430 - Bluetooth | FerrariChat
430 Bluetooth
Discussion in '360/430' started by Luano Nomellini, Jan 27, 2021.
  1. Luano Nomellini
    Feb 27, 2020
    13
    Luano Nomellini
    Any recommendations on converting my existing stock radio to Bluetooth to stream music on my 08 F430
  2. mike32
    mike32 F1 Veteran
    May 13, 2016
    5,835
    Isle of man- uk
    Alpine cde 203bt is a straight 5 min swap, no need to cut any wires, just needs one plug adaptor
  3. flash32
    flash32 F1 Veteran
    Aug 22, 2008
    5,680
    Central NJ
    Dominick
    JimDowd1 likes this.
  4. wtam608
    wtam608 Rookie
    Sep 24, 2015
    28
  5. Sj_engr
    Sj_engr Formula 3
    Sep 15, 2020
    1,310
    San Jose
    dc
    Interesting solution on the older 30pin adapter.
    I would think the bluetooth option depends on whether you desire to remove the deck, add something to the cig lighter port, put something behind the stock deck with mini-ISO or adapt an older iPod style connection.
  6. CoreyNJ
    CoreyNJ Formula 3
    2,030
    New Jersey Shore
    I have the factory iPod interface and use a Bovee 1000. Worked great till my last iOS update, now it only works in "aux" mode where I can't control the iPod over bluetooth from the Factory radio. Prior to this I could browse my playlists, songs and stuff and pick wirelessly from the OEM radio.
  7. Ray Smith
    Ray Smith Formula Junior
    851
    Costa Mesa, CA
    Raymond Smith
    I'm having a similar problem with a Pioneer AVH3500NEX head unit and IOS 14.3 after a recent upgrade. Siri will play music and and GPS directions, but follows every action with the message "There was an error".
    I will contact Pioneer and see if they offer a firmware upgrade to ameliorate this problem.
    I *hate* Apple.
    Ray
  8. Ray Smith
    851
    Costa Mesa, CA
    Raymond Smith
    Update: Pioneer only handles IOS 13 and has no newer firmware upgrade.
    Ray
  9. CoreyNJ
    CoreyNJ Formula 3
    2,030
    New Jersey Shore
    I can't say I hate Apple, they have indirectly paid for a lot of my toys... I just hate modern technology, things were so much easier when all I had was a Motorola Brick telephone. ;)
  10. mike32
    mike32 F1 Veteran
    May 13, 2016
    5,835
    Isle of man- uk
    2 tin cans and a length of string. No need for batteries
  11. JimDowd1
    JimDowd1 Rookie
    Jan 23, 2021
    23
    Pacific Palisades, CA
    James Dowd
    flash32 likes this.
  12. TexasVince
    TexasVince Rookie
    Jun 9, 2018
    37
    Dallas, TX
    Vincent
    I've tried this adapter in my 08. It does work, BUT...
    It will Bluetooth connect and play from your iPhone constantly over anything else. Every. Single. Time. It's relentless. :p
    It will even connect over your earbuds and autoplay anything you have on the phone, at least in my case. I even had the earbuds in a higher selection priority. It got to the point that I only connect it when I have a long trip and feel the need for music. The music quality is pretty good though.
  13. Ray Smith
    851
    Costa Mesa, CA
    Raymond Smith
    Quite by accident, I discovered that the latest of the frequent annoying and troublesome IOS updates has had an odd effect. It now allows my iPhone 8 Plus to connect to my Pioneer AVH-3500NEX via Bluetooth. Pioneer said it would not. The installer said it would not. They installed a flash cable to allow the phone to connect to and communicate with the 3500NEX. And it did, and worked perfectly. That is until the latest update to 14.3. After that the GPS and Car Play were constantly interrupted by error messages. I was going to pony up for the latest and greatest DMH-8600NEX thinking its later firmware would ameliorate this issues and allow Bluetooth connectivity connections. But after investigation the content of the error messages, it turned out the were failed pairing attempts. When I configured the iPhone and 3600NEX to pair, they did, albeit glacially slowly. So the problem was never with the Pioneer unit, it was the iPhone 8 Plus.
    The pair will now play Car Play and GPS directions without interruptions caused by the pairing issues. Via Bluetooth.
    If you have a Pioneer unit that uses Bluetooth, update the phone to IOS 14.3, set the Pioneer to advertise its presence, and enable auto connect. Then try to pair the units. It's a slow process, but it works.
    Serendipity.
    Ray
  14. Enzo Sebastian
    Enzo Sebastian Karting
    245
    Amsterdam
    Laurence Sebastian
    Hi Ray,
    You're saying you have wireless Carplay now with your Pioneer 3500NEX flip-up screen? With bluetooth connection, you can have Carplay, is that correct?
    I have an iPhone 8 and I want to replace the SPH-10BT Pioneer radio with a flip-up monitor with Carplay function, but wireless Carplay would be great!
  15. Ray Smith
    851
    Costa Mesa, CA
    Raymond Smith
    Yes, it does connect and offer car play. However, and you can experiment with this, I found that it does not work as well as it does when connected with a flash cable. It simply does not work the sameS way. For example, the gps will give verbal directions but not show the map. Siri responds to commands but Carplay does not display on the screen, although it plays the music just fine. Also, wireless, volume is controlled by the phone, not the Pioneer.
    I went back to using the cable and turned off auto-pair and pairing broadcasts.
    Ray
  16. Clint 360
    Clint 360 Rookie
    Apr 25, 2018
    12
    Gold Coast, Australia
    Clint
    brogenville likes this.
