Hi to all, It's been some time since I wrote on this forum. I am looking for a small part which I don't even have a part number as I cannot find it not even on the original parts catalogue. Well I need a clip which holds the tail gate number plate wires for the 328. It is located a the right hand side hinge and the wire connector clips into it. Thanks for any help, Regards, Stephen
It just occured to me that it might be hard for you to post a pic if you are missing the part. I have attached a pic of some hinges I acquired recently. One has a wire clip attached. Is this what you need? Image Unavailable, Please Login
Looks like it although a bit too far. However there is inly one clip and it should be on the right had side hinge. ie passanger side. Regards, Stephen
Yep, I'm sure that's it. If I were to turn the hinge over a spring clip would be visible. Please PM me your address and I will get this on the way. No charge. Best...Jim
