Boeing Starliner | Page 2 | FerrariChat
Boeing Starliner
Discussion in 'Aviation Chat' started by BJK, Sep 4, 2022.
  1. BJK
    BJK F1 Veteran
    Jul 18, 2014
    5,695
    CT
    Launch is scrubbed as teams evaluate an oxygen relief valve on the Centaur Stage on the Atlas V. :rolleyes:
  2. BJK
    BJK F1 Veteran
    Jul 18, 2014
    5,695
    CT
    TODAY >>> 12:25 pm ET (1625 UTC)
    TWITTER
  3. BJK
    BJK F1 Veteran
    Jul 18, 2014
    5,695
    CT
    SCRUB >>> again :rolleyes: :( .......... Safety first ;)
    >>> 1,000 things can go wrong. >>> how often do SpaceX Crew launches scrub? Appreciate what they accomplish more ...... just sayin'
  4. Mondog1
    Mondog1 F1 Rookie
    4,326
    Philly burbs
    Robert
    These delays are painful to watch. Doubt there is any accountability, heck someone will probably get promoted with these delays (F up and move up the ladder)
  5. vandevanterSH
    vandevanterSH F1 Rookie
    3,416
    AR
    Stephen Van Devanter
    Boeing received $5 billion development cost funding from NASA (SpaceX received 1/2 that to develop its successful Crew Dragon)....Boeing has put in at least another $1.5 billion and still hasn't gotten off the ground.
  6. Rifledriver
    37,327
    The primary goal of any publicly funded project is to get more funding. Any other results are strictly coincidental.
    NYC Fred likes this.
  7. BJK
    BJK F1 Veteran
    Jul 18, 2014
    5,695
    CT
    These last 2 scrubs were on ULA rocket (normally very reliable), not Boeing.
  8. vandevanterSH
    3,416
    AR
    The Atlas V, powered by a Russian engine, has been very reliable. !st scrub was valve problem in 2nd stage, recent scrub was issue with ground control computers.
  9. BJK
    BJK F1 Veteran
    Jul 18, 2014
    5,695
    CT
  10. jcurry
    24,153
    In the past
    Jim
    ULA is a joint venture between Lockheed and Boeing;):eek:
    BJK likes this.
  11. BJK
    BJK F1 Veteran
    Jul 18, 2014
    5,695
    CT
  12. BJK
    BJK F1 Veteran
    Jul 18, 2014
    5,695
    CT
  13. INRange
    INRange F1 World Champ
    12,931
    Virginia/Florida/Caymans
    JD
    Nice launch. I could comment that launching a couple of people into orbit really isn't a big deal for Space X and they reuse their booster. Star Liner has a long way to go.
    NYC Fred, jcurry and BJK like this.
  14. jcurry
    24,153
    In the past
    Jim
    I don't like use of solids for manned flight. Otherwise, ho-hum except for the fact it took them so long and a few more $ than Musk.
    NYC Fred and INRange like this.
  15. tazandjan
    39,370
    Solids did not work out perfectly for the STS.
  16. jcurry
    24,153
    In the past
    Jim
    Sure the joint, but what I don't like is the on/off feature. Once you light the boosters your options are immediately reduced.
  17. jcurry
    24,153
    In the past
    Jim
    So was this a one way trip? Does SpaceX have to go rescue them? Dragon has room for 6 or 8, right.
    kylec likes this.
  18. kylec
    kylec F1 Rookie
    Jun 9, 2005
    3,671
    Orlando
    Yeah, not a good look
    jcurry likes this.
  19. tazandjan
    39,370
    The helium provides the RCS for reentry. Now they just have to calculate whether the leak rates exceed the amount needed to keep the vehicle pointed in the right direction for reentry. And hope they get it right. Assuming they can top up the helium from the station.
    INRange likes this.
  20. EastMemphis
    EastMemphis Formula 3
    May 25, 2019
    1,905
    Memphis, TN
    I believe that would be an incorrect assumption. The design doesn't appear to take into account that helium could leak out while attached to the station. If it goes flat, it would likely take a special trip by a dedicated team with equipment designed to operate in a vacuum and zero G to refill those tanks.
    If they determine the helium pressure is too low for the capsule to survive, it would likely be filled with trash and ditched.
    The ISS itself has no onboard helium.
    BJK likes this.
  21. BJK
    BJK F1 Veteran
    Jul 18, 2014
    5,695
    CT
  22. INRange
    12,931
    JD
    Why do they use helium? SpaceX uses "storable hypergolic propellants" (like hydrazine) for their RCS. I get the inert gas perspective but effectively they have been chasing this leak for months. I'm sure the amount of stored helium pressure must be ridiculous to match the effectiveness of a propellant.
    At what point do you just say: "We screwed up with this NASA/Boeing design and need a Falcon launch to bring the astronauts home"?
  23. EastMemphis
    May 25, 2019
    1,905
    Memphis, TN
    Generally, helium is used to pressurize the propellent tanks.
    INRange likes this.
  24. tazandjan
    39,370
    Helium is used on a large number of space systems for reaction control. While it has a lower Isp than hypergols, it is also much simpler and usually lower risk than relatively nasty hypergolic propellants. Bad news is the helium molecule is very small and can leak easily through any miniscule opening in lines or fittings. The helium tanks are also very high pressure, typically around 8000 psi, and this can also make it easier for leaks to develop short of the pressure regulator.
    Those high pressure tanks can also be a danger in themselves. One of the programs I worked on, Modular Insertion Stage, had a helium tank blow up during filling from being overpressurized due to a faulty pressure gauge. Took out the stage, another nearby experimental stage, and luckily only broke the arm of a tech in a plywood safety enclosure nearby.
    As John mentioned, helium is also used to pressurize propellant tanks for obvious reasons.
    EastMemphis and INRange like this.
  25. jcurry
    24,153
    In the past
    Jim
    Dewinator and INRange like this.
