Bleeding my Testarossa Coolant, where? | FerrariChat
Discussion in 'Boxers/TR/M' started by 4carbs, Jun 30, 2009.
  1. 4carbs
    4carbs Karting
    May 4, 2006
    59
    Toronto, Canada
    Peter
    Ferraristi,
    I feel stupid asking this question, but my system needs to be bled and I don't know where to do it from. I have searched the other threads, and have come across some where they describe where the bleeding should be done, however I don't even know what the bleed screws look like on the Testarossa. My 308 is quite simple at the rad, but on the TR, I don't see a similar type of bleed screw on the locations that are described in previous threads.
    If anyone has any pictures of what the bleed screws look like, it would really help me.
    Thanks again.
  2. Rifledriver
    37,121
    On the firewall in the middle there is a thermostat housing. On the top in the middle of that there is a brass screw that will take a 10mm socket to loosen.
    On each side of the engine compartment towards the front there is an aluminum water pipe. On the top of the pipe is a bung with what looks like a brake bleeder screw in it pointing up. On the left side it is a little difficult to see and access because it is next to and slightly below a frame tube which obstructs it. I wold suggest taking the bleed screws totally out of the pipes and coating them with some antisieze. They have a nasty habit of getting corroded and wanting to stay in.
  3. Rifledriver
    37,121
    #3 Rifledriver, Jun 30, 2009
    In this picture you can see the bleeder on the thermostat housing in the middle of the firewall. The bleeder screw is just peeking out from under the black grill. You can also see the one on the right coolant pipe in the lower right corner of the picture. There is one just like it behind the air injection pump filter on the left side not visable here.
  4. 4carbs
    4carbs Karting
    May 4, 2006
    59
    Toronto, Canada
    Peter
    Alan,
    Thanks for all the help! I was just able to get my system bled because of your help.
  5. Rifledriver
    37,121
    Good to hear.
    Is the car OK or are you just servicing it?
  6. jgmblair
    jgmblair Formula Junior
    814
    Winnipeg, MB Canada
    Jeff Blair
    #6 jgmblair, Mar 5, 2016
    Thought I would post this here instead of starting its own thread. Looking at an old book and came across this picture of what would appear to be a coolant drain hose is that correct? Was this just used to bleed the system then removed?
  7. 302Tim
    302Tim Formula 3
    Jul 2, 2011
    1,182
    Northern California
    Tim
    #7 302Tim, Mar 6, 2016
    That hose is the "SAIAG" imprinted 3.5 - 8mm vacuum hose that would connect to the electro-valve on that side under the fender (on a US car). That's a production line photo so they may have just run the hose and not yet made the connections. Or, as you said they may be using extra hose to bleed the coolant without making a mess (i do that too). If for that purpose the hose is removed afterward.
  8. blown daytona
    blown daytona Formula 3
    Feb 6, 2008
    1,679
    maryland
    I used an Air Lift kit. No bleeding required. Quick easy no mess :)
  9. Chief20123
    Chief20123 Karting
    Dec 22, 2012
    169
    Melbourne,Australia
    Fred
    what's an air lift kit?
  10. wintech
    wintech Karting
    Jun 1, 2011
    206
    Perth WA
    Pete K
    Nitrous Oxide Fred
  11. 512man
    512man Formula Junior
    Jun 27, 2014
    337
    Sweden
    Tobbe
    Dont understand..Please explain?
  12. 1TRICK6
    1TRICK6 Karting
    Aug 28, 2014
    159
    So. Cal (L.A./O.C.)
    Jim
    Amazon sells these air lift kits that purges the air out of your cooling system and then fills it with coolant. Search (air lift coolant) on Amazon. I don't have one but thinking about getting one next time I change my coolant.
  13. 512man
    Jun 27, 2014
    337
    Sweden
    Tobbe
    Ok,thanks.
  14. wintech
    wintech Karting
    Jun 1, 2011
    206
    Perth WA
    Pete K
    Tobbe,
    vain attempt at humor to Cheif (an in joke) Nitrous oxide, makes one laugh or lift one up.
    Hmmm
    Pete
  15. 512man
    Jun 27, 2014
    337
    Sweden
    Tobbe
  16. jgmblair
    814
    Winnipeg, MB Canada
    Jeff Blair
    Just doing some service on my car and drained the coolant, noticed a rubber grommet near the base of each rad and looking at the pic it appears this hose runs through it, guess I just figured out another little interesting fact about my car :)
  17. Shamile
    Shamile F1 Veteran
    Dec 31, 2002
    6,712
    Lakeland FL
    Shamile
  18. Chief20123
    Chief20123 Karting
    Dec 22, 2012
    169
    Melbourne,Australia
    Fred
    Great thread on coolant bleeding. Tried to loosen the Radiator bleed screws, no success. They are too tight, maybe seized, and if I put any more force they may break. The only bleed screw that I can use is the one in the centre on thermostat body. Any suggestions?
  19. turbo-joe
    turbo-joe F1 Veteran
    Apr 6, 2008
    9,547
    romano schwabel
    what about the 2 bleeding screws in the aluminum pipes?
  20. Chief20123
    Chief20123 Karting
    Dec 22, 2012
    169
    Melbourne,Australia
    Fred
    Romano, sorry, they are the ones I meant. The two on the Coolant pipes...I think they may be seized.
  21. Rifledriver
    37,121
    Air Lift?
    Seems everyone has been told how already.
  22. vincenzo
    vincenzo F1 Rookie
    Nov 2, 2003
    3,373
    but, personally I would not use unless there was no other way.
    Life Does NOT Suck!
    vincenzo
    [ame]http://m.youtube.com/watch?v=lgtax96BH9c[/ame]
  23. Rifledriver
    37,121
    Been using it for years. Can think of no good reason not to.
  24. jgmblair
    814
    Winnipeg, MB Canada
    Jeff Blair
    Hey Brian,
    Any comment on the factory picture in post 6. Is that line something they used then removed after they bled the system?
    Cheers,
    Jeff
  25. vincenzo
    vincenzo F1 Rookie
    Nov 2, 2003
    3,373
    #25 vincenzo, Mar 15, 2016
    Perhaps my concern is unwarranted.... but,
    When you unclog a drain with a plunger, you break the plug free by cycling pressure/suction/pressure/suction etc etc.
    Having used stop leak (as a kid, on a beater), I know that very small particles under pressure are jammed into each of the teeny tiny crevaces and leak points in our cooling systems. They plug microscopic leak paths.
    I don't want to break 'em free.
    Life Is Good,
    vincenzo
