Bolts, dowel, rusting wheel nut | FerrariChat
Discussion in '348/355' started by C'dwic, Jun 11, 2022.
  1. C'dwic
    C'dwic Formula Junior
    Apr 23, 2021
    493
    France
    Hello everyone, I have the head of some of my studs that are rusting, I imagine I am not the only one?
    what did you do to avoid this?
    If you had to change them all, where to find them? It's really not cheap, should you consider buying titanium?
    My vehicle is fitted as standard, so no chocks or “spacers”
  2. Ferrarium
    Ferrarium F1 Veteran
    Sponsor Rossa Subscribed
    Jul 28, 2018
    5,728
    Central NJ
    Eric
    Your referring to the head of the bolts that the socket goes on to remove the bolts that hold the wheels? They get nicked from the socket yes, I believe Hill or Griot's Garage sells a socket that reduces that. They have plastic on the inside and the outside.
    https://www.griotsgarage.com/search-results-page?q=wheel+socket
  3. IvanRico
    IvanRico Karting
    197
    Westchester NY
    Ivan Rico
    According to the description, there’s only an outer nylon sleeve so this wouldn’t help with scratching the lug bolt head itself.
    Qavion likes this.
  4. flash32
    flash32 F1 Veteran
    Aug 22, 2008
    6,956
    Central NJ
    Dominick
    I was always under the impression that the metal was soft aluminum on the inside and the reason it didn't scratch
  5. Ferrarium
    Jul 28, 2018
    5,728
    Central NJ
    Eric
    Ivan, your missing what the actual problems is and how those solve it. The aluminum is only part of it Dominick.
  6. IvanRico
    IvanRico Karting
    197
    Westchester NY
    Ivan Rico
    Fully agreed - I’m not sure I understand what the problem is and whether it’s rust on the lug bolts or the wheel socket or both. Maybe a photo would help?
  7. Ferrarium
    Jul 28, 2018
    5,728
    Central NJ
    Eric
    What causes the bolts to rust is the corners of the bolts. Those sockets are radiused so the corners do not touch the socket. The flat part of the socket is typically not what rusts. If a socket was plastic you would not have very much luck torquing them. Those sockets solve the problem of the lug nut corners getting chipped up from a standard socket.
    Take a close look at the inside of the socket it will make sense.
    Sent using FerrariChat.com mobile app
  8. C'dwic
    Apr 23, 2021
    493
    France
  9. C'dwic
    Apr 23, 2021
    493
    France
    I have the good Key, look at thé Green part... 8 months ago, i asked a détailling and the Guy removed certainly my wheels with a Steel Key...this is the result 8 months later...
  10. MAD828
    MAD828 F1 Rookie
    Oct 8, 2011
    2,631
    Elliott Caras
    The Hill Engineering wheel bolts are far superior to OEM wheel bolts in the chrome plating department. And I use the HE chrome saver socket, with no rattle gun.
    They are relatively cheap as well.
    308 GTB likes this.
  11. C'dwic
    Apr 23, 2021
    493
    France
    Bought to superformance, with the special Key, you right, it's the same as Hill..
