Bleeding Testarossa Clutch | FerrariChat
Discussion in 'Technical Q&A' started by HK9, May 16, 2018.
  1. HK9
    HK9 Rookie
    Nov 18, 2015
    4
    Hey guys, I let my 85 TR sit for longer than it should and I need to bleed the clutch. I know where the bleed plug is but where do you refill the fluid? Any help is appreciated, Thanks!
  2. Ferrari Tech
    Ferrari Tech Formula 3
    Mar 5, 2010
    1,229
    Georgia
    Wade Williams
    The clutch shares with the brake master cylinder reservoir. When bleeding the clutch, make sure you keep the fluid full, as the clutch will run dry if it drops below 3/4. This protects the brake system in the event of a loss of fluid in the clutch.
    Fill the reservoir and open the bleeder, push the petal fully down and close the bleeder before releasing the petal. Try pressing the petal and if it does not come off the floor on its own, repeat the above process. Once it starts to return the petal, you can pump it vigorously and then hold it down and open the bleeder, close the bleeder and release the petal. Repeat until the petal is firm and clutch actuation is normal.
    If it was completely dry, you may find that the next day the first push of the petal is soft. Tiny air bubbles may still be in the fluid when you finish bleeding and sitting over night lets the tiny bubble come together and become one larger bubble. If the petal is soft on the first push, just bleed it again until you see the bubble pass and that will take care of the issue.
    Then go drive the hell out of it.
  3. ago car nut
    ago car nut F1 Veteran
    5,520
    Madison Ohio
    David A.
  4. brian.s
    brian.s F1 Rookie
    Nov 3, 2003
    3,809
    Midwest
    Brian
    On TRs and 355/348 we often do a reverse bleed to start the system fill, pump clean fluid back through the bleed screw having sucked out the reservoior. Then have someone help with a regular pump/open/close/pump/open/etc.. until the fluid runs clear. Or the newe style pressure bleeders work very well, I have a long hose to my drain bottle and have thart located higher than the bellhousing.
    tbakowsky likes this.
  5. innerloop
    innerloop Formula Junior
    Jan 17, 2010
    260
    Houston Heights, TX
    I had good results using a pressure bleeder on the 348. Not only does it make it a one person operation, but the constant flow of fluid (vs. the stop-start flow of the pedal pump and bleed method) continually pushes any air bubbles through the line. The stopping and starting of other methods can allow air bubbles to back flow to higher points during times of no fluid movement.
