Blow By System Hose - Wet with oil? | FerrariChat
Discussion in '308/328' started by teatime, May 30, 2025.
  1. teatime
    teatime Rookie
    Mar 8, 2009
    43
    NW Burbs, Chicago
    Todd A.
    I tried to find this through search but came up empty. I have an 84 308 GTS US car, just passed 85K miles, owned for it 15 years and put 30K on it, it has been well enjoyed!
    I noticed that the blow by hose on the rear bank, is pretty wet with oil. Just touching it and there will be oil on my finger. I took the attached picture, and you can see it's pretty well saturated with oil.
    I'm not a mechanic, but I understand this is a vent hose for the oil vapors. There is a similar hose on the front bank, but that one is dry. I noticed this a little over a year ago, and I replaced this hose because I thought the original hose went bad, but now this replaced hose is just as wet as it was before. When I look at other 308s, it appears this hose looks pretty dry compared to mine.
    So, hoping to get an opinion if this is just normal or perhaps indicative of a problem?
    I have changed out all the original fuel and coolant hoses with Scuderia Rampante products and I see they make this particular hose kit too, so thinking to get it, but if there is a problem elsewhere I'd want to address it.
    Thanks in advance for any thoughts/advice on this.
  2. Jerry458
    Jerry458 Karting
    Nov 6, 2024
    85
    NYC
    I would not be alarmed at all but you can order a complete replacement hose kit from many vendors only, i would start with replacing the hoses first as they crack inside which you can not see unless you remove the hose so yours may be cracked due to heat etc i have been there many times and replaced these now at every service. if the new hoses get wet then you need to explore where the leak is coming from. Now I am wondering if you were not doing the oil changes yourself a sloppy mechanic can make a mess removing the oil filter getting that hose wet very easily with, something else to consider
    teatime likes this.
  3. GordonC
    GordonC F1 Rookie
    4,163
    Calgary, AB, Canada
    Gordon
    I'd suggest that you'll want to check the entire oil vapour recovery system for blockages - not just those hoses, but the connecting pipe, the canister they connect/drain to, and the drain line from the canister to the front of the engine block (middle of block, lower down). IIRC there are mesh screens in the cam cover ports that the hoses connect to, you'll want to check that those aren't blocked.
    A blockage somewhere in that system could be causing pressure buildup in the engine crankcase and forcing oil up - or even something like a blocked oil drain passage in the rear head could be forcing oil up into that hose. Just speculation, but that hose would not be saturated in normal running operations, so something is not right.
    Gordon
    Rifledriver and teatime like this.
  4. Rifledriver
    37,075
    When was the last time the PCV system was serviced? As the previous post outlined, they cannot just be ignored.
    teatime likes this.
  5. moysiuan
    moysiuan F1 Rookie
    4,183
    Canada
    I dont understand why oil would be on the outside of the hose, it is not coming through the hose unless old and cracked, and you rrplaced that, so the oil source must be somewhere else. I there a cam cover leak with oil wicking up the hose fabric?
    teatime and Steve Magnusson like this.
  6. Steve Magnusson
    26,764
    +1 -- or the nipple has some sort of damage/nicking/roughness on the outside, and isn't sealing well to the inside of the hose. In any case, not a huge issue...
    teatime likes this.
  7. moysiuan
    moysiuan F1 Rookie
    4,183
    Canada
    Those pretty older style cad plated hose clamps are unobtanium, so don't lose or get rid of those!
    That said, they do not seal as well as the Norma style clamps used in the later years of 328/Mondial 3.2 series. Perhaps tighten those clamps, or try the Norma clamps. Those hoses are very thick and hard, tighten them with the engine hot, you will be surprised how much tighter you can go when the hoses are heat pliable.
    It is possible that aluminum pipe has fractured, it is a hard but somewhat brittle aluminum. Check the pipe for integrity, hairline cracks and such.
    The suggestion to dismantle and clean the blowby system is not a bad idea. That said, the key blow by part is a weird shaped hollow metal canister item with a simple baffle in it. You would solvent rince it out, and replace the various hoses. I am sure cleaning out after many years is a good practice, but it is hard to imagine this system getting blocked or plugged up.
    teatime likes this.
  8. Michael DB
    Michael DB Karting
    Dec 22, 2023
    230
    Michael D Beswick
    Is the problem further up the aluminium pipe and is dribbling down to that hose? Shop paper wrapped round the pipe securely might give indications
    teatime likes this.
  9. teatime
    teatime Rookie
    Mar 8, 2009
    43
    NW Burbs, Chicago
    Todd A.
    Thanks so much Brian, I have done three majors, but I haven't touched it under my ownership (other than replace the hose). Appreciate the insight. BTW..my car has records showing it was serviced by you under previous ownership in Walnut Creek circa 2005~2006, small world.
  10. Rifledriver
    37,075
    The pipe is anything but hard and brittle. It is soft and malleable. They bend very easily. The vapor separator gets a great deal of water moisture and being clogged with rust and or sludge is very common. The return hoses clog commonly as well.
