Bleeding Cooling System In 328 | FerrariChat
Discussion in 'Technical Q&A' started by billg, Nov 19, 2011.
  1. billg
    billg Formula Junior
    Jun 7, 2006
    307
    New Orleans
    Bill Grady
    I have a small water leak, necessitating the adding of coolant periodically to the radiator. I understand if it takes more than a cupful or so, I need to bleed the system which is supposed to be within my embarrassingly narrow range of skills. Can someone tell me how to do it?
  2. greyboxer
    greyboxer F1 World Champ
    Dec 8, 2004
    12,708
    South East
    Jimmie
    There should be several threads if you take a look in the 308/328 section - if its like the 308 its best to do it with the nose raised
  3. Dr Kananga
    Dr Kananga Formula 3
    Apr 20, 2011
    1,222
    Los Angeles, CA
    Buonapart I. Gallia
  4. PT 328
    PT 328 F1 Rookie
    4,016
    Where is the coolant leaking from? I would verify where the leak is coming from first. If it coming from the expansion tank cap you should replace the cap with one rated at 1.1 bar as this is a common failure point when they get weak. You may also have a water pump going out or a failing hose. Hard to say until you find the source of the leak.
    If all you want to do is bleed the air then the procedure not in the thread DrKananga noted is accurate.
