Bluetooth Receiver for Maranello | FerrariChat
Discussion in '456/550/575' started by Dm993tt, Aug 23, 2019.
  1. Dm993tt
    Dm993tt Rookie
    Aug 19, 2019
    38
    David
    Does anyone have a favorite solution for a head unit with bluetooth receiver for their Maranello?
    Thanks in advance
  2. AVIMAX
    AVIMAX Formula Junior
    Aug 5, 2014
    686
    Toronto
    Ryan
    I bought this Continental unit. Bluetooth audio and phone. I like that it looks sort of similar to the original Becker unit and is not “blingy”. They also have an option without the CD player, a larger screen and only one knob, but I thought this looked more appropriate.
    F456M, Bas, root and 2 others like this.
  3. Dm993tt
    Dm993tt Rookie
    Aug 19, 2019
    38
    David
    Looks great! Does the job well??
    Thanks for the response. Just a regular din unit? Simple swap?
  4. AVIMAX
    Aug 5, 2014
    686
    Toronto
    Ryan
    Yes does the job well. Regular 1din sized unit. I used to use a Bluetooth receiver from Becker Autosound plugged into the OEM Becker unit, but I always had some background interference noise and it only does music, no phone. I really wanted to add Bluetooth phone.
  5. Dm993tt
    Dm993tt Rookie
    Aug 19, 2019
    38
    David
    Thanks for quick response!!
  6. dsd
    dsd F1 Rookie
    Nov 19, 2006
    4,191
    Northern Virginia
    Dm993tt likes this.
  7. JLF
    JLF Formula 3
    1,645
  8. Bas
    Bas Four Time F1 World Champ
    Mar 24, 2008
    41,356
    ESP
    Bas
    So hard to find a non-flashy single din unit that has bluetooth music functionality. Finally!
    F456M likes this.
  9. docapl
    docapl Formula Junior
    385
    SF Bay Area
    Anthony
    Is the Continental head unit a "plug and play" replacement for the Becker?
  10. AVIMAX
    Aug 5, 2014
    686
    Toronto
    Ryan
    Almost. The switched power and permanent power pins are reversed so you must de-pin pins 4 and 7 and reverse them in the connector of the car's harness. I also did not have any wire going to pin 6 in my car (even though the radio pinout diagram shows it), so I did not have any backlight illumination of the Continental unit. I spliced a wire into the switched power line and added a pin to pin 6 to the car's connector. If you don't care about the backlighting, all you need to do is reverse pins 4 and 7 which is easy enough to do. Just google "how to de-pin an ISO connector". The only trick on the Ferrari connector is there is a locking pin that needs to be pulled out of the connector before you can remove any pins. There is a pinout diagram on Becker unit and one in the Continental manual.
    docapl likes this.
  11. F456M
    F456M F1 Rookie
    Jan 8, 2010
    3,665
    Oslo
    Erik
    This looks great Jas Baski. I ha e a Pioneer retro look model now from 2003 and installed a Focal activ subwoofer behind the drivers seat. No Bluetooth but CD. Great sound now after six years of terrible sound! I am looking to add a Bluetooth adapter of some kind. Image Unavailable, Please Login
