Thanks Jim, will do
  4. Tabletcounter
    Tabletcounter Karting
    Apr 30, 2005
    161
    Cheshire UK
    #4 Tabletcounter, Aug 9, 2009
    Had my Fiat a couple of years now.
  5. celestialcoop
    celestialcoop Formula Junior
    715
    Coop
    #5 celestialcoop, Aug 9, 2009
    John,
    'great looking stablemates. And, to think that they are related, too. :)
    That's a classic shot. Ya brought a smile to my face!
    Cheers,
    Coop
  6. TonyL
    TonyL F1 Rookie
    Sep 27, 2007
    4,202
    Norfolk - UK
    Tony
  7. nerodino
    nerodino Formula 3
    1,161
    Suffolk UK
    Graham
    #7 nerodino, Aug 9, 2009
    John, How are you doing, it,s been a long time since we spoke! Spooky that you have a 500.
    Heres "Luigi" whom we bought back from Maistone today and one of big brother on the trailer arriving back from Tony L's workshop on Thursday where we spent a 13 hour day getting her running for the first time in 5 years.....A big thanks to Tony whom has become a good freind and certainly has far more mechanical knowledge than me.....Thanks for the heads up on the brakes Tony but i have'nt the heart to call on you again for a while! I am sure that i will get there soon with the bleeding and maybe a power bleeder is the way to go.
  8. celestialcoop
    715
    Coop
    #8 celestialcoop, Aug 9, 2009
    Graham...et tu?
    'something in the water there in England? Wow. What's the chance of that? You've a very nice pairing, too.
    John,
    I saw it first time around, but it didn't register. That's an Abarth badge on the front of yours. Hmmm.
    Both,
    I recently bled/flushed the brakes on my friend's Tipo M and my Tipo E. We used a vacuum pump & it worked great. As Jim S. said, keep the reservoirs filled with fluid. Have your son carefully replenish fluid as you work the vac pump. One person can do the job via the pump, but it's way easier with two (and much less chance of getting brake fluid on a painted surface! :( ).
    Good luck; keep us posted,
    Coop
  9. synchro
    synchro F1 Veteran
    Feb 14, 2005
    9,294
    CHNDLR
    Scott
    Gorgeous.
    Congratulations on a major milestone
  10. TonyL
    TonyL F1 Rookie
    Sep 27, 2007
    4,202
    Norfolk - UK
    Tony
    #10 TonyL, Aug 10, 2009
    thanks for you kind words Graham, i did the easy bit, its you that rebuild her completely and as i have told you many times, i could never have done it.
    It was a real privelege to be there and hear her start up for the first time in 5 years...and after only 2 turns of the key. If only the cooling system was that easy.
    tony
    cute 500 too,
  11. nerodino
    nerodino Formula 3
    1,161
    Suffolk UK
    Graham
    Bought a pressure bleeder today(works on around 20psi off spare) good piece of kit worked well........but still got a bleeding spongy pedal....any more ideas?
    Regards G P
  12. TonyL
    TonyL F1 Rookie
    Sep 27, 2007
    4,202
    Norfolk - UK
    Tony
    Its got to be air trapped in the lines,if you are sure its completely removed check the the hydraulic lines are all tight and not leaking. even the slighest minute weep can allow air to be drawn back into the system and give you a spongy pedal.
    Check the flex lines are not expanding under pressure as this can give you a long pedal travel.
    Have you adjusted the master cylinder pushrod properly?
    Have you tried bleeding the master cylinder as well, air can be trapped in this too!! Also try the calipers, if you got carried away with blue grease it could have created a void in the cylinder and trapped air. take them off and bleed them upside down.
    What fluid have you used?
    Does it go down to the floor, spongy when depressed or solid then goes soft. does it pump up after pumping the brake pedal a few times? Does it do it with the engine running and under vacuum? Disconnect the servo vacuum NRV at the engine and it should be under negative pressure
    Tony
    PS:- Have you got four flat tyres on the dino now!! i would use the 500 to do it, then tell Lisa she has four flat tyres!!!!!!!!!!! :)))
  13. nerodino
    nerodino Formula 3
    1,161
    Suffolk UK
    Graham
    Tony, Some good suggestions there which i will try tommorow......or i might just take a leaf out of your book and go and give it a good kicking!!!!
  14. GCalo
    GCalo F1 Veteran
    Sep 15, 2004
    7,645
    Northern California
    Greg Calo
    You might want to try a air powered bleeder such as this one.
    http://www.griotsgarage.com/product/tools/specialty+tools/one-person+brake+bleeder.do
    You still need someone to pump the brakes but you can remove the end they give you with this device and place the tube directly over the bleeder nipple.
    This will pull a good bit but I do a few of these, then a few manual pumps with suction tube attached, then I occassionally remove the tube and use the suction to clear the tube, and repeat as necessary, etc.
    Do all 4 calipers, test the pedal, and if not tight as a drum, do the same at each caliper again.
    Ultimately you'll feel the pedal very tight. A drive will confirm it.
  15. michael bayer
    michael bayer Formula 3
    Aug 4, 2004
    1,293
    Did you replce the flex lines? If not how old are they?
  16. nerodino
    nerodino Formula 3
    1,161
    Suffolk UK
    Graham
    All new
  17. TonyL
    TonyL F1 Rookie
    Sep 27, 2007
    4,202
    Norfolk - UK
    Tony
    Are you still having trouble?
  18. nerodino
    nerodino Formula 3
    1,161
    Suffolk UK
    Graham
    Given up till our friend comes over!
    Have e-mailed you
  19. sowest
    sowest Formula Junior
    Aug 18, 2006
    899
    Hi
    If I could, I would like to add a couple of things to think about. The fact that you did not get fluid out of the rear on your first attempt isn't too unusual. It seems that it is tough to get any movement past the rear brake pressure limiter when the whole system is air bound. When I do a dual system with a rear pressure limiter, I do a preliminary bleed on the front system first. It does seem to cut out some of the frustration.
    The pedal "feel" issue certainly could mean a problem, but these systems usually are quite easy to bleed. When I do a rebuild on a car with calipers that have been in service for a while, I always talk to the owner beforehand about the pedal feel he is going to have when it is all done. The pedal shouldn't feel "spongy" (by my definition), but it will have noticeably longer travel. On the old calipers, the pistons generally are not retracting because of the crud and corrosion. On newly rebuilt calipers, the pistons are fully retracting and the small master cylinder piston has to travel far enough to displace enough fluid to move all of the much larger caliper pistons. This makes for a longer pedal travel and it is disconcerting, at first.
  20. synchro
    synchro F1 Veteran
    Feb 14, 2005
    9,294
    CHNDLR
    Scott
    See OMGjon's prior restoration. I believe he had to prime the rear lines first in order to bleed the system. Lots of info there.
  21. nerodino
    nerodino Formula 3
    1,161
    Suffolk UK
    Graham
    System has NO air in it but still crap pedal.
  22. TonyL
    TonyL F1 Rookie
    Sep 27, 2007
    4,202
    Norfolk - UK
    Tony
    Fit a new pedal then!!!!!!!!!!!
    Seriously i do think because a lot of the components are new, they need to settle and bed in.
    Tony
