Bleeding Clutch Hydraulics Backwards? | FerrariChat
Discussion in 'Technical Q&A' started by UroTrash, Dec 29, 2011.
  1. UroTrash
    Jan 20, 2004
    40,691
    Purgatory
    Clifford Gunboat
    I just removed the master and slave clutch cylinders from my 1975 BMW 2002.
    I should get the new parts tomorrow.
    Easy enough to put every back together.
    I found this thread on a 2002 board. It shows bleeding the clutch circuit backwards. Looks like a great idea. If it works.
    http://www.bmw2002faq.com/content/view/93/32/
    Can you do this, simply pump the fluid thru the slave to the master to the reservoir?
    Thanks!
    Uro.
  2. willrace
    willrace Three Time F1 World Champ
    35,524
    North Tay-has
    Kurt
    In theory, it should work.......but Step 1 is pushing a bunch of air through the slave, and hoping it all gets out as it's filled from the bleeder. I guess the density of pushing the fluid upward should keep things pretty solid.
    I used a Speedbleeder on the Boxer's clutch slave, made life easy, with just little ol' me.
    Whichever you choose, lots of tapping along the route, especially the cylinders.
  3. FerrariDublin
    FerrariDublin F1 Rookie
    Jun 14, 2009
    3,457
    Dublin, Ireland
    Greg
    Never tried priming a system this way. Certainly a typical brake system allows fluid to push back up past the master to the reservoir. We all do it as we push back the caliper pistons to fit new pads for old.
    Is there any benefit to the technique though?
  4. 2NA
    2NA F1 World Champ
    Dec 29, 2006
    18,221
    Twin Cities
    Tim Keseluk
  5. UroTrash
    Jan 20, 2004
    40,691
    Purgatory
    Clifford Gunboat
    Thanks fellas!
  6. UroTrash
    Jan 20, 2004
    40,691
    Purgatory
    Clifford Gunboat
    Benefit is one person can do it.
  7. Ehamilton
    Ehamilton F1 Rookie
    2,759
    Durham, NC; USA
    Eric Hamilton
    Also would avoid the messy and bad things that happen with a pressure bleeder (which is the same one person idea, except done from the reservoir end, as is traditional) when there is a leak anywhere in the normally unpressurized area above the master cylinder.
    One possible downside is that the reservoir could fill before all the air is out. You'd have to stop, siphon the excess out of the reservoir, and then continue.
  8. FerrariDublin
    Jun 14, 2009
    3,457
    Dublin, Ireland
    Greg
    Appreciate that but I meant is there any benefit with reverse filling over pressure filling from the reservoir?
  9. Cribbj
    Cribbj Formula 3
    I've always thought there was merit in trying to push air upwards in its natural direction (from the slave or the calipers back to the master), instead of downward (the conventional way), but the reverse bleeding doesn't seem too popular. Probably because of the potential for dislodging & pushing accumulated grunge up into the master? (like the effects of reverse flushing a cooling system?)
    I've also wondered about fitting a small vacuum pump on the master reservoir and pulling a small vacuum on the system to "pull" entrained air out of it. Would have to be a bit careful not to pull too hard and pop the seals in the system which are rated for high pressure, but probably not rated for vacuum.......
  10. UroTrash
    Jan 20, 2004
    40,691
    Purgatory
    Clifford Gunboat
    Good point about the grunge. I'm replacing the master, slave and connecting line with all new, so that won't be a prob in my particular application.
  11. carguy
    carguy F1 Rookie
    Oct 30, 2002
    3,427
    Alabama (was Mich.)
    Jeff
    Recently I was bleeding the clutch of the Testarossa. I've always used the mity-vac method in the past, but my professional mechanic buddy had a snap-on "push" type bleeder and told me to try it. It did work okay, just don't get too enthusiastic...go slow and easy. Yes there is the possibility of overflowing the reservoir if your not careful. As Mr. EHAMILTON pointed out....you could fill up the reservoir before all the air is out - I never thought of that. All in all....I think I still prefer the vacuum method, or a helper to push the pedal while you operate the bleeder fitting.
