blue smoke on cold start for f430 normal? | FerrariChat
Discussion in '360/430' started by dcautomotive, Feb 26, 2010.
  1. dcautomotive
    dcautomotive Rookie
    Dec 26, 2009
    22
    rocky mount NC
    Robert Zampardi
    pretty much every time i start the f430 cold, 07 3500 miles, i get a nice puff of blue smoke.
    was wondering if this was normal?
    I am used to it in early porsche but was un sure about ferrari
    robert
    www.dcauto.com
  2. spdrcr
    spdrcr Formula Junior
    Aug 2, 2004
    318
    San Jose, CA
    Matt
    Sounds like it could be burning oil. Not sure about the F430, but on other cars I've owned it's been attributed to bad valve seals. Just to be safe I'd bring it in to the dealer to have them check it out.
  3. Loz997S
    Loz997S Formula Junior
    Aug 26, 2007
    988
    Bay Area
    Laurence D
    In every car I've ever owned that's a bad sign. Hope RifleDriver is around, he'll comment.
  4. Challengehauler
    Challengehauler Formula 3
    Jul 28, 2008
    1,315
    NE Connecticut
    DB
    NORMAL
    IT SHOULD GO AWAY WITHIN SECONDS.
  5. Rifledriver
    37,099
    If it is indeed blue smoke it is not normal.
  6. Rifledriver
    37,099
    If it really is blue smoke it almost certainly means someone overfilled the oil. That possibility should be investigated and rectified.
    It is probably steam from condensation. If so, that is normal.
    Smoke lingers and has a smell. Steam dissipates very rapidly and does not smell.
  7. Ari
    Ari Karting
    Feb 23, 2010
    160
    Everglades City FL
    Ari Silversteinn
    Not good, not good at all. If it is truly blue and has an oily residue, you have something akin to either a minor problem to a potentially major engine disaster.
    Yeppers, my 911T did the same thing but different car and reasons for the short blue poof.
    Take a piece of white cardboard or metal, start the car with the metal/cardboard a few inches from the exhaust. You will be able to easily tell if it is oil.
  8. Challengehauler
    Jul 28, 2008
    1,315
    NE Connecticut
    DB
    Agreed, over filled oil will make it's way into the intake manifold and even into the mass air sensors. This has to be cleaned out....must be cleaned out.
    BUT....I should have been more clear about color. Be sure it's blue before you start to freak out.
    Check the oil level HOT and engine running.
    I have seen brand new cars throw a puff of white smoke upon start up.
  9. Financialman
    Financialman Formula 3
    Sep 8, 2005
    1,841
    San Jose CA
    Dan Carpenter
    My 430 has no smoke of any kind at start up, just turned 11K miles.
  10. zstyle
    zstyle Formula Junior
    Jun 28, 2007
    552
    Tempe
    Jon
    since the dry sump vent's into the throttle bodies, oil vapor could be getting sucked down into the chambers. if it's very excessive and not just at start up, it could be valve guides.
  11. TFord
    TFord Rookie
    Jul 8, 2008
    23
    I had the same issue last week, but it was white smoke. I took my car into the dealer and they checked it out and found no issues. Likely condensation. My car has 14k miles.
  12. forgeahead
    forgeahead F1 Rookie
    Sep 16, 2008
    4,408
    Rocky Mount, NC
    Ray
    Dang. I'd check those seals. Get it checked while still under warranty!
    We are fortunate to be in the service area for Foreign Cars Italia. They'll get it straightened out with a minimum of pain. Perhaps the can pick your car up when they drop off my Cali!
    Nice to see that you're off ban Rob!! Behave!
