Blinking Gear indicator | FerrariChat
Discussion in '360/430' started by ICULUKN, Jul 28, 2018.
  1. ICULUKN
    ICULUKN Formula Junior
    Apr 11, 2007
    548
    Ahwatukee AZ
    G.P.
    Highway Driving in 6th gear today in my 430 and I saw my gear indicator blink... Not rapid... but a slow methodical blink... It blinked 4-5 times and stopped and it only did it in 6th gear....
    Ideas?
  2. 24000rpm
    24000rpm F1 Rookie
    my experience said it could be a lot of things.
    even changing an TCU will solve the problem
    sometimes do a self-learn will solve the probelm
    sometimes it means there's a tiny leak on the valve body
    somtimes there's an actuator centering issue
    sometimes none of above, and i couldn't figure out why, just like you
  3. ideloera
    ideloera Formula Junior
    Jun 2, 2015
    525
    Chicago
    Isi
    Had the same experience with my F430. The potentiometers failed a year later.
  4. djempire
    djempire Formula Junior
    Apr 30, 2012
    613
    Toronto
    Serf
    The flashes indicate the gears are not engaging properly. As suggested by @ideloera, the potentiometer is failing or has already failed. I would also get the actuator flushed and perform a self learn.
  5. Skippr1999
    Skippr1999 F1 Rookie
    4,513
    #5 Skippr1999, Jul 30, 2018
    I had this on my 355. Researched some old posts by Dave Helms who said it can be just electrical grimlins. I’m getting a new clutch right now and hoping that is my issue. My Flywheel had not been properly resurfaced when the last clutch plate was installed, thus it wore very unevenly and had begun to slip.
    How old is your clutch ?
  6. mthompson2376
    mthompson2376 Formula Junior
    Feb 2, 2017
    267
    North East England
    Mark Thompson
    I had exactly this on my F430, the gears need re-syncing, it is a simple process, but a dealership job if you want it done right, my car only took a 1 hr to reset, they run through a procedure with software, car was sorted and problem gone, over time the F1 shifters can slightly misalign, the blinking is a warning that it is not syncing properly, more use may skip a gear or simply not go in gear in the case of 1st and 6th. Nothing to worry about in my experience, nothing has broken, it is the car letting you know it needs a small resetting/adjustment on the gearbox, and protecting itself from ramming gears home when they may not mesh perfectly and causing much more trouble.
    Mark T
    KC360 FL likes this.
