Blow-By system? | FerrariChat
Blow-By system?
Discussion in '365 GT4 2+2/400/412' started by dougmilbourne, May 16, 2011.
  1. dougmilbourne
    dougmilbourne Rookie
    Dec 22, 2006
    41
  2. Fritz Ficke
    Fritz Ficke Formula 3
    2,261
    Tucson, AZ.
    Fritz Ficke
    All engines have to ventilate the crank case of compression blow by.
    If they did not run it back into the intake it would be done with a 'road breather,' not very tidy.
    In the 1960's Positive crank case ventilation was for clean air but now it is just a clean way to get crank case gases out to the back of the car after being processed through the engine.
    So "no" it is not a exhaust emission device. Are a safety thing.
  3. It's Ross
    It's Ross Formula 3
    Jul 30, 2007
    2,028
    Barrington, Ill. USA
    Ross
    Crankcase gases were discovered to be a significant contributor to Los Angeles' smog in the early sixties. Burning those gases with the intake charge was and is indeed done to reduce tailpipe emissions.
    Other than breathing the polluted air there is safety issue.
    Evacuating crankcase pressure is also beneficial to making power. Full race engines will also have crankcase ventilation systems.
  4. Fritz Ficke
    2,261
    Tucson, AZ.
    Fritz Ficke
  5. Ak Jim
    Ak Jim F1 Veteran
    9,486
    North Pole AK
    Remember these cars were never brought into the US by Ferrari. Did Italy/Europe require the system for emissios reasons? I remember when I was a kid we had a couple of cars that had the breather tubes vented to the atmosphere and it was kind of nasty. A lot of modern race engines actually put powerful vacum pumps to scavange the crankcase.
  6. Flinch
    Flinch Formula Junior
    Nov 15, 2009
    302
    Holland and Sweden
    Peter El Cheapo
    The system we have on our V12 dates back longer. Way longer before we in Europe even considered emission equipement. I guess it was just designed to keep the engine bay clean and burn off the ventilation gasses via the intake.
  7. It's Ross
    It's Ross Formula 3
    Jul 30, 2007
    2,028
    Ross
  8. Fritz Ficke
    2,261
    Tucson, AZ.
    Fritz Ficke
  9. dougmilbourne
    Dec 22, 2006
    41
    Thanks for the responses.
