Block Studs | FerrariChat
Block Studs
Discussion in '206/246' started by swift53, Oct 5, 2025 at 6:46 PM.
  1. swift53
    swift53 F1 Veteran
    8,553
    E.S.
    Alberto
    Has anyone replaced Engine block studs? Do they even exist? Are they prone to failure?
    Thank you.
  2. TTR
    TTR F1 Veteran
    6,073
    Riverside, CA
    Timo
    No personal experience on Dino engines, per se, but I've replaced variety of (cylinder head, main cap, connecting rod, etc), bolts/studs on variety of engine blocks I've rebuilt, including Daytona, due to variety of reasons over past 4+ decades and imagine there are countless or at least millions of others who've done it too.
    Most I've ever needed were available either OEM or aftermarket, but some I had to have custom made-to-order.
    swift53 likes this.
  3. pshoejberg
    pshoejberg Formula 3
    1,866
    Denmark
    Peter H
    I'm assuming you mean the studs for the heads? I've changed the studs and nuts on my L-series engine precautionary during a engine out service in 2020. The studs are readily available from the usual suppliers . They are made in improved material and methods and pricing is fair. I consider it a "worth while" job to do unless you know the history of the original studs and that they appear in good condition. On the L-series engine you will need to seal the studs with Loctite hydraulic sealer (Or similar brand) because the threads in the block enters into the cooling water gallery.
    Best, Peter
    Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login
    Ribolla_67, swift53 and TTR like this.
